Question about Acer TravelMate 2300 Notebook
Cant leave laptop cause screen wont come back on
When i leave my laptop for about 5 minutes and then come back to it, it wont let me start it up again. I press space bar, move mouse and press power button for a few seconds but just a black screen. I know it is doing something because i hear sounds when email has arrived and power button is green. But screen just wont come back on. I have to shut down the computer. Does anyone know the answer to this? Its an acer TravelMate 4520.
  • 813 Answers
Have you checked the hibernation status / settings of your computer or stnadby mode
Posted on Jul 25, 2008
  • 304 Answers
Right click on the desktop and click on personalize in vista. Click on screen saver and set it to a more reasonable time like 120 minutes. From there you can also enter into the power settings and specify the system to prevent allowing hibernate and sleep mode.
In xp go to control panel and make the necessary similar changes. Just setting the screen saver to a reasonable time such as 180 minutes alone should solve this problem for you. If this helps you please take the time to rate it fixya.
George
    Brigadier General:
  • 6,966 Answers
It would seem that for some reason, the display would not activate again after going to standby. This would involve checking the inverter circuitry that powers the CCF lamps (backlight).
A possible temporary workaround is to disable/deactivate the "Turn off monitor" feature in your laptop's Power Scheme.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
  • Louie  Role
    Louie Role Jul 25, 2008
    Hi again,
    Further to your concern, you may want to check on any updates for your laptop's:
    bios;
    video driver;
    power management (including hibernation).
    In certain instances, it may be simpler to disable hibernation, Advance Power Management, and all other power saving schemes altogether and just use a screen saver.
  • Louie  Role
    All of the previous posting could be activated/deactivated by doing a right click on any free space of your desktop and clicking on "Display Properties" and clicking on the "Screen Saver" tab, Power button. Alternately, you can also go to your Control Panel, Power Options, Power Scheme tab. Select "Never" on the "Turn off Monitor" and in the Hibernation tab, uncheck "Enable hibernation".
    Cheers.
After a factory reset my screen is blank
IF IT IS A LAPTOP TAKE OUT THE BATTERY PACK TEMPORARY AND DISCONNECT THE POWER PLUG, WAIT 5 MINUTES. PLUG THE AC BACK IN BUT LEAVE THE LAPTOP BATTERY STILL OUT. MAKE SURE THAT THERE IS NOW CD OR DVD IN THE DRIVE. NOW TRY IT. WAIT AT LEAST 5 MINUTES AFTER YOU TURN IT BACK ON. IF THIS DOES NOT WORK ALSO DISCONNECT YOU INTERNAL BATTERY AND WAIT AGAIN AT LEAST 5 MINUTES THEN TURN IT ON THE ONLY THE AC PLUG IN. GOOD LUCK.
Oct 06, 2014 | Computers & Internet
Samsung rc520 wont start blue screen
Your Graphics Adapter may be out? Have you tried to boot to Safe Mode or a System Restore/Recovery? Have you done ANY updates? Remove ALL media, CD,DVD,USB, unplug, remove battery, leave battery out, plug in, reboot, Try this Win 7 procedure: http://www.sevenforums.com/tutorials/666-advanced-boot-options.html The other option is to re load Windows.
Mar 21, 2013 | Computers & Internet
Screen scrolls back to the top of the page
clean the keyboard i think some dust is there that is causing it
Feb 02, 2013 | HP Compaq Presario v4000 Notebook
My msi netbook wont turn on even though the battery charging indicator is lit.
1. Turn netebook OFF with button, hold 4 seconds.
2. Remove recharge plug
3. Remove battery
4. Leave it like this for about 5 minutes.
5. Put everything back and power the laptop again
Does it appear to charge the battery at all when plugged into AC? Can you hear the charger humming when you put the brick up to your ear? (while it's plugged into AC,You may have a bad motherboard
Dec 04, 2011 | MSI Wind U120-020US Netbook
Laptop fell and wont boot up properly
remove battery, remove power. wait 5 minutes
start up
get back to us plz
Jun 09, 2010 | Acer Aspire 3680 Laptop
I plugged for the first time my laptop on to the VGA input tv screen showed a sign that read something like: no signal, tv will turn off. then it switched off and now it wont turn on on the on/off switch...
There is a button on your laptop for switching from laptop screen to external screen, This button is usually in the top row of special function buttons, did you press that as it will tell your computer you are connected to another monitor. Also some times you have to leave the monitor off for about 5 minutes so it will reset itself.
Oct 09, 2009 | Televison & Video
Easynote r1004 wont power on
The battery is too low and the power supply can't charge the battery and also power the laptop at the same time.
Try this:
1. Remove the battery from the laptop
2. Plug in the power cord and turn ON the laptop.
3. It should work ok.
4. After the laptop is "stable" (what 5 minutes?), you can put the battery back into the laptop while it is ON.
5. Leave the laptop ON so the battery can get charged.
6. Lower / close the lid so that the screen will turn OFFand not take up power from recharging the battery.
If this doesn't work for you, try these steps again, maybe wait a few minutes between steps.
This WILL work!
Hope this helps!
Sep 03, 2009 | Toshiba A15-S1292 Notebook
It wont start up, push the power button and screen doesnt come on
Please plug also the power cord to the power source then wait for 10 - 20 minutes to charge the battery of your laptop then after the said time given above please turn on the laptop and see if your laptop is working now. Else if it is not then try to contact computer technician and let that person check the problem of your laptop Most of the problem causes of software and hardware.
Thanks
Aug 04, 2009 | Dell Latitude D505 Notebook
Golf 1.9 tdi wont start :-(
Sounds like you have a bad glow plug relay that could cause a power spike and drain your battery,it could also take away power to the fuel pump causing the loss of power.Hope this helps you out some!!
Jun 02, 2009 | 1996 Volkswagen Golf
Computers & Internet Logo
97 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
