Question about Samsung SGH-D500 Cellular Phone
Screen my screen lights up but it's blank. I press the keys and it makes all the right sounds but cant see where I'at because it's blank. Please help me if you can...Thankyou..Regards S.R.Irwin Gold Coast, Australia
    Brigadier General:
  • 7,752 Answers
Replaced the lcd on the phone
Posted on Aug 31, 2008
How to make my fonts smaller
Quick answer - not specifically to change font size, but to change whole screen size
The whole screen size can be magnified (zoom in) by simultaneously pressing CNTRL + ; the reverse operation (zoom out - what you want I think) is performed by CNTRL - (press cntl and + keys simultaneously)
Or change (increase) the resolution of the screen by right clicking a blank a blank area of the desktop and selecting 'screen resolution' in Windows 7 or in XP one the tabs similarly labeled, and increasing resolution if not at max already.
12.February.2015
Feb 12, 2015 | Computers & Internet
Screen is blank. Sounds are still there. Lights on
Is the screen switched off? Try pressing the 'F' key with the screen icon.
Sep 13, 2014 | Computers & Internet
Viewpia 32" LCD TV goes blank, with sound still working
This is not the problem with a reset. It must be due to a problem to its back-light circuit. Contact any service technician.
May 15, 2013 | Televison & Video
Bkackbery reset codes
Here are some of the BB rest codes.
Soft ResetIf you can't sync your BlackBerry with your PC (device not detected), then you can make use of the following key combination to perform a soft reset:
  • Press the following keys simultaneously: ALT+DELETE+RIGHT SHIFT.
  • The screen will go blank and from there let the device start normally.
Hard Reset
  • You can use a hard reset when your applications/device are not working properly.
  • This is achieved using the same key combination as above:
    • ALT+DELETE+RIGHT SHIFT.
  • But this time you will have to use it twice.
  • On the first attempt the Blackberry screen will turn blank and will light up.
  • Upon this use the same key combination again (ALT+DELETE+RIGHT SHIFT.), you should get a blank screen followed by an hour glass.
  • Let the device boot normally and it should be OK.
Feb 25, 2013 | Cell Phones
Brother mfc-6490cw lcd screen shows no display (just the backlight is on)
Procedure1: Changing the LCD Contrast setting
  1. Press Menu.
  2. Press the Up or Down Arrow key to choose General Setup.
  3. Press OK. (For touchscreen models, skip this step.)
  4. Press the Up or Down Arrow key to choose LCD Settings.
  5. Press OK. (For touchscreen models, skip this step.)
  6. Choose LCD Contrast and then choose Light, Med, or Dark.
  7. Press OK. (For touchscreen models, skip this step.)
  8. Press Stop/Exit.
Procedure 2: Changing the Backlight Brightness setting
(This option may not appear depending on the model of your Brother machine.)
  1. Press Menu.
  6. Choose Backlight.
  7. Do one of the following (The menu varies on your model.):
    • Choose Light, Med, or Dark.
    • Press the Left Arrow key to make the backlight darker or press the Right Arrow key to make the backlight lighter.
  8. Press OK. (For touch screen models, skip this step.)
  9. Press Stop/Exit.
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
May 28, 2011 | Brother MFC 6490CW InkJet Printer
I have HP pavilion DV6500 laptop. Last night, system suddenly struck while working and now only power light is okay, and some blue lights also runs which shows sounds etc...DVD is working, but no sound of...
Please do not panic....The first thing what we need to do is perform a hard reset...What does Hard Reset mean... Unplug the A/C Adapter Pin from the notebook...Turn the notebook upside down and then remove the battery from the notebook...Turn the notebook in the upright position and then press the power button for 30 seconds without the battery and without the A/C Adapter Pin connected to the notebook... After 30 seconds place the battery in the battery outlet and connect the A/C Adapter pin and restart the notebook...Check if you can see anything on the screen....If you can't see anything on the screen then please perform a forced shutdown by pressing the power button down until all the lights have turned off...Then as soon as you restart the notebook press the F10 key continously on the keyboard...It will take you to the BIOS Screen... Check if you see the screen...If the screen is still blank then don't perform the next step....Click N for No...Then press the F9 key and then select Y as in Yes...again press the F10 Key then press Y and it will boot to the desktop.... still you have the same problem then perform a recovery....If the screen is blank in the BIOS Menu then try connecting an External Monitor...If you cannot see anything on the screen it is a problem with your video card or monitor you will have to contact HP since your fan does not work...If you have any other queries please don't hesitate to contact me and i will help you with the same.....
Aug 18, 2009 | HP Computers & Internet
Blank Screen problems
go ahead the workshop and figure out the problem ... this is common problem nowadays since not every n85 is good in quality so i think u was the unlucky who bought the low quality n-85 key un-sensitive is a very common problem with n-85 ..but not so serious..the black screen i think is ur ram overload or something... so the only way u can solve is go ahead the workshop
=D
Mar 15, 2009 | Nokia N85 Cellular Phone
On my screen it keeps saying Organizing call logs
Try to reset using the doing these firstly just the soft reset if that doesn't solve the issue complete all these steps.
Perform a soft reset by pressing the ALT+RIGHT SHIFT(CAP)+DELETE keys. The screen will go blank. When the screen is no longer black, press the ALT+RIGHT SHIFT(CAP)+DELETE keys again. You should then see another blank screen followed by an hour glass
Nov 19, 2008 | Cingular Wireless AT&T RIM BLACKBERRY BES...
My Nokia N70 cell phone Screen is white blank
formating your phone may fix the problem
Here’s how to hard reset or format your Nokia N70 mobile phone:
1) Switch off your phone
2) Press and hold these 3 keys together:
-green dial key
-the star key(*)
-the number 3 key (Ugh, I wish I had three hands…!!)
3) Power on the phone
Warning: Do not release the keys until you see a formatting screen and even after the phone has started. Wait until the initial sound starts to play and the hand animation is displayed.
Before formating make sure that your battery is fully charged. Copy all your important contacts, messages, calender, etc in your memory card and your phone should be fully charged window.google_render_ad();
Oct 21, 2008 | Nokia N70 Cellular Phone
Unlock apex tv model # AT2702
  • If you have a blank screen with a red key on the bottom left, simply press the (function or F) button and the mute button at the same time. This will unlock the screen and allow you to view the channel as desired.
  • If your TV asks for a 4-digit code or password please enter 3308 or 6688 to unlock the screen or reset any preset rating levels.
  • If you have a GT2011J or GT2011S Television, hold the (Display) button for 10 seconds, it will unlock the screen. If password or code is requested, try 3308 or 6688.
Hope that helps..........
Jul 20, 2008 | Apex Digital AT2702 27" TV
Samsung SGH-D500 Cellular Phone Logo
64 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
