Question about Sharp Office Equipment & Supplies
What does ' download mode mean as soon as the copier is turned on no other function tart ....just the display turns on and stated "download mode" Sparp copier 1655 cs
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Sharp Master
  • 1,362 Answers
Not sure what it means but it's almost impossible to get out, once in that mode. If it's under a year Sharp will fix it for free, call and talk to tech support they will ask for a CC # and will send a prepaid return sticker to ship ground. If not most likely you will have to change the main board!!!!!!!
Posted on Jul 28, 2008
My cannon image runner 330 n says to turn switch on and off then says eoo5 on it what does it mean
this code means you should replace web roller. to start machine temporarily go in service mode. i.e. additional function 2&8 again additional function press copier press counter on top press misc press cleang. web or belt.press C from key pad. the value will become zero in bracket.press ok.switch off and on the machine .E005 will disappear but replace web roller soon.
Aug 09, 2011 | Canon imageRUNNER 400S Copier
Tip
How to Troubleshoot CF-19 The Panasonic Toughbook CF-19, commonly known as...
How to Troubleshoot CF-19<br /><span style="font-style: italic;">The Panasonic Toughbook CF-19, commonly known as simply the Toughbook 19, is a laptop computer geared towards people who work on location, such as field workers or military personnel, who require a sturdy and resilient device. Unique features of the model include its screen which can display clearly in bright sunlight, its touchscreen function and its backlit keyboard. If you experience errors or malfunctions with the CF-19, troubleshoot it to diagnose and solve the problem before replacing the device or seeking professional repair.</span><br style="font-style: italic;" /><br /><span>Instructions</span><br /><br /><span>Device Turning On</span><br /> <ol> <li> <span style="font-style: italic;">Check that the AC adapter is connected properly. One end should be plugged into the laptop and the other end should be plugged into a working AC outlet. If the adapter is disconnected at either end, connect it.</span></li> <li style="font-style: italic;"> Disconnect any device connected to the laptop's USB port or ExpressCard slot. A malfunctioning device may cause the laptop to malfunction and not turn on.</li> <li style="font-style: italic;"> Press the "Fn" and "F8" at the same time to turn off "Concealed Mode." This mode disables the power functions of the device.</li></ol><span>"Remove disks or other media. Press any key to restart" Error Message</span><br /> <ol> <li><span style="font-style: italic;"> Remove the floppy disk or CD-ROM from the device and press any key. This message indicates that the disk does not contain system startup information and cannot run on the device.</span></li> <li><span style="font-style: italic;">Disconnect any device connected to the laptop's USB port or ExpressCard slot as problems with these device's may also cause this message to appear.</span></li> <li><span style="font-style: italic;"> Contact Panasonic Technical Support if this problem persists after attempting Steps 1 and 2 as this may be a sign of a problem with the laptop's hard disk and it may need repairing or replacing.</span></li></ol><span> No Display/Screen is Blank</span><br /> <ol> <li style="font-style: italic;"> Press the "Fn" and "F3" keys simultaneously to switch to "Internal Display" mode as the device may have been set on "External Display."</li> <li style="font-style: italic;">Check if the device is in "Power-Saving" or "Sleep" mode by pressing any key on the keyboard. The screen should come on if the device was simply in "Power Saving" or "Sleep" mode.</li> <li><span style="font-style: italic;"> Turn on the display screen or monitor of the connected device if you have the laptop set on "External Display" and want the display to come up on that device.</span><br /></li></ol><span style="font-style: italic;"><span>Hopefully this can help<br /><br />regards<br />multilinkent</span></span><span><span><span style="text-decoration: underline;"><span style="font-style: italic;"><span style="font-weight: bold;"><br /></span></span></span></span></span>
on Jul 08, 2011 | Computers & Internet
The display has "*" blinking
You can get out of programming mode by pressing f [P/R] or simply turning the calculator off and on again. The blinking asterisk is the low battery indicator. You probably still have at least a week of normal usage left, but you should replace the batteries soon.
Jul 25, 2011 | HP 12c Calculator
I am very happy with my new smeg oven but no where in the oven manual does it say how to cook puff pastry for example a pie. I have a wall built in oven and have tried turbo and static function
Hello blachett989,
I belive they refer to puf pastry as Fruit Tarts under the sweeties label in the owners manual. As I do not know what model number oven you have I have looked at a few of the owners manuals on line. It states the different types of modes and temperature and approximate cook time for the pastry or tart as they refer to it.
Thank you for choosing FixYa.com if you have anymore questions about this unit I will need a model number to help furthure.
Justin
Mar 10, 2011 | Ovens
Code 82265
  • Turn off the printer. Turn on the printer.
  • As soon as you see XEROX start moving across the display hold down the back and help buttons until you see "beginning service mode" on the display.
  • Release the buttons, it will now come up in the service mode.
  • Scroll down to the function menu, hit ok, scroll to clear isc fault, hit ok. Hit the back button to get back to the first menu then exit diagnostics, hit ok when it asks if you want to restart in customer mode.
Jan 25, 2011 | Xerox Phaser 7400/DXF Laser Printer
Error code: 09,038.46:13269
Solution:
Jan 25, 2010 | Xerox Phaser 8500/DN Printer
Phaser 8560mfp system error 09,038.46:12367
Solution:
Oct 16, 2009 | Xerox Phaser™ 8560MFP/D All-In-One Laser...
Error code 09.036.44:38950
09,03x 35 = Cyan 36 = Magenta 37 = Yellow 38 = Black The error indicates an ink stick was jammed. You have to clear the ISC (ink stick count) error. Turn off the printer. Turn on the printer. As soon as you see XEROX start moving across the display hold down the back and help buttons until you see "beginning service mode" on the display. Release the buttons, it will now come up in the service mode. Scroll down to the function menu, hit ok, scoll to clear isc faault, hit ok. Hit the back button to get back to the first menu then exit diagnostics, hit ok when it asks if you want to restart in customer mode.
Jun 07, 2009 | Xerox Phaser 8500DN Printer
User gets the above error on the actual printer " error 09.038.46:43938 "
Solution:
Mar 12, 2009 | Xerox Phaser 8500N Printer
Durabrand wd810
Page 12 of the WD810 manual states: XM OPERATION =SWITCHING TO XM MODE Press MOD button (6) shortly to select XM mode. =SELECTING CHANNEL UP/DOWN Press the TUN/TR>> button (17) or TUN/TRK<< button (16) to select the channel up or down. = SM MODE SELECTION Press LOC/XM button (2) to switch Category mode, Skip mode or normal. It is used as the selection of each: Normal >> Category mode >> Direct Tune >> When Category mode or Skip mode is engaged, the "CATEGORY" function is turned on in the display. When Category mode or Skip mode is released, the "CATEGORY" function is turned off. When Direct mode is engaged, "DIRECT" of alphanumeric display is turned on. How to direct tune (omitted)
Dec 28, 2006 | Durabrand WD810
118 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
