Question about Car Audio & Video
Cd player not working
Please can you help my cd player is not giving out sound but the dispay is working it was fine yesterday
  • 25 Answers
Need more info to provide you with a solution. For example, what brand and model is the cd player, is it an aftermarket or factory unit, does the radio work, did you unhook the battery, etc?
Posted on Jul 26, 2008
My 2002 ml 320 says no cd player installed when I press the cd button, it worked yesterday and for some reason it will not work, Any suggestions on how to fix it, the radio comes on but there is no sound...
try resetting the cd player in cargo compartment. you may have to loosen the screws holding the cd player in place to access the plug connector on the cd player. Most likely though it sounds like the fiber optic ring is down. which could be caused by any of the audio components. e.g. comand unit (radio), cd player, sound amp, tele-aid, navigation processor.
Sep 27, 2010 | 2000 Mercedes-Benz M-Class
Dispays 'NO DISC'when disc is loaded in tray and
optical pick up went bad, simply replace it.
Nov 22, 2009 | Teac PD-H500 CD Player
CD player is not working.
I would first try removing the fuse to the radio/cd player, see if that resets the system and get the cd out.
Hope this helps some.
Matt
Jun 19, 2009 | 2003 Mazda Mazda6
2004 Chevy Trailblazer radio and CD player works, but no sound
if you have installed a new cd player in there then the propblem could be that your speaker wires and either touching each other or grounding them selfs out.. pull of the cd player and check to make sure all the speaker wires are covered properly and no bare wires are exposed.. if you still have a factory cd player in it then you will probably need to take it to a dealership to have it checked out..
Feb 18, 2009 | 2001 Chevrolet Suburban
My one-year old Marantz CD5001 CD player
these models use the 12.1 philips laser mechanism and it is a very common problem for failing to read discs.
various technics / marantz / philips / cyrus cd players etc also use it and are plagued with the same fault.
it's a 90% chance the laser is dead!
philips realised the unreliability of this laser and uprated it to the identical looking VAM-12.
do not dismiss the spindle motor as these also fail quite alot on this mechanism.
hope this helps.
Dec 20, 2008 | Marantz CD5001 CD Player
Freeway indash DVD
u need to switch function screen to dvd screen. Button is on front of unit to scroll through screens.
Dec 14, 2008 | Kenwood KVT-817DVD DVD/CD/MP3/WMA 7"...
Bose Lifestyle 12 Porblems
sorry mate, looks like cd 5 is damaged goods...... wheter you damaged it or not, can't say....
however, make sure. when you try to play cd, that the cd button, nearest display was pressed as just putting in a cd isn't automatically taking control of the cd function like in other cd players. ( that is to say you have to diliberately select CD mode to play cd's)
if you fancy a load of electronic messing and visits to radio shack i am sure you can repair it if broken,
or a second hand cd unit could be obtained elsewhere on line.
Jan 02, 2008 | Bose Lifestyle 12 System
Sansa problem being blacked screen please help
You can reset the player by holding the power button for 20 seconds.
It should be fine after a reset.
Best of Luck.
Oct 14, 2007 | SanDisk Sansa E280 MP3 Player
No sound from anything but FM
Disconnect whatever's connected to the blue wire behind the unit, and re-connect it to the blue/white wire instead.
Aug 05, 2007 | Kenwood KVT-617DVD Car DVD Player
Car Audio & Video Logo
60 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
