Question about Kenmore 98702 Stacked Washer/Dryer
Clothes don't ring out dry. I thought maybe a belt but how do I get at it?
    Master:
  • 713 Answers
From back you will have to take back off then the side then the belt will be located under tub.
Posted on Feb 16, 2011
SOURCE:
Amana NED7200TW dryer. Has heat, tumbles, clothes don't dry. Vents have been gone through and cleaned. This happens in the sensor dry and time dry modes. Any thoughts? Thanks!
Just a question. Does your blower work. If your blower does not work it won't dry. Check blower belt. Mine broke and had no air blowing. Just a thought.
Oct 21, 2016 | Amana NED7200TW Electric Dryer
Clothes come out of washer wet
Most often you have a worn out belt that spins the drum when it is time to spin dry. Upend the machine and check the belt, if it has one.
A new drive belt should fix you right up.
Mar 14, 2016 | Washing Machines
Why isn't tumble dryer drying clothes?
is there high n low switch............might be set to low...........cheers
Jun 29, 2014 | Zanussi ZDC37100W Electric Dryer
My 4 year old roper washer leaves grease on clothes. On spin cycle the machine makes a screaching noise, and the clothes don't spin dry.
Possible that the belt is slipping and also there is some issue with the agitator as the gaps within seems to bring up the dirt or grease mix to the clothes.
So it is important to remove the panel and check the play on the belt, replace if the play is high and check if the agitator bearings are worn out. If so the agitator assembly must be taken out and checked.
Dec 09, 2011 | Washing Machines
Bosch axxis wtl 5410 dryer takes too long to dry.
You should have a cycling thermostat. this is most likely bad or your dryer vent may be clogged. Something is cutting the heat off before it gets hot enough. Both these cause this problem.
Nov 17, 2009 | Bosch Axxis WTL 5410 Electric Dryer
Takes a lot longer to dry clothes
belts MUST be ordered by model all belts are different sizes, different witdhs
Mar 04, 2008 | LG DLE5977 Electric Dryer
Kenmore 98702 Stacked Washer/Dryer Logo
21 people viewed this question
fordexpert
Kristen Denison
Kristen Denison
Level 1 Expert
Jim Chinnery
Jim Chinnery
Level 1 Expert
