Question about Acer Aspire 5610-4648 Notebook
Acer Aspire 5610 again
Hy i've already set my bootable device on my cd drive once i try to boot with any Xp it still dn't give me booting options or even it dn't run !!
NB my 5610Z is on vista
  • pshyko22 Jul 25, 2008
    I have also the same problem with my Dell Vostro 1400 which is on vista too
  • pshyko22 Jul 28, 2008
    No i want to install XP !!
    Genius:
  • 2,028 Answers
Are you trying to boot and run from CD or install XP?
Posted on Jul 25, 2008
Acer notebook will not boot, no cd drive to use boot up disc, wont start In safe mode any help please
use external cd/dvd drive via usb, boot from usb upon setting the bios, go to boot tab and place usb drive in the first boot priority
Apr 10, 2010 | Acer Aspire 3690-2196 Notebook
Acer aspire one 1640Z XP BIOS RECOVERY WON'T READ USB WITH BIOS
if I understood correctly you have the recovery software loaded on a stick flash drive and you want to boot from usb to restore the pc .....There are a few things that you have to know about to do that ...
first you have to go to bios and enable boot from another device ....other than hdd /cd or flopy ... for some elder bios this isnt even a choice ..or ..if it is ,,it will be as a sub options into the hdd...choice ..
another thing that you have to keep in mind ..is that you have to disable the other options to force it boot from this one ...or ....to press f8 on boot and manually choose the usm or the stick name that will appear on boot devices...
the most important thing is that if you already formatted the hdd it does notr have a usb driver loaded and that why willl not see the device ...also the device you are using to boot ...has to be specially formatted to be bootable ....this is made ussualy with a hp format tool ...and it is explained in more than one places on the net ...just look for making a boot-able stick (usb device)
in short ...make sure the sticvk is boot-able ...second the pc ha s teh capability to boot from another device ...and this is a feature that you already enabled like first boot device ...
than things will be easy ...it will ask you to press any key to boot from the usb ...and continue like an installation from the cd ...
if you cannot do it ...I recommend using a cd ..or an image that you will ***** in a virtual cd ...for those that do not have cd drive ( use daemon tool )
Dec 21, 2009 | Acer Aspire 1640Z Notebook
Acer aspire x3200 error reading "disk boot failure, insert system disk and press enter"
Check to make sure you don't have anything in your floppy drive. (3.5 drive or 5.25 if really old system).
If you can boot from bootable CD then probably your Hard Drive is not working and all other periferals are OK. If it is making clicking noises then the drive arm or the head is most likely shot and you need a new hard drive.
The one chance you do have is if your Hard Drive just needs to be made bootable again. Load up the XP cd as if you where to reinstall XP but instead goto the recovery console, type "fixmbr" at the command prompt once you have entered the XP logon, its very simple once you get there very well laid out.
Hope this helps. Best Regards,
Nov 09, 2009 | Acer Aspire X3200 PC Desktop
This Acer AST 160 I'm working on crashed...
Computer stops at verifying dmi pool data. Issue: Computer stops at verifying dmi pool data.
Cause: This issue can be caused by any of the below reasons.
  1. Corrupt boot files on the computer.
  2. Settings for hard disk drive are not correct.
  3. Floppy diskette or CD in computer causing issue.
  4. Boot devices not set properly.
  5. BIOS corrupt or misc. setting not set properly.
  6. Connections loose or disconnected.
  7. Bad Hard disk drive or other bad hardware.
Solution: Corrupt boot files on the computer
If the computer has no bootable files on the drive it is attempting to boot from it is possible that the computer may halt at " verifying dmi pool data..."
To resolve this issue:
  • Boot from a bootable floppy diskette. Ensure that this diskette was made on the same Microsoft Windows operating system that is installed on your computer.
  • Once at the A:> prompt type "sys c:" and press enter. This should report the message "File system transferred." Once transferred remove the diskette and reboot the computer.
If the computer continues to not boot attempt to re-create the master boot record by booting from the bootable floppy diskette again. Once at the A:> prompt type "fdisk /mbr" and press enter. This should return you to the prompt without giving you any message. Once at the prompt remove the diskette and reboot the computer.
Additional information about the "fdisk /mbr" command can be found on document CH000175.
Note: The above information only applies to Microsoft Windows users. If you are running a Linux / Unix variant or other operating system such as OS/2 and the computer is freezing at this DMI message ensure that Linux / Unix has been properly installed first and/or your boot manger is not corrupt.
The computer freezing at "Verifying dmi pool data..." may be caused when the hard disk drive settings within CMOS are not set properly. Enter CMOS and verify that the hard disk drive settings are set properly and/or that it is set to Auto Detect. Additional information about entering CMOS setup is found on document CH000192.
Verify no floppy diskette or CD is in the computer. In some cases the computer may be trying to boot from either of these drives causing issues with the boot sequence.
The computer stopping at " verifying dmi pool data..." can be caused when the boot devices on your computer are not set properly in CMOS. First, verify that no CD or diskette is in your computer. If a CD or diskette is in the computer attempt to remove this first to determine if it was attempting to boot from it.
If No CD or diskette is in the computer and your computer still halts at the DMI message enter CMOS setup (steps found on document CH000192) and verify that the boot options are set properly. We commonly recommend that the floppy be set the first boot device, hard drive as the second boot device and the CD-ROM as the third boot device.
If none of the above recommendations have resolved your issue
Sep 10, 2009 | Acer Aspire T160 (AST160UA3400) PC Desktop
How to install xp in dell 1545
Insert the xp install disc into drive "d" or whatever letter is assigned to the drive, restart your dell, if it doesn't boot from the cd, restart and press and hold down F2 while it boots(or F2 or F8 deoending on setup) until the boot options appear, select drive "d" as boot device and continue the restart.
Then when the options appear, select the choice you need, full install will allow you to format and partition your drive.
Sep 05, 2009 | Acer Aspire 5610-4648 Notebook
Reset bios without running hard disk first
2 options:
  1. create a bootable cd with the bios rom file, and a dos based flash utility (included with bios download). Boot to cd and flash.
  2. Connect a usb floppy drive and create bootable floppy. Copy rom file and flash utility to floppy, boot to floppy and flash......option 2 may be easier if you are not familiar with creating bootable cd's.......Let me know if this helps or not.
Jul 31, 2009 | Acer Aspire 5610-4648 Notebook
My acer aspire one says no bootable device
This sounds awful, but a friend just had the same problem - no bootable device. He had dropped it, hitting keyboard first. Now he thumped it on the opposite side and IT WORKED! Must have been a loose connector
Jun 03, 2009 | Acer Aspire 4315 Notebook
Aspire 5315, no bootable device, PXE-E61 media test failure,
With any standard laptop (your Aspire included) the default boot disk should be set to drive C:
If the system is not finding drive C:, the boot sector may be damage or the drive may have failed completely.
Depending on your operating system (probably Win XP for this one) you can make a boot disk on a friend's optical drive and change the boot sequence in the BIOS setup to your optical drive. Just make sure the disk you've made is compatible with the drive in your Aspire; such as CD - DVD+-, etc.
Once you can get some kind of prompt, either from a basic Desktop or just E:\ from your boot CD, try typing in "C:" (without the quotes) to see if it is accessible. If not, the drive may be bad.
If the drive is still readable, you have more work to do to restore the damaged boot sector.
Mar 21, 2009 | Acer Aspire 5315 Notebook
Acer Aspire E571, stuck on "ACER" screen
Have you tryed unplugging the HD and seeing if you can access the cmos?
Dec 06, 2008 | Acer Aspire 5610-4648 Notebook
Can't format 5610Z
If you can enter the bios, change the boot order in the bios, so that the CD drive boots before the hard drive.
Jul 16, 2008 | Acer Aspire 5610-4648 Notebook
Acer Aspire 5610-4648 Notebook Logo
82 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
