Question about GE A730 Digital Camera
Lens error i have a ge a730 camera and it was working fine then it started saying lens error then turning off on its on now i tried the solution about the hair dryer and blowing into it to take out sand or other particals but that doesnt work can someone plz help me cause i have no idea wat to do!!!
  • 446 Answers
You need to send this to a repair shop, for immediate cleaning, sand can practically stucked in betweeen mechanical parts and cause binding
Posted on Aug 11, 2008
Just says lens error and wont stop making grinding noise
Try one of these two fixes, if they dont work for you follow the link below for further troubleshooting.
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: If the camera's batteries ran down completely while the its lens was still open, the camera may show a lens error or not start properly when new batteries are installed. Remove the memory card and keep it removed, then install the new batteries. When you turn the camera on with the card removed it may come back to life, as this triggers a reset in some cameras. Error E30 (for older Canon's) means that you don't have a memory card installed, so turn it off, slip in the SD card and turn it on one last time
Jun 16, 2010 | GE A730 Digital Camera
Ge w1200 new when turned on reads lens error will not respond
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try:
Apr 11, 2010 | GE A730 Digital Camera
LENS ERROR
This is probably THE single most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jul 03, 2009 | GE A730 Digital Camera
Lens error keeps coming up and the lens won't go in...it is a GE A730.....can anyone tell me how to fix this......
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jun 30, 2009 | GE A730 Digital Camera
GE A730 LENS ERROR
Hi sadloserx:
I am inserting this from a previous post, since this seems to be the same problem.
Also lens problems have to be described in full to see what is wrong. The following will give you some idea as to what I am saying.
This camera is telling you that there is a problem with the lens, either in the tracking, mechanical, or electrical circuit.
Try this: If the lens extends at all... then pull on the lens or push in to try to reset the tracking of the lens.
If the lens does not extend at all and makes noise, then it has problems in the lens gearing or motor.
If the lens makes no noise at all and you get the error with the shut down, then more than likely there is nothing that can be done.
Try this at your own risk:
With the camera off, gently hit the camera on a padded (folded towel) cloth on a solid surface, using one of the corners. This may jar the internal parts enough to make the camera work again.
BY doing this, you do risk damaging the camera beyond repair, however, if you have a camera not working anyway, it may be worth it.
I have fixed two cameras in the past this way. However, nothing is guaranteed.
Finally:
Find a repair shop and have it fixed. (These kinds of repairs can cost $150.00 or more). That will depend on your value and the age as well of the camera.
Sell it as is or for parts on a site such as Ebay.
Sep 25, 2008 | GE A730 Digital Camera
I HAVE A PRAKTICA LUXMEDIA 7303 AND AN ERROR MESSAGE KEEPS COMING UP SAYING LENS ERROR 21
HAVE A PRAKTICA LUXMEDIA 7303 AND AN ERROR MESSAGE KEEPS COMING UP SAYING LENS ERROR 12 and 27
Aug 24, 2008 | GE A730 Digital Camera
Lens error
It is defective. Call 800 730 6597 and we will replace it if it is still in warranty.
Trevor Gordon
Senior Customer Tech
General Imaging Company
(Exclusive GE Digital Camera Licensee)
Jul 01, 2008 | GE A730 Digital Camera
My ge a730 digital camera
Try this...Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Jun 18, 2008 | GE A730 Digital Camera
Lens error
I had the same problem - here's what worked for me....
Mar 13, 2008 | GE A730 Digital Camera
GE A730 Digital Camera Logo
60 people viewed this question
Top GE Cameras Experts
sonic boom...
sonic boom...
Are you a GE Camera Expert? Answer questions, earn points and help others
