Question about Vacuums
Have a polti vaporetto 2400 been used 3 times approx but out of warranty heats up ok but wont release steam when trigger pressed.have tried flushing water in tank with no results
  • amymillie Jul 31, 2008
    dear Fixya earlier today I sent a reply through this site to say it hadn't worked and to ask where the trigger switch is etc. I was expecting a reply to that instead you have sent me my original letter. Amymillie
  • 77 Answers
These machines like to be used regularly. if allowed to sit (especially after using tap water) they may buld up lime deposits on valves and cause them to stick. you could try filling with vinegar and let set, also tilt it so vinegar runs into valve area. you could heat the vinegar and it will run through the trigger valve area. if this doesn't work you'll need to replace trigger valve.
Jim
Posted on Jul 28, 2008
  • Jim Gillon Jul 31, 2008
    Valve is attached to trigger, may have to replace handle and or hose assembly. on small units (quart or less capacity) there are usually no parts available.
    J
My polti steam cleaner wont work when i click trigger
Check the wand and line for calcium build up especially in the nozzle. Hard water will deposit a lot of calcium in the system, which needs to be cleaned regularly to keep it running freely.
Aug 25, 2014 | Polti Vaporetto 2400 Canister Steam Vacuum
Lost instructions for vaporetto polti 2400
Download instruction manual for Vaporetto 2400
Good Luck
Rating the solution is highly appreciated
May 31, 2010 | Polti Vaporetto 2400 Canister Steam Vacuum
My polti has steam coming out of the tool connection all the time...is there anything i can do with it ?
Either the solenoid vale is stuck open all the time if there is no click when you pull the trigger or the "o" ring is split or missing where the tool fits on
Aug 12, 2009 | Polti Vaporetto 2400 Canister Steam Vacuum
Starting a polti vaporetto steamer
Put a couple of lts. of water in the tank, replace lid, assemble hose with tool you require. Plug in switch on, wait for needle to climb into yellow then pull trigger for steam
Jan 23, 2009 | Polti Vaporetto 2400 Canister Steam Vacuum
POLTI VAPORETTO PROBLEMS
Hi, It is the solenoid that is sticking, It there fore needs opening up, the solenoid valve stripping and cleaning, or replace at a cost of about £12 then putting back together. they don,t like being left and not used. It is possable if you keep clicking for it to start working again.
Dec 09, 2008 | Polti Vaporetto 2400 Canister Steam Vacuum
No steam polti 2001r, heats up clicks, but no steam!!!!!!
the solenoid valve isn,t operating when you pull the trigger. It is caused by either the coil has burnt out on the solenoid or the valve itself is stuck
Nov 06, 2008 | Polti Vaporetto 2400 Canister Steam Vacuum
Polti steam cleaner
It should go just below the red providing steam isn,t escaping from the cap otherwise you won,t get the pressure build up to enable it to come out when you pull the trigger
Oct 23, 2008 | Polti Vaporetto 2400 Canister Steam Vacuum
Cant find out where i get a new gun handle mine has snapped
http://www.spares2you.co.uk/Vacuum+cleaner+spares/Polti+steam+cleaners/Vaporetto+2400/
Mar 14, 2008 | Polti Vaporetto 2400 Canister Steam Vacuum
Polti Vaporetto 2400: Water out light comes on when tank is full
Hi you need to put 5ml of Kal Stop fo Polti machines into 1000/1500ml of water into the tank, The stronger solution is better (1000ml) Let it heat up and this should break down the limescale on the solenoid. I tried this today and it has worked saving ££££'s in repair by Polti.
Nov 04, 2007 | Polti Vaporetto 2400 Canister Steam Vacuum
Vacuums Logo
187 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
