Question about Mitsubishi VS-45603 45" Rear Projection Television
Tv guide instalation message on Mitsubishi vs-45603
I have the dreaded "installing tv guide data" message. nothing will work. any help would be greatly appreciated. We saved for a long time to buy this one on craigs list. Thank you
Steven
    Brigadier General:
  • 6,966 Answers
I am assuming you tried to "cancel" using the original remote and/or you are using a universal/replacement remote with no "Cancel" button/key.
in any case, are you using a cable box or a home theater with tuner? If yes, temporarily remove the cable connection from where its originally connected now and connect the incoming cable connector straight to the back of the Mitsubishi TV, allow the TV to go through its updating cycle, might take some time. Thereafter, power off and try again. If not fully done repeat the process or unplug from the mains for a couple of hours.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Jul 25, 2008
Hello I have a mitsubishi vs-45603 with what appears to be a convergence problem.
You may have bought bad chips or your soldering...
This is a common problem on many brands of Projection Tv sets. Its usually a convergence issue. You can get more details and a solution here on fixya using this link http://www.fixya.com/support/r11932741-convergence_repair_dull_video_repair
Mar 22, 2012 | Mitsubishi VS-45603 45" Rear Projection...
Mitsubishi VS-45603
You will need to go into the menu, setup, a/v connection, then make sure the locked to input is selected to no..
Good luck..
Sep 17, 2008 | Mitsubishi VS-45603 45" Rear Projection...
My tv is locked and i do not know the code
Devices: Mitsubishi VS-45603 45 in. Rear Projection TV (only)
I'm hoping your have a working original remote for this creature from 1998 (the dark ages of Analog).
The first thing to try to reset a stored "lock code" is to unplug the set and leave it unplugged until the code is lost (or reset to the default). How long will this be? Mitsubishi won't tell (see below).
Service Codes are for the use of qualified service technicians only. Damage resulting from the unauthorized use of Service Codes will not be covered under warranty.
Manufacturer: Mitsubishi
Model: VS-45603
TV type: Analog Rear Projection Television
Chassis: VZ5
Year of Manufacture: 1998
Option Menu Code: 1370
Circuit Adjust Code: 2357
Convergence Adjust Code: 2359<4><5><6>
Since Mitsubishi fails to provide online support for its own products (even Users Manuals are unavailable), its left to the consumer to discover how to use & maintain Mitsubishi Electronics Products. Accordingly, I've no way to provide guidance on how to use the above Service Codes, nor is assistance possible if something goes horribly awry during the course of experimenting with them.
Please post your results.
Dec 05, 2011 | Mitsubishi VS-45603 45" Rear Projection...
Mitsubishi VS-45603 had power outage and when it came back on it says TV is locked. How do I unlock it?
Go into the 'Menu' -> then 'Setup' -> then 'A/V Connections'.
You should see an option called 'Locked to Input' switch it to 'No' and your problem should be solved!
May 05, 2011 | Mitsubishi VS-45603 45" Rear Projection...
My TV cuts on, then right back off
This is a very common problem among Toshiba & Mitsubishi RP TV's. It is caused by the circuit boards not communication with each other. The fix is about $600-700 with labor, parts, etc. I would suggest getting an LCD or LED TV.
Nov 28, 2010 | Mitsubishi VS-45603 45" Rear Projection...
No picture or sound on Mitsubishi VS-45603
you may want to inspect it for a fluid leak. Look on the signal pcb first. look for any signs of liquid on the connectors. If the leak is found and has been there for awhile before it finally shorted out a connector then chances are that it corroded the pcb
Jan 09, 2009 | Mitsubishi VS-45603 45" Rear Projection...
VS-45603 we have power but nothing else will show up on screen.
I would suspect bad solder connections on the convergence IC's caused one to short out a blow one or more pico fuses, thus causing the set to go into shutdown so as to stop further damage to the set. The TV will need to be seen by a profesional to confirm or deny this.
Dec 17, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi vs45607 dead
Check for leaky D980 PART # 264P045040. You also can try to do a self test to get the error codes, search here or on ctechnicians.com
Jan 02, 2008 | Mitsubishi VS-45603 45" Rear Projection...
Only Picture in Picture Works...????
Its possible some of the surface mount capactors has failed on the pip board is so the unit will need to be replace or repaired.
Mar 18, 2007 | Mitsubishi VS-45603 45" Rear Projection...
Televison & Video Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
