Question about Sebo Vacuums
Sebo felix upright
Hi, I just tried to put a new bag my new sebo felix and the lid wont shut. So i emptied the original bad and tried to get it to work .. same problem .. lid wont close. I have read that everything must be correctly located for it to close and have tried everything. Any tips would be gratefully received!
Many thanks
Debs
  • 328 Answers
Hey Debs
Ive got a Sebo Felix. Unfold the bag (if its folded) and drop it into the top of the bin. Once you've aligned the plastic parts the two nibs which are pointing outwards towards the handle, make sure the plastic collar is sitting on the rest of the surround.
Now the most important aspect is the plastic flap - not the dust cap - but if standing behind the Felix, there is a green flap on the left hand side of the bag which must be pushed down over the spring (looks like a large staple). Once that is folded over and locked in, the lid should close. If the lid still doesn't close check that the top hose fitting has been securely locked and is dust free. Dont forget to rate, ty.
Posted on Jul 26, 2008
Why will my sebo felix not turn on when it is plugged in. The bag is empty and the beater bar is free of threads and string.
If it is only the power head that does not turn on, make sure that the hose is fully inserted into the bag housing. There is a switch in the bag housing that has to be activated. If you are not getting any power anywhere, the most common cause would be the power cord. If you are getting 120 volts through the cord, you may need a new power switch. I have included a parts list for your machine for reference. http://sebo.us/pdfs/website_schematicsPDFs/FELIX%20Schematics.pdf
Aug 06, 2014 | Sebo Vacuums
How to fix a switch on a sebo vacuum
They are known for the cable to break internally where they go into the machine. It's a simple repair for any vacuum repair shop.
May 02, 2014 | Sebo Felix Classic Bagged Upright Vacuum
Hi, I have a Sebo premier and the brush wont work or the green light come on. Can anyone tell me if you should get 240v on the connector from the main vacuum body to the brush head? I have tested this and...
I understand 240v to be 240 volts. of electricity- no vacuum should have 240v. that amount is used on elect. stoves, air conditions,welding machines and large electic appliances. Check the belt drive and the manual for the green light operation- I still don't understand the 240v deal.
Jan 06, 2014 | Sebo Felix Classic Bagged Upright Vacuum
Brush not working on sebo felix
I had the same problem. Make sure nothing is clogging the airway, then bring the handle down as if to clean but dont turn it on. Press the 'light' button in and then turn it on. Hopefully that should do it.
Jan 16, 2013 | Sebo Felix Classic Bagged Upright Vacuum
Sebo upright barged hoover- good suction using hose, brush wont turn, sounds fine when running, nasty wineing noise when stopping?? help!! i love my hoover, have checked for bolckages....
The real clue seems to be the brush is not turning, a bad belt is possible or a blockage at that head, if you cannot get the brush moving the rest does not matter.
Dec 03, 2012 | Sebo Felix Classic Bagged Upright Vacuum
Sebo Felix Premium Vacuum cleaner brush will not spin. Not the belt, already checked.
Just the other day we had a customer bring a Felix in to our repair shop with the same problem. Although she'd had the Felix for several years, she'd never realized that one of the buttons on the base is a foot-operated switch (the left hand one as you see it from behind the machine). Hers had been "on" from day one, and never been switched off... until she'd obviously inadvertently pressed it without noticing and switched it off. Then she thought something had broken.
It may be as simple as that. So, does the green light come on when you operate the foot switch? If it does, and the brush doesn't spin, you have most likely got a problem with the motor (or possibly the circuit board) in the base. If the green light does not come on, there is most likely a poor (or broken) electrical connection where the bag compartment plugs in to the base.
I'll gladly try to be more help if you want to post more details.
Jul 07, 2010 | Sebo Felix Classic Bagged Upright Vacuum
Power Head not working - no apparent blockage
After double-checking the hose is firmly in it's place (along the side). Contact "Rick" at The Vac Stop...Mt.Dora, FL He's the best I've ever seen on SEBO's SATURDAY and SUNDAY 10A-4P ONLY 352-735-2332 Good Luck!
Dec 28, 2009 | Sebo Felix Classic Bagged Upright Vacuum
Vacuums Logo
282 people viewed this question
Top Sebo Vacuums Experts
Nick Olsen
Chris Nomland
Chris Nomland
Are you a Sebo Vacuum Expert? Answer questions, earn points and help others
