Question about Samsung SCX 4521F All-In-One Laser Printer
Your reply - how do you do what yoiu suggested ?
U said "But the jamming, the roller marks, and other issues would indicate that the entire printer is probably needing to be cleaned out and that the rollers may even need to be reconditioned or replaced. " HOW do you that ? clean out entire machine .....
    Guru:
  • 1,049 Answers
Sorry, more specific instructions below...
Dusting: No matter how clean the rollers are if dust gets under the fuser it will burn, stink, and coat the rollers with black specs which will mar your copies. First remove all the panels and blow the thing out with compressed air. Where you have complex gear assemblies with no contact in or around paper a quick spray with WD-40 is good too.
  • The toner cartridge: Next remove from the toner from the printer and clean by moving a cloth or cotton swab from left to right across the glassy surface while turning the gear on the side manually.
  • The rollers: Next you need a product called rubber renew or something similar. Use it sparingly, it actually eats away at the rubber but also softens it and in small amounts will clean and make the rubber tacky again. This will stop slipping and jamming in most cases.
  • Run it out: Once you've cleaned everything either run the cleaning utility, or in the absence of that run a large wordy print job. This will pickup any remaining dust on the paper. If you have clean printing, great. If not repeat these steps a couple times.
If none of this works, you may have too much scoring on the fuser or cartridge to fix it. The toner cartridge is easy to replace, but the fuser is much harder and you will more then likely need the users manual to do it.
Posted on Jul 30, 2008
  • NA NA
    NA NA Jul 31, 2008
    Did this help?
P3005 jams
Post the exact error message indicated on the printer LCD. 13.01, 02 paper feed issues, worn rollers or jammed paper inside of paper feed assembly.13.05, 06 fusing assembly issues, broken sensor flag in fuser or worn busing on fusing rollers (fusing assembly will be noisy or making grinding sound.) If this the issue being noisy, the fusing assembly has to be replaced along with one of the drive gears, about a 30 min. of work.
Sep 30, 2011 | HP LaserJet P3005 Printer
Printer brother DCP330 Problem paper jamming
You may encounter a paper jam while working with your Brother printer. You need to be cautious while feeding the paper to your printer. Paper jams are often obvious, but you might come across a situation when you do not get any indication that the paper has jammed up the printer. In such cases, you need to open your printer and visually inspect it to search for the jammed paper. If the rollers of your printer are leaving marks on the printouts, then there is a need to clean them. Using chemical cleaners such as benzine, thinner, or alcohol to clean the rollers might prove hazardous to your printer.
Dec 22, 2010 | Brother DCP-330C All-In-One InkJet Printer
How to remove a paper jam brother printer
Get more information and help for Brother Carriage Jam .
Nov 29, 2010 | Brother DCP-9040CN Laser Printer
My laserjet 1020 develops a paper jam after printing the first page of a multipage print instruction .I have deleted the printer and re-installed it including all drivers but problem still...
Reinstalling the printer is related the Software.
If the paper gets physically jammed than its the driver setting issue or hardware issue.
Check if two sheets get jammed or only one sheet.
If it is two sheets than printer is picking up multiple sheets and paper gets jammed.
If the printer is jamming a single sheet than remove the Tray and look there is rubber roller inside if there are marks or lines on that rubber roller or if the roller roller is worn out than that rubber roller called as paper pickup roller need to be replaced.
If that looks fine than try to priny using manual feed and if the problem persists from manual feed too than try another toner cartridge
If the problem is not from Manual feed Tray that Replace the main Tray with known good Tray and check if the issue resolved.
Jul 01, 2009 | HP LaserJet 1010 Printer
Hp2200D Won't print - "jam" light comes on - but no jam
Have you cleaned the feed roller? If it's dirty it'll spin but won't pick up any paper. Look at the paper after a "jam." Can you see any black roller marks on it? That's a sure sign of a dirty roller. If you suspect a dirty roller, clean it with a little alcohol on a cloth.
Mar 10, 2009 | HP LaserJet 2200D Printer
Paper jam issues
make sure the entire system is dried out you may have a wet roller that is grabbing the paper and jamming it on you, its either that or your lubrication has washed off and gotten on the rollers.
Jan 09, 2009 | Xerox 8830 Copier
Jamming, roller lines and loud fan
You'll want to purchase the service manual for this printer if you do not already have one. Obviously the fan is the most annoying problem. But the jamming, the roller marks, and other issues would indicate that the entire printer is probably needing to be cleaned out and that the rollers may even need to be reconditioned or replaced.
Jul 23, 2008 | Samsung SCX 4521F All-In-One Laser Printer
HP cp1160 printer power light flashes indicating "the printer is busy"
The duplexer might not be seated properly in the printer causing the carriage to jam. See if you can reseat it.
Jun 14, 2008 | HP Color Inkjet cp1160 Printer
Toner marks down right side of page
hmmm...sounds like your toner cartridge is truly unhappy. I'd return it if I were you.
no worries..start by getting new driver for that here
Feb 28, 2008 | HP LaserJet 1320 Printer
Paper jam
Sounds like the pickup roller is worn or dirty. Try cleaning the pick up roller for the tray. If this doesn't work the pick up roller will need to be replaced.
Jan 14, 2008 | IBM Infoprint 1412 Laser Printer
Samsung SCX 4521F All-In-One Laser Printer Logo
136 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
