QuickStart CATIA V5 Full Version  Logo
Posted on Feb 16, 2011
Click OK to terminate comes while opening catia , when further going with OK gives "Insert VBA(38216) disk and click OK" what is the solution to this problem
Catia v5R16 shows "no warm
Mr. raulii,
As catia is the software for drawing, & big in size,....
so i want to suggest you to uninstall the same & install again in safe mode...
By the way you can start safe mode by pressing F8 button at start up....
Thanks,
Dhiren Motivaras
08530903006
4helpful
I PURCHASE 4GB MEMORY CARD AND INSERTED IN NOKIA 6303 CLASSIC MOBILE, FEW DAYS AFTER MEMORY CARD FAILED AND NOT ABLE TO OPEN, WHEN IAM TRYING TO OPEN IT DISPLAYS "MEMORY CARD NOT FORMATTED...
1. Insert the memory card in a card reader.
2. Connect it to a PC or a laptop.
3. Go to My Computer > Removable Disk
4. Right click on the Removable Disk icon and click on format.
5. This shall format your memory card.
6. Run an anti-virus scan on it in order to fix any possible bugs.
1helpful
The instruction at "0x77d4bbcd"referenced memory at "0x00000048".the memory could not be "read" click on OK to terminate the program click on CANCEL to debug the program
This error comes when there is issue with harddisk clusters.
First open cpu cabinet and find motherbord.
Refix RAM memory.
Then boot computer with windows disk or recovery disk.
For that when you power up the computer press F1 or F2 or "del" key to enter in bios screen.
Then go to boot option and set first boot device as your cd/dvd rom .
Then save settings and exit.
Then insert disk in cd/dvd rom .
Then it boot with that disk.
Then follow the procedure and enter in recovery console mode.Then type in prompt "chkdsk /r"
then press "y"
Then it fix error on harddisk.
Then check.
If still same error then you have to repair your widnwos.Follow the above procedure again and this time choose "R" option for repair previous windows.
Let me know if you need more assistance.Thanks.
VBA not working in all Office products
There is setting for VBA in office 2007.
Go to Excel options-->Trust center--> trust center setting and configure the required settings
2answers
Macro on excel
Macros are a timesaving feature that allow you to record a sequence of actions that you do in excel, and replay them back later.
You give each macro a name, and you can invoke them later, and Excel will "do" whatever it is you did when you recorded the macro.
To record a new macro:
1) Open Excel
2) Go to Tools->Macros->Record New Macro...
3) Type in a name for your macro and hit OK
(A new toolbar will popup with a "stop" button on it. Excel is now recording everything you do)
4) Do something, like, for example, select some cells and make them bold.
5) Click the "stop" button.
Now your macro has been recorded! You can play it back later by:
1) Open Excel
2) Go to Tools->Macros->Macros...
3) Select your macro from the list
4) Click "Run"
The actions you performed earlier will now be executed.
Macros are written in Visual Basic for Applications, or "VBA". It is a programming language which uses the Excel Object Model to perform various actions. You can edit and create custom macros by writing the code manually in VBA. To do this:
1) Open Excel
2) Go to tools->macros->macros...
3) Select an already existing macro
4) Click "Edit"
(The visual basic editor will open, showing you the code for your macro)
At this point you are writing a program in Visual Basic. To learn how to edit macros, you need to learn visual basic, as well as the specific quirks related to excel macros in visual basic.
Recording a macro, and then using it as a template while you edit it is a common trick for making macros manually more quickly.
If you are not familiar with VB, I would not suggest attempting to edit your macros in any but the most simplest of ways. If you're brave, you can try to learn about editing macros in VBA here:
http://www.anthony-vba.kefra.com/
Top QuickStart Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a QuickStart Computer and Internet Expert? Answer questions, earn points and help others
