Tv power wont stay on
Whenever i press the power button the tv turns on but immediately shuts off why is this happening?
  • 1 more comment
  • leele35 Jul 25, 2008
    same issue red light is lit and wont stay on magnavox smart series 36".
  • GOMLEDS Jul 25, 2008
    iDENTICAL ISSUE - TV power goes on, select channel, channel appears for literally 1 second and then goes blank.. At same time, the red indicator light goes into a continuous phase of flashing 3 times , pausing, flashing 3 times etc. Its almost like the set has gone into some form of hibernation mode - but nowhere does it say how to re-set this
    Irritating - only a cheap telly, but now basically useless due to this
  • poppaswife Aug 25, 2008
    same exact thing with my smart series
    Genius:
  • 1,139 Answers
Hello All,
The problem that is happening is due to the shutdown circuit activating, which is an indication of excessive current flow. This may indicate a problem in the High Voltage section or in the power supply feed from the HV section. In any case this problem is best dealt with by a trained professional. I would suggest that you take the TV to a qualified TV repair person and have them check it out.
I hope this helps
Thank you,
Shuttle83
Posted on Jul 25, 2008
Tv will not turn on i push power on button and blue lights click on an tv acts like it will come on but then tv shuts off and no picture appears
The blue light merely indicates power is getting to the TV. When you press the power on button, the defective power supply shuts the TV down immediately
Jan 06, 2013 | JVC LT42P789 42 in. LCD TV
Code number to program my bell remote to this tv
01768,11034,11265, 10178, and 11748.
Or you can:
1. Press "TV" button
2. Hold "P" (program button) till the "TV" button flashes once then twice
3. Enter 9 9 1, and the "TV" should flash twice
4. Aim the remote at the TV and hold the Power button down for at least 3 seconds. (Remote automatically goes to first code but it probably wont work so go on to step 5)
5. Press CH+ repeatedly till the TV shuts off and stop immediately!
6. Hold "P" for 2 seconds
7. Hold "Select" for 2 seconds
8. Hold "P" for 2 seconds
9. Hold Power for 2 seconds and TV should turn back on
Found at:http://wiki.answers.com/Q/What_is_the_universal_remote_code_for_a_haier_tv
Be sure to rate macapplezoo 100% or whatever you think I deserve!
May 29, 2011 | Haier HL32D1 32 in. TV
Sylvania 6432TD turns off within a second of turning it on
Had same problem Sylvania SRT2232s 32"had to keep powering on and off until it warmed up enough to finally stay on. Problem was the 100/50 & 1/50 filter cap took it to local repair total cost to fix was 74.52 works better than ever
Mar 06, 2010 | Sylvania SRT2232S 32" TV
Model CS- 40307 40 inch Mitsubishi TV will not turn on
continue to push power button until light turns green. verie rate of push and hold
Jul 15, 2009 | Mitsubishi WS-65819 TV
Garmin c330 gps will not turn on
try this just worked for mine
1.Under the face plate by the Garmin Logo.Use your thumbnail to remove the plate.
2.Press the reset button.
Information located on page 28 of the owners manual if you need a diagram.
Nov 14, 2008 | Garmin StreetPilot C330 GPS Receiver
Theatre View Toshiba Rear Projection TV 50 Inch with no sound or picture and a red light keeps blinking
I have the sames t.v you have to go in the back flip the power cord switch...then reboot the t.v.
Jun 27, 2008 | Televison & Video
Set won't stay on
hi im joe i have the same problem, but before this happened it turned the channel by its self and hade a mind of its own. to get it on unplug it. then as you plug it in repeatedly press the power button on the REMOTE. this will get it to turn on. if you get it on and some how get to control it then go into menu and put the fpd lock on. now you can only use the remote but at least it works. :)
Apr 06, 2008 | RCA 27V520T 27" TV
Assistant
is this electricity pocket plugged up to a timer ? or take the tv back to the shop... lost the receit just look for the same tv on computer
Feb 20, 2008 | Toshiba 28N33 28" TV
Assistant
check your sleep timer settings thats the most comman prob
Dec 18, 2007 | Philips 27PT81S 27" TV
Televison & Video Logo
289 people viewed this question
Top Televison & Video Experts
