Question about Ventamatic Direct Drive Whole House Fan With Univer
Shutters closing while running
The shutters barely open on low speed.. They open most of the time on high speed but after awhile they close even though the fan seems to still be running. Thanks
    Problem Solver:
  • 10 Answers
The shutters should be gravity closed, which means they are counter weighted just enough to close with no air flow...  when the fan starts, it will create a slight pressure differential across the shutters - when that pressure overcomes the counter weight, the shutters should open...  I assume you open windows and/or doors when the fan runs...
I would check for the following items: a) (unlikely) check to see if the counter weight is adjustable, if so, it may be slipping and needs reset.. I think this is unlikely as I think most shutters do not have adjustable counter weights -- check last)
b) check your attic vents to the outside -- the air being blown into the attic must escape to the outside world, otherwise it will build up pressure and the airflow will drop or stop altogether -- this sounds like what is occurring, at slow speeds, there is insufficient airflow to open the dampers, at high speeds, they open long enough for the pressure to build up and then they close as the air flow diminishes
c)  have you replaced windows, caulked up windows, made any modifications to reduce the flow of air into the living areas -- air must enter the house just as air must leave the attic (assumes you don't open windows or doors)
d)  if you have a fireplace, check to make sure some animal or other hasn't plugged up the chimney -- if the house is tight, the attic fan will pull air from the chimney unless it is blocked
hope this helps...
Posted on Jul 27, 2008
I recently brought a nikon fm2a and a fm2t. When I fire both shutter at the same time with 1 sec shutter speed.The fm2t has a slight delay in closing the shutter compare to the fm3a. To my knowledge, both...
All shutters do have a certain tolerance. Because you don't say anything about the real time the shutter is open, It is impossible to tell what camera has a "correct" shutter time. Or if they both are of. I used to calibrate my camera's, because most of the time the next time is exact twice or half of the former time on the dial. Even with the band new cameras in the past, I shot one or two rolls, to check if my settings were correct. Never had any trouble with shutter times, because I never checked how long the were open.
Jan 31, 2014 | Photography
Won't stay on
i could be that the rechargeable batter is weak. try replaceing the battery for a new one. also check that the connections for the battery are clearn.
I hope this was useful.
Feb 15, 2013 | Sony Cyber-Shot DSC-P52 Digital Camera
How to set carb and idle on poulan pro chainsaw 4218avx
I took carb out changed hoses cleaned hi and low port and all other openings with starting fluid it is high pressure and drys fast and clean put back together now this is were it got tricky the H and L
I put H closed and L almost closed started and now runs great.
it took awhile to figure were they should be some say 1.5 out that was not my case they are very very sensive the idleler screw is barely positioned to open the idle now i have a great education on this type of saw
Apr 16, 2012 | Poulan Garden
COOLANT IN PCM
With growing fuel costs and problems of global warming that are being faced by our planet, automotive industry is trying its best to create cars and engines that are more fuel efficient. In a recent news release Chevrolet unveiled the working of The Air Shutter system which is going to be used in the much awaited Chevrolet Cruze Eco model giving it a decently good fuel economy of 40MPG or 17 kmpl.
Air Shutter System Working Greg Fadler, aerodynamics engineering group manager at Chevrolet and his team developed The Air Shutter system to make 2011 Chevrolet Cruze Eco one of the most fuel efficient small cars on the market achieving almost hybrid like fuel economy without the Hybrid cost and maintenance. This was achieved by using commonly used techniques of reducing overall weight and ride height to provide it the aerodynamic benefit. chevrolet+cruze+eco+air+shutter.gif
The real innovation is the front grill which has an automatic shutter system that senses wind flow and temperature conditions with sensors which, are connected to small electric motors that open and close the shutter as and when needed. When the car is moving at slow speed (city driving) the shutters open to provide maximum air flow to the engine for cooling thus, reducing radiator power consumption. The shutter remain closed during high speeds (highway driving), providing an increase in half a mile per gallon in combined city and highway driving.
The system however doesn't compromise with engine cooling in anyway. The system in fact helps to provide maximum cooing in the worst of conditions with the advantage of increased fuel economy.
Feb 24, 2011 | 2011 Chevrolet Cruze
Just purchased new burners with air shutters. How do I adjust the air shutters on the new burners? Thanks
Turn the shutters closed til the flame just starts to change to a more yellow color... then open just a tick...
heatman101
Oct 20, 2010 | GE Monogram ZGG36L31CSS All-in-One Grill /...
Canon Powershot A510 - lens covers stuck
A stuck lens cover is a fairly common problem, but it is normally easy to fix. A single grain of sand jamming the cover mechanism is normally the culprit, and you want to try to dislodge it. There are many non-invasive techniques that people have come up with to accomplish this. Some may be seen on this blog article. You can also open the lens barrel up to fix the covers, but only as a very last resort. The article also gives examples for this type of procedure.
Jun 06, 2010 | Canon PowerShot A510 Digital Camera
Carb settings mixture jets on a homelite weedeater st155
ther is no set setting but to get it to run so it can be adjusted. lightly close the high off then open the low about two turns. try to start if starts slowly adust the low screw till it runs normal with the choke all the way off. then start to add throttle while turning the high out till regiured rpms ar reached with no misses. this takes awhile even fo a seasoned mech and may require several attempts
Dec 24, 2009 | Garden
The shutters on my Fujifilm E900 wont open or close properly.
Do you mean the lens cover on the end of the lens Is not opening properly, or the shutter inside the lens?
Aug 24, 2009 | Fuji FinePix E900 Zoom Digital Camera
My son pulled out one of the shutters that opens and closes over the lens. The shutters no longer open all the way. The camera is brand new. How can I fix the rest of the shutters? Should I pull them...
You can pull off the other one if you want. To put it back in your basically going to have to take apart the camera. The "Shutters" on the outside is nothing more but to protect the lens will its in the camera. The actual shutter is inside the lens that open and closes very quickly when you take a picture.
Think of it this way, the shutter in the lens opens up to let in light that shows the image to the sensor behind the lens. Then it closes to "finish" capturing the light".
The "shutters" or "doors" on the outside do not move once you take a picture. They only close once the lens retract. (When the camera is turned off or idles)
Hope this has been helpful.
Mar 30, 2009 | Fuji J150w Digital Camera
Shutter will not open/close (Disengaged from motor - "flopping" loose)
Well, replacement of the shutter unit (lens barrier)instead of the repair seems more realistic... Please contact your nearest Sony Service for the price estimate. If you need more info please advice. Arpi
Mar 19, 2007 | Sony Handycam HDR-HC3 HDV Digital...
Ventamatic Direct Drive Whole House Fan With Univer Logo
190 people viewed this question
Top Ventamatic Dryers Experts
Are you a Ventamatic Dryer Expert? Answer questions, earn points and help others
