I set-up my wireless router (Belkin G Plus), I am attempting to secure it however, when I try neither the factory or the assigned IP Adress will take me to the Belkin site!
    Problem Solver:
  • 30 Answers
I have lost the security code and have a new laptop, how do i set it up to work
Hi!
If you don't remeber the wireless security code, maybe you still remeber the user and password to access the web management interface of the router.
Then you have to connect the laptop to the router by using a network cable. Open a browser window, type in the IP adress of your router and check the wireless setup section. There you can find / modify the wifi security code.
If you don't know the router's IP adress, then open on your computer a ms-dos prompt and type the command
ipconfig /all
it will display your current IP adress, subnet mask and GATEWAY. The gateway adress is the router's IP adress that must be typed into the browser.
If you don't remember the user and password for accessing the router's web interface, please refer to the router's user manual in order to reset it to factory default configuration, and then proceed as for the first installation of the router.
Hope it helped,
Bogdan
Aug 30, 2011 | Belkin (F5D8231-4) Wireless Router...
I can't connect to internet through wifi with belkin 54g but netgear works fine, it can't assign an ip address and i have it set to automatic configuration.
You can try to change channel on the router
Connect Belkin router with a Cable to the computer Open router router interface with its IP address Goto wireless settings and change Channel to 6 / 11 and apply settings You can also try to disable Wireless security to check if it connect without security Check for the latest firmware for your router and upgrade it.
Hope this help, Or you can ask for help
Jul 13, 2011 | Computers & Internet
My belkin N1 router when i plug it in it just flashes the security light and wont connect to the internet
You will need to double-check your security settings. Apparently, the modem is trying to tell you there's a problem regarding this.
The easiest way to be able to access the router settings in this case, will be to provide a direct connection between your PC and the Belkin router (using a network cable) and then type in that address.
If the address still doesn't work, double check the router's IP address by opening the Command Prompt (it's under Programs -> Accessories) and typing in "ipconfig", then hitting Enter. The IP-address you're looking for is listed under "default gateway".
(Also, make sure your computer isn't using a fixed IP, set it up so it's dynamically assigned an address by the Belkin router.)
Jan 20, 2011 | Belkin N1 Wireless-N Wireless Router
I have a Virgin Cable Broadband which I use with a
Log into your router via web browser (usually routers IP is 192.168.1.1). The default password is usually "admin" and leave the username blank, admin again. Another way to figure out what IP address is assigned to your router is to click START > RUN > Type CMD and hit enter. At command prompt type IPCONFIG. The DEFAULT GATEWAY is the IP address that is assigned to your router.
From main configuration page, click WIRELESS
Then click WIRELESS SECURITY
For security mode, choose WEP
Keep your default Transmit Key to (1) and set your encryption level to either 64 bits or 128 bits. (128 bits is more secure then 64 bit and much harder to crack.
Now you can either create a passphrase which will automatically generate key values or you can set your own key values. (You only have to set KEY 1)
Click SAVE SETTINGS
IMPORTANT Then write the key down so when ya wanna log on from wherever ya enter key and ya can enter.
Jan 26, 2010 | Belkin (F5D7230-4) Router (587009)
I need the ip adress for my belkin wireless g plus router
The default IP address for this router is 192.168.2.1
Hope this helps.
Jan 07, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Not able to connect with the router in... no ip adress bieng pulled up...
If you are not getting Ip address from the router to the computer then you can assign a static IP to the computer.
If it is a wireless computer then you try to disconnect from the wireless network and reconnect to the network.
Click here for more info
Oct 16, 2009 | Belkin (F5D8231-4) Wireless Router...
Subject: my ip adress
The Wireless Security might be enabled in your wireless network. Check the wireless settings of your wireless router (encryption or wireless MAC filter). If the wireless settings are correct, you may try to manually assign a static IP.
Jul 27, 2009 | Sony Playstation 3 (PS3) Console
Having problems connecting a lap top computer to the internet.
Connect the router directly via lan to your computer.
goto setup of the router: usuallly via the ip-adress of your router (see manual, usually: 192.168. ***.*)
Now look at the network security-settings .
May 11, 2009 | Belkin (F5D8231-4) Wireless Router...
Can't get to router setup page.
Have you attempted resetting the router?
There's a small hole in the back of the router. Find a paperclip, unravel it, then stick it into that hole. Once inserted and you know the paperclip has reached the end of the hole, press in. Hold it in for about 30 seconds and the router will be reset.
NOTE: Resetting the router restores it to factory default settings (most of the time). This means any settings you have changed since then will have been erased! Reset the router at your own discretion.
If resetting the router doesn't do the trick, let me know. I'll find some instructions for forcefully accessing the control panel.
Mar 22, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Open Questions:
Online Data Backup ' Offsite, Onsite & Cloud Backups 'Dataalign These days, not only businesses but individuals increasingly need access to their data on the go without thinking about storage and hardware maintenance costs. Online Cloud backup provides an efficient solution and is swiftly attaining popularity. Before cloud-computing, end users stored their personal data on computer's hard drives and memory cards. Unfortunately, computers and mobile phones require physical proximity to the device to allow access to the stored data and are far more vulnerable to damage and accidental deletion. Individual devices need diligent support and maintenance, and ensuring the security of the data remains a challenge. With, Server Cloud Backup Solution end users can upload documents, photos and videos to the cloud and then fetch them at their ease. This helps them save storage space on their computers and mobile devices. Furthermore, the cloud based structure allows end users to upgrade software more quickly - because software Cloud Backup publishing companies choose to offer Cloud Backup For Small Business web rather using traditional, tangible methods that involve discs or flash drives. Top software publishing companies have chosen to turn their business models to subscription based and they deliver their product offerings through cloud solutions. An online backup service isn't much capable if the process of restoring your data and getting back to being productive is not simple and quick. DataAlign offers a search tool to find a backed-up file. Also, the ability to replicate an entire folder-tree structure, helps with preventing bigger data losses. Versioning is another capability offered by DataAlign. This allows you to see earlier versions of a file in case you made Online Backup Pricing some undesired edits. This can also be termed as archiving function. You can set the number of versions and days you wish to keep any file and utilize the maximum available storage space. Using the version history, you can view the history of each file stored and undo mistakes, if required. Any accidental deletion of file from the computer and can be restored instantly as deleted files are backed up on the cloud. The moment the data is no longer required, you can setup a data destruction policy.
Apr 25, 2018 | Individual Computers & Internet
Cloud Backup, Data Recovery, Data Backup, Cloud Back up Solutions 'Dataalign These days, not only businesses but individuals increasingly need access to their data on the go without thinking about storage and hardware maintenance costs. Online Cloud backup provides an efficient solution and is swiftly attaining popularity. Before cloud-computing, end users stored their personal data on computer's hard drives and memory cards. Unfortunately, computers and mobile phones require physical proximity to the device to allow access to the stored data and are far more vulnerable to damage and accidental deletion. Individual devices need diligent support and maintenance, and ensuring the security of the data remains a challenge. With, Server Cloud Backup Solution end users can upload documents, photos and videos to the cloud and then fetch them at their ease. This helps them save storage space on their computers and mobile devices. Furthermore, the cloud based structure allows end users to upgrade software more quickly - because software Cloud Backup publishing companies choose to offer Cloud Backup For Small Business web rather using traditional, tangible methods that involve discs or flash drives. Top software publishing companies have chosen to turn their business models to subscription based and they deliver their product offerings through cloud solutions. An online backup service isn't much capable if the process of restoring your data and getting back to being productive is not simple and quick. DataAlign offers a search tool to find a backed-up file. Also, the ability to replicate an entire folder-tree structure, helps with preventing bigger data losses. Versioning is another capability offered by DataAlign. This allows you to see earlier versions of a file in case you made Online Backup Pricing some undesired edits. This can also be termed as archiving function. You can set the number of versions and days you wish to keep any file and utilize the maximum available storage space. Using the version history, you can view the history of each file stored and undo mistakes, if required. Any accidental deletion of file from the computer and can be restored instantly as deleted files are backed up on the cloud. The moment the data is no longer required, you can setup a data destruction policy.
Computers & Internet Logo
David Payne
David Payne
