Home | Canon | MV500i Mini DV Digital Camcorder | XP Pro wont rec...
Canon MV500i Mini DV Digital Camcorder
Problem for Canon MV500i Mini DV Digital Camcorder
XP Pro wont recognise my canon mv500i dv camera
By Kim1 - usenet poster
Hi there
Hope someone can help with. I'm connecting my new camera
using firewire through the firewire card that came with
the camera.
Xp recognised the card emeidietly and is happy with it. It
is a card that supports what i'm trying to do and i'm
pretty sure everything hardware at the pc end is fine.
I then connect my camera put it into play mode (vcr) and
switch on the puter. All my paperwork suggests XP will see
the new hardware and install the drivers. It does see the
hardware but can't install the driver. It says it cant
find a driver for this device. I beleive the driver I need
is a AVC driver, the camera is definatly compatable with
XP or so it says on the box. Cant find anything on Canon's
or Microsofts websites. Any one have any experiance of
trying to get this to run.
thanks
simon Robertson
Same Problem
Mar 23, 2009
-   ow do i connect my mv500i to my computer? i would like to load files from my camcorder onto moviemaker but i dont know hoe to connect the camcorer -   moumen
Mar 23, 2009
-   how do i connect my mv500 to my computer? i would like to load files from my camcorder onto moviemaker but i dont know hoe to connect the camcorer -   moumen
Dec 06, 2007
-   how do i connect my mv500i to my computer? i would like to load files from my camcorder onto moviemaker but i dont know hoe to connect the camcorer-   Lazz
Solution #1
posted on Jul 21, 2008
Not Rated)
chris1958
Rank: Apprentice
Rating: 0%, 0 votes
CAN ANYONE TELL ME WHERE I CAN DL THE DRIVERS PLEASE. i was just given the camcorder and i am running XP sp3 and have no idea on how to transfur movies from cam to comp. any help would be graeat thanks
Was this helpful?
Yes
No
Solution #2
posted on Aug 11, 2005
Not Rated)
Rachel007
Rank: Apprentice
Rating: 0%, 0 votes
This may do the trick, it worked for me: this is
from another newsgroup:
"I just had this problem and I found a way to fix it for
my Sony TRV-103. It found an av/c subunit and couldn't
install any further. To fix it you must rename two files
in c:\windows\inf. It's a hidden directory and you must
enable viewing of hidden directories in the "View" menu.
You need to rename msdv.inf.1 to msdv.inf and msdv.pnf.1
to msdv.pnf. Basically, you just delet the ".1". For some
reason Miscrosoft renamed these files so that XP can't
find the drivers. Once I did this it worked perfectly fine
and installed my camcorder."
Hope this helps!
Quincy
Was this helpful?
Yes
No
Solution #3
Not Rated)
Powe33
Rank: Apprentice
Rating: 0%, 0 votes
You are spot on my friend. There is a USB port for
transfer of still images off the memory card in the
camera, I think this was messing things up, even tho the
USB wasn't connected and had never been connected at that
time. I couldn't get the little monster to loose this
driver so eventually went for a clean XP Pro install and
the os spotted the camera first time. Thank god for having
2 hard drives so I could easily back-up importent data
before the install.
But thanks for your help and I'm glad to say my computer
and me are once again firm friends.
Simon Robertson
Was this helpful?
Yes
No
Solution #4
Not Rated)
pawa
Rank: Apprentice
Rating: 0%, 0 votes
Thanks for the advice, I actually got so fed up I did a
completly clean install of XP Pro and you'll never guess
what it found it first time and all is working splendedly..
cheers tho
scr
Was this helpful?
Yes
No
Solution #5
Not Rated)
Ranny
Rank: Apprentice
Rating: 0%, 0 votes
click on removeable e drive. xp. already has a veiwer in
it. then you move the file to a place where you want.
this might not work. just trying to help.
Was this helpful?
Yes
No
Solution #6
Not Rated)
2Pansy
Rank: Apprentice
Rating: 0%, 0 votes
Is it possible that the camera driver is loading properly
and you are seeing another AVC subunit on the camera
(possibly for still image support) that doesn't have a
driver loaded?
On their website there is a vague reference to storage
driver support on MacOS, which makes me think that this
device might have an extra AVC Subunit which would require
3rd party drivers. Lack of these drivers should not
prevent normal DV Tape Mode operation of this device in
WinXP or earlier releases of Windows (Win98SE and above).
**The storage driver is also compatible with Mac OS
10.0/10.1
MV500i
http://www.canon.com.au/produc ts/cameras/cameras_video/mv50
0i_specs.html
0i.html
To verify if your camera is enumerated in VCR or Tape mode:
Right click "My Computer"
Click "Manage"
Click "Device Manager" in the left window pane
*Look for "Imaging Devices" in the right window pane. This
is where the DV camera will be listed (in either VCR or
Camera mode) if it is enumerated properly.
If any other Subunits show up besides the one above, then
they are likely associated with some addition feature of
the device (Still image, storage, Tuner etc) which will
require drivers from the HW vendor. Standard DV camera
functionality should not be affected by lack of drivers
for these addition subunits.
Justin Robbins [MSFT]
- This posting is provided "AS IS" with no warranties, and
confers no rights.
Was this helpful?
Yes
No
Popular Solutions for Canon MV500i Mini DV Digital
Questions and Unsolved Problems for Canon MV500i Mini DV Digital
Do you recommend Canon MV500i Mini DV Digital Camcorder?
Answer
Answer
When attempting to load the cassette it will not load and keeps ejecting the tape. This has happened... (More)
Answer
the i movie recognises the canon mv500i imports for a few seconds then stops recording the canon... (More)
Answer
I have a canon mv500 and want to transfer video to pc. PC has no firewire port so I purchased a... (More)
Answer
i want to see all i take on camera on my computer
Answer
my problem was closed a cassette then camcorder told to EJECT EVERY TIMES
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Canon MV500i Mini DV Digital...:
Top Camcorder Experts
Rank: Guru Guru
Solutions: 721
Experience: More than 5 years attempt with printers, computers and all office equipment
Ask Me
Find more Camcorder Experts
Top Camera & Camcorder Repair
(214) 951-9731
Digital Camera repair and sales,trade,salvage.
Mikes digital camera repair
(915) 239-6199
CamerasAndParts.Com Specializes in the Service /...
CamerasAndParts.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
