Question about HP Officejet 7210 All-In-One InkJet Printer
When trying to scan, 7210 doesn't see/recognize networked computers
BACKGROUND: The 7210 is on the same network as multiple computers, all of which are running Windows XP and all of which can print to the device. I just downloaded the mamma-jamma 450MB full feature device driver for networked connection directly from HP's web site, and the install seemed to go fine.
PROBLEM: When I try to scan, the LCD screen says "Select Computer" with a little right arrow. But pressing the right arrow doesn't do anything, and when I click the "OK" button it says "No scan options" and tells me I need to install device software.
Any suggestions?
  • gregbarr23 Jul 25, 2008
    Thanks. This is maddening, though, I can't find HP Director on my computer (no icon, not in start menu, not even in the "HP" directory under Program files) and can't find a way to download it. Seems like it's supposedly part of the driver package, but I downloaded/installed the driver earlier today yet HP Director is not on my system. When I installed the drivers it went through exactly the process documented at including the affirmative recognition of my 7210.
    Any ideas on how to get HP Directory on my system? Now that you turned me on to that I see all kinds of problems you can fix once you take the first critical step of "Click the HP Director icon..." GAAHH!!!
  • 162 Answers
From each computer, you need to run the HP Director. When opened, click on SETTINGS, then SCAN TO settings to configure. This way it will transfer data to the scanner so that when at the scanner, that computer will be in the list of places to send a scan job.
Posted on Jul 25, 2008
  • Gary Luis
    Gary Luis Jul 25, 2008
    You may need to download the HP patch which is on the same page entitled: CRITICAL UPDATE TO RESOLVE AN ISSUE WITH HP DIRECTOR AFTER INSTALLING IE7.
    You can get it here:
    But you should have an HP folder when you click START, PROGRAMS, HP. The fact that this folder is missing means the program didn't load properly.
    The size of the file you need is over 450mb (496mb) so you may have downloaded the wrong file. But if you have IE7 on that machine, the above file may solve your problem. I had that issue one time but I had HP Director on my desktop, just wouldn't launch until I installed the patch. The fact that you don't even have the icon is troubling. Before doing anything else, uninstall the current HP drivers, reboot and try reinstalling. Make sure any firewalls are turned off. You can check by clicking START, SETTINGS, CONTROL PANEL, SECURITY CENTER. If Firewall is enabled, click near the bottom where is says WINDOWS FIREWALL, and click on OFF, click OK to exit the screen.
Network adapter
May 31, 2013 | Dell (E210882) Motherboard
Code error
If the Nokia 7210 says Code error means you entered the wrong code,It's Network Unlock code or security Unlock code?Network unlock code means you can have only 5 Unlocking tries ,if you missed means it get hard locked ,so cannot unlock using the unlock code,get the correct Unlock code from the site and Unlock from Network lock,You need to unlock from security or password lock means get the master reset code for Nokia 7210 at here and reset it.You can also try default code 12345 or 1234 or 0000 if not works means get the master reset code and reset it.
Dec 12, 2011 | Nokia 7210
Can i share scanner across multiple computers?
Some network scanners have the ability to scan to PC's. I have the Brother MFC-465CN all-in-one ethernet network printer. This scanner lets me press scan and decide which PC to send the scanned image to.
If it is a USB scanner then I don't think this is possible.
Oct 28, 2009 | Nikon COOLSCAN 5000 ED Film Scanner
Need connect HP Officejet 7210 printer into wifi domestic network
Check your drivers at Driver Detective
If your computer does not recognize the printer, try going into your printers in the control panel and go to add printer and see if it finds it.
May 20, 2009 | HP Officejet 7210 All-In-One InkJet...
Can't scan with mfc-7840 w, has worked fine for months, on laptop with xp, was working in another office for last 10days, came back to home office and it can't recognize device at all I can ping IP no...
I had a similar problem. I was able to print and scan for months and then all of a sudden could not scan anymore (from printer or through software interface). I then found out that the IP address for the scanner was not set properly. To fix this, goto control panel and scanner and cameras. Right click on the MFC7840W and select PROPERTIES. On the network setting tab, make sure that the IP address is the same as that on the MFC7840W.
Mar 31, 2009 | Brother MFC 7840W Printer
Scanner not recognizing software
I also have the same error and same 2015 printer in addition to my 7210.
Anyone figure this out? HP tech level 2 support cant figure it out.
May 23, 2008 | Office Equipment & Supplies
Computer doesn't recognize usb device...
do not use Front usb connector. put your device in backside of CPU usb port. it wil work fine.
Mar 05, 2008 | Belkin BLKF5U201 USB Peripheral...
Network Interface
test the printer network cable for connectivity,but if the network interface fails u can use other ports like the usb port with the usb network interface adaptor to connect to the network once uve confirmed that the RJ45 network interface is bad
Dec 24, 2007 | HP Officejet 7210 All-In-One InkJet...
HP Officejet 7210 All-In-One InkJet Printer Logo
1,288 people viewed this question
Ben Johnson
