Glen,
We should be able to help you with your wiring issue but I will need one other piece of information off of the motor nameplate; the date code/derial number of manufacturers number. Depending on when it was made it will have one of these numbers which in turn identifies the age and therefore how it was connected at the factory. Once you have that information, or even better, send EVERYTHING on the nameplate either in an email or picture to:
[email protected]
It may take a little time to get the record from the tech department but we should get it.
Thanks,
John
Arrow Motor & Pump, Inc.
Hi Valeantudor. Looked at site you sent me. Only it didn't show how to connect the Capacitors, The 2 running Capacitors
Hi, I need the wiring diagram that shows how the wire connection are made for the capacitors. There is 2 running caps, & 4 starter caps. The diagram that was on the site you sent didn't show this information. Glen
Hi, I got the info that was provided. But it does show how to hook up or wire the capacitors. As I said before. There is 2 Running capacitors & 4 Starting capicators. There is 4 leads that go to capacitors from motor.The drawing just show 2 capacitor. Are they series or parallel or series /parallel connection. Please let me know as I need to get the motor running. Glen
