Question about Dell Inspiron 6000 Notebook
Won't Turn On
My laptop slipped out of my hands six inches off the floor and now will not turn on. When I press the power button, the power light blinks as long as I'm pressing the button. At the same time the laptop makes no sound and seems practically dead.
I've removed the battery, hard drive, and RAM and then put the parts back which worked once. I tried it again after shutting my laptop off and now will not turn on at all. I repeated the steps and nothing has changed. I tried turning on the laptop without the battery and only plugged in with the AC and this doesn't work either.
Any ideas?  Thanks in advance.
Im having the same problem.
i've heard that replacing the dc jack fixes it.
i currently have my lappy sitting in front of me in 100 parts.
im going to radioshack tomorrow to get a dc jack. im also going to get a new power adapter and battery just in case.
if it doesnt work than new computer for me...
Posted on Aug 10, 2008
    Scholar:
  • 162 Answers
Unfortunately, it sounds like the board cracked. But if holding the button down illuminates it, then maybe all is not lost. Did the unit hit the floor sideways?
Posted on Jul 25, 2008
My Asus X553M laptop is not booting up. Any ideas how to fix this problem?
Temitope, Hard reset. Open computer, remove battery,hold power button down (((1 minute))), reinsert battery, reassemble laptop, push/hold power button a couple seconds.
2nd fix, try to boot laptop without hdd.(hard drive). Remove the hdd, then turn on the laptop.. then it can get into the bios.. reset the bios to the default setting, turn off the laptop, and then turn it on again with hdd reinstalled. This seems to be what works in the forums with this issue found in Asus laptops. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Asus Laptop unable to boot black screen no bios
How to Fix Laptop that Won Turn On Asus X551M
Laptop Won Turn on Fix How to Hard Reset Laptop
Asus laptop not booting
Aug 21, 2016 | ASUS Computers & Internet
Simply won't turn on. All the power at the plug has current but nothing when you push the on button.
Gary, Could be power supply failure. Links below for trouble shooting your problem.
How To Fix Laptop That Won Turn On
Laptop not powering up won turn on Fix Solutions
My laptop won turn on when push the power button
Here What to Do When Your Computer Doesn Turn On
Feb 26, 2016 | Computers & Internet
My laptop won't turn on
check the battery and adapter first do they have a light on adapter?
2nd press F8 and power button at same time
does SAFE mode show on the screen?
May 25, 2012 | Fujitsu LifeBook Notebook
Laptop Fan and Power Indicator won't turn off.
Are you sure you are turning it off completely. Sounds like you have it sleeping or hibernating. Press and hold the power button for 15 seconds or so, it should power off completely.
Mar 29, 2012 | Computers & Internet
My dell vostro 2510 won't power on, when i press power button to turn on the pc , the power light turn on for about 5 sec then it turn off itself,
Try this to see if can give us some codes with it's on board diagnostics. Hold down the function button of your laptop and then the power button while still holding down the Fn/Function button on the left side of the keyboard. See if this gives you either an error message on your screen or, flashing lights above your keyboard. Pay attention, write down what lights where lit up what ones flashed, etc. This is to diagnose if the LCD isn't working. Comment back if you get either the light code or the error code on the screen. IF nothing happens try holding the Fn/Function button on the left side of keyboard and holding the F4 button, see if that makes any lights flash above your keyboard.
Jun 18, 2011 | Dell Vostro 2510 Laptop
My Dish 5.0 IR remote won't program to my new TV, it's an Emerson, the model number on the back is- LC320EMXF. I've tried holding the TV button until all the top lights flashed and then...
lrsnihe
You were attempting to perform a power scan initially. The second procedure is manually attempting to address the remote to your TV. I will give you the procedures again so you can try one more time. Emerson TV is one brand we have a low percentage of success getting our remotes to work. If it still doesn't work, we could try replacing the remote.
TV code: 623, 667, 666, 233, 516, 537, 544, 642, 655, 699, 000, 999, 888, and 720.
Remotes: Basic (Television Only)
  1. Turn the Television On.
  2. Press and hold the clear TV button for six seconds until the LED flashes.
  3. Enter the three-digit code using the buttons on the number pad.
  4. Press #. Note: The LED will flash three times.
  5. Test functionality with the TV.
  6. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
Remote Power Scan: Basic Remote (Television Only)
  3. Press and release the red TV Power button.
  4. Press and release the Up or Down Arrow on the remote until the television turns off once every second.
  5. After the television turns off, press and release the # button.
  6. Test functionality with the TV.
  7. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
Jun 12, 2011 | DISH Network IR Remote Control
My charger broke like six months ago and I never bought a new one. When I charged it my computer didnt want to turn on. all it does when I push the power button it turns green along with the power symbol...
  • Turn on laptop.
  • Laptop will be start booting. Red/yellow light will be blinking. If yes then check your monitor light will be fixing and Show *********** Board.
  • If shows and your OS will be Booting and fail to start.
  • If yes you can repair it.
  • Insert OS disk into the DVD driver.
  • Turn off PC.
  • Turn on
  • "Press any key........" when comes this message you press any key.
  • After that you can see two option
?? Fresh copy Installation OR
?? Repair Option
  • For Repair Press "R"
  • It will be start repairing
May 16, 2011 | Dell Inspiron 6000 Notebook
My inspirion 6400 does not start.
you just have to press power button once and then remove your hand , you should not wait for it to power on , just press once and remove your hand , it will automatically power on , if you keep on pressing power button and as soon you remove your hand it wil turn off the computer.
Jul 15, 2010 | Dell Inspiron 6400 Notebook
Dell Inspiron 6000 Notebook Logo
255 people viewed this question
Alun Cox
