HP LaserJet IIp plus Printer Logo
velin velikov Posted on Jul 25, 2008
HP LJ II P plus
My printer (HP LJ II P plus) did not functio.
Error 51 appears on the display.
After several on/off the power boton printer to work, but it gives error 51 again sometimes.
velin velikov
Level 1:
Problem Solver:
  • Contributor 4 Answers
  • Posted on Jul 25, 2008
velin velikov
Contributor
Level 1:
Problem Solver:
Answers
Questions
8
Helped
949
Points
5
The laser PCA is bad.
I removed it and the printer functioned.
I thank you really after all.
1helpful
2answers
Hp lj 2300 55.40 error shown on display
55.4 is Communication timeout. It is about communication between electronic components inside and indicates bad or broken connection. Are you sure there is zero after the 4?
I have an envelope feeder that came with my old LaserJet 4 many years ago. I replaced the LJ 4 with an LJ 4-Plus and tried to use the envelope feeder on it. I get an immediate error message "EE...
My suspiction is there is a tab on the tray that triggers a switch telling the printer what type of tray has been inserted. Your old tray is likely different from the Plus 4 tray and the printer knows it.
2helpful
2answers
My 2600 laser printer have 55.1 error message its not working.
DC Controller error.
Turn printer off for 60 seconds. If it's plugged into a surge protector, plug the printer into a wall outlet. Power it on. If it works - good. If not check the firmware version and upgrade it if needed. Other wise replace the DC Controller.
1helpful
Error 51 HP 4Plus laserjet printer just stopped and error 51 appeared cartridge replaced replaced repair kit
Hello sir; 51 often in this model, change laser assembly( C2037-69008 ). next tryDC controller ( C2037-69004 ).
Hp LJ 4 + will not load the first page from the drawer or (s)
remove the cassette and toner. turn the printer upside down and look for broken parts stuck in the silver covered guide.
17helpful
3answers
Error code i hp 4255 officejet printer
have problem in my printer hp officejet 4255 oll-in-one it give message ERROR : 0XF0aF8005 pleas help me I can repair the priter if u can diagnose the error code
3helpful
6answers
HP Laserjet 1320n Error Lights not in Manual SPAM LOSERS CAN BE FOUND AT 1*800*532*4187
hi friends......
shivachadra is here.....just i faced this problem "Attention, Ready, and GO LEDs are on solid"
and i got solution in troubleshooting....just vi refixe the connetion of laser scanner........its the error of comunication between laser scanner and formatter....
4answers
HP 2430tn lj printer with 13.20 jam inside top cover error
What is the exact error message shown on the display ?
Does it makes any strange noise when you start it up ?
Hp 9500hdn has error 8388D4 EIO devise 3 disk not funtional
Try the following steps to reinitialize the HDD:
1 Turn the printer off.
2 Turn the printer on.
3 Press and hold PAUSE/RESUME (LJ 9500) or START (LJ 9500mfp) on the control panel during the
memory count.
4 Hold PAUSE/RESUME (LJ 9500) or START (LJ 9500mfp) down until all three error lights illuminate
steadily.
5 Press (the 5 button on the MFP) until INITIALIZE DISKS appears on the display panel.
6 Press (the 6 button on the MFP).
7 The printer begins initializing the disk (this might take a moment). The control panel displays the
HP event logo and eventually displays READY.
k24674
Grand Canyon Tech
Grand Canyon Tech
