Question about Acer Aspire 5610-4648 Notebook
Primary HDD Password
I am having problem with my Aspire 5610. It opens with and says "Enter Primary Master HDD User Password". I don't have stored a password to open. the system never opens and having problem for many weeks
thanks
Nepal
sunilnep@gmail.com
  • 5 Answers
SOURCE: hdd master password
PLEASE REPLACE UR MOTHER BOARD BATTERY. I GUESS UR BATTERY MODEL WILL BE CR3212... PLEASE CHAGE IT AND TRY IT AGAIN. NOT YOUR LAPTOPS BATTERY... THIS IS A BATTERY ON THE MOTHER BOARD. PLEASE TAKE IT TO UR NEAREST DEALER AND GET IT DONE.. PLEASE DO NOT OPEN IT WITH ANY KNOWLEDGE.
CHEERS
AVI
Posted on Nov 05, 2007
lenny297
  • 133 Answers
SOURCE: need to bypass primary master HDD user password
I would recommend that u take it to a technician but if u can be able to open it u need to remove the cmos jumber inorder to clear the cmos settings, also try to remove the system battery switch on the notebook and the switch it off after a few seconds, replace the battery and switch it on again. It should laod up with default settings which might make other devices not to work since the settings where cleared, so u need to reconfigure the Bio's settings again
Posted on Feb 22, 2008
  • 6 Answers
The solution is to go to BIOS and u can enable and disable the HDD password query item. U can disable it and u can run ur computer again.
Posted on Apr 22, 2008
kikoksky
  • 119 Answers
the only solution is for you to call the acer tech support and they can generate a password for you to gain access to your hard drive and bios.
visit: http://www.acerpanam.com/synapse/forms/webpage.cfm?siteid=7117&areaid=2&website=AcerPanAm.com
Posted on Jun 13, 2008
Eddie333
  • 176 Answers
For Dell you can go here;
http://www.pcdoc.bz/service/dell.htm or
http://www.theonlypcdoctor.com/dell/dell-prod.htm
Posted on Jan 26, 2009
Acer aspire 5610z, enter primary master hdd user password
Sometimes removing CMOS battery of laptop overnight will reset bios parameters.if this does not work you have two other options.Google hirens boot disc 15.1 on another computer and either make a bootable USB. Stick or burn to cd.start laptop in get into bios to change the boot sequence to either cd or USB.let the hirens boot cd run.it installs a small version on windows Xp on the ram and let's you then access the hdd to save all the files and pictures on to other media.it also has many tools including software to read all stored passwords on hdd and bios but I don't recommend this until you have retrieved all you want to save.hope this helps please vote?thankyou.
Feb 07, 2015 | Lifetime Acer Aspire 5610z Replacement...
Enter primary HDD user password.. pls.... me thanks
You can get the HDD master password for your acer laptop from http://www.unlockbiosrecovery.com/Unlock_Acer_HDD.phpFor $20 they will email your Acer HDD master password and they guarantee it t to work. I use them monthly in my work repairing laptops.
Aug 30, 2011 | Acer Aspire 5600 Series 5630-6951 Laptop
After boot, appears ENTER PRIMARY MASTER HDD USER Password i need the password @ solution to boot up my lappy... thanks
How Do I Change the Primary Master HDD User Password?
Prior to loading an operating system, your computer will first execute the BIOS program. The BIOS has an extra password feature, called the hard disk drive (HDD) user password, that can't be bypassed and provides a layer of defense to keep your data secure. To change an existing HDD user password you will have to load the BIOS menu, which is only accessible during the computer's operating system reboot procedure.
Instructions
1. Close any windows that are currently open on your computer. Eject any discs inserted into the optical drive and disconnect any peripheral USB devices.
2. Open the "Start" menu and select "Shut Down." Turn on your computer once the operating system finishes shutting down.
3. Press the key your computer uses to load the BIOS menu. For example, with Dell computers tap "F2" when the "Press F2 for Setup" option appears. Press the "Access IBM" key on IBM laptops or "F10" on HP desktops.
4. Navigate to the BIOS tab that contains the HDD password option, which will usually be the "Security" tab. Some computer manufactures instead include the password option in the "Advanced" tab.
5. Scroll down to the option labeled either "User Password" or "BIOS lock" and hit "Enter." Type the current master HDD user password when the prompt appears and press "Enter."
6. Input a new HDD user password and hit "Enter" again. Navigate to the BIOS tab labeled "Exit" or something similar.
7. Move over to the "Save and Exit" entry and press "Enter." Select "Yes" and tap "Enter."
Nov 15, 2010 | Acer Aspire 5610 Notebook
Primary hdd password
Visit http://acersnoop.co.cc
and get your unlock codes. 100% working!!
Superfast solution with super cheap price.
Feb 04, 2010 | Acer Aspire 5610 Notebook
Need to bypass primary master HDD user password
send me ur email and I'll give you link for software to remove all passwords in bios or windows
Jan 26, 2009 | Dell Inspiron 2650 Notebook
call the acer tech support or go on line a to www.acer.com and they should be able to get you need best regards mike
Aug 11, 2008 | Acer Aspire 5610-4648 Notebook
Jun 13, 2008 | Acer Aspire 5100-5022 Notebook
How to unlock>
Try admin/admin or administrator/admin or just admin/*blank*
If your friend did not set the password it may have been set by a virus.
May 04, 2008 | Acer Aspire 5610-4648 Notebook
Feb 19, 2008 | Acer Aspire 5610 Notebook
Acer Aspire 5610-4648 Notebook Logo
80 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
