DOES ANYONE HAVE THE INSTRUCTIONS MANUAL FOR THIS WATCH ?
SOURCE: Adidas watch
Troubles you to help the solution to look for adidas the adx156 instruction for use, thanks!
SOURCE: Instruction Manual for Fossil Watch
go to fossil .com and click on customer service that is where all manuals are hope this helps
SOURCE: Watch setting instructions
i had the same problem, follow this link it should help you
http://www.fossil.com/wcsstore/Fossil/images/en_US/customercare/digital_WorldTimeModule_Digital.pdf
SOURCE: Set time on Fossil DQ1138 Watch
Press and hold the SET button (it will read CHIME with a flashing on or off). Then push the MODE button - the top will be flashing 12-HR or 24-HR. Push the ST/SP button to toggle between the 12-HR to 24-HR reading. Push the MODE button to get to the hour/minute/second/year/mo-day/month/day value you want to change. Push the ST/SP button to increase the value, the RESET button to reduce the value.
SOURCE: No Manual. How do I set the time and other functions?
Go to http://www.fossil.com/en_US/shop/customer_care/static/fossil-Instructions.html and you will find a list of generic instructions in which you should be able to find a set that suit your watch.
