Need remote for bose av 18 media center
Hi how are you? i need a remote for my bose av 18 media center system. do you know what part number i need for the remote? i want somthing original.thanks
This seems to be a common problem with Bose Av18 media centers systems. Remotes just stop working for unknown reasons. So after spending $1,200 for the bose system you need to buy another $100 remote control. I found new remotes by doing a search but eBay has them as well as amazon.
Posted on Feb 06, 2011
I have a bose system and my remote control model RC18T1-27 does not respond at all> I thought maybe it is the batteries and thaty didn"t sole the problem. It has not been droped or anything it just stoped working all of the sudden
Posted on Jul 11, 2009
Model rc18t1-27
Posted on Sep 22, 2008
Bose av 18 media center remote codes
Codes to check with Bose AV systems are 1231 1298. If you wish to get more, check the sites linked here. Pull up previous posts there, either by type in the model name to your set in its search box, or view it in Mosaic /Timeslide option.
Jul 15, 2013 | Televison & Video
Bose av321 video settings won't display on tv
Make sure the video output from your Bose System is connected to the right input source of your tv.If it does not work,try using a different remote control.If it still doesn't work,then you will need the service a Bose repair technician.
Jan 28, 2013 | Bose Av3-2-1 Series Ii Media Center...
Hello I have a bose surround sound system in my house, both inside and out. It appears that only the inside portion of the surround system works and the remote for the outside portion the RC48S2-27 model...
I think we're discussing the Personal Music Center II.
I had to back into the product from the remote model number. Can we assume you also have one of the compatible LS systems (18 or 28 Series II or the 38 or 48) ?
You can go to and search for it or register and download the manual for free at
The first item in Troubleshooting (page 28) might explain what's happening.
Jun 18, 2011 | Bose PERSONAL music center II System
My bose av 321 IImedia center remote isnt working , is there a way to program it, have new batteries in now
One does not have to program the original remote of the media center, yes even if the battery runs out. It is pre-programmed and you cannot change that .
What you have to check is if your previous battery leaked inside ( was there any wetness in the battery compartment when you replaced the previous battery? ). The acid / alkali in batteries are known to corrode the circuit board and components . You might need a replacement instead of a fix .
Apr 10, 2011 | Bose (321GS) System
Bose lifestyle 28 will not come on?
The Bose Lifestyle System has two power connection. One is the adaptor for the media center/DVD and the other one is the bass module/ subwoofer. Both has physical indicators showing that power is present. If your pwoer adaptor is ok, then the media center display should show "BOSE LIFESTYLE SYSTEMS" on startup. The bass module power module should be OK when you see a green blinking or steady linght underneath.
If only the media center/DVD has no display then there is something wrong with your pwer adaptor and should be sent for repair.
Hope I have helped you
Apr 05, 2009 | Bose Lifestyle 18 System
I have a lifestyle 18 bose system which only plays region 2 DVDs. How can I get it to play region 1 as well?
Hi, check below the media center/DVD player as to what region your system was fixed into (indicated by a number inside a globe). This is located underneath the unit just beside the serial number. FI the system indicates that your system indeed is set to region-2 then proceed as follows. IF it marks a different number region, then bring the unit to the Bose service center.
Steps in UNLOCKING REGION CODE of media center:
1. Load a DVD and wait for the display to show "REGION CODE ERROR, CONTACT BOSE"
2. Once this comes out, press eject button on your remote control but do not remove DVD disc
3. Press the following button commands in sequence (make sure they are in sequence and are pressed by looking into the media center display where a small green dot should blink indicating that each command is received).
4. First you need to initiate the system region change on the remote control:
a.while the tray is out and the DVD is still in the tray, press and release "RIGHT" arrow button
b. then press and release "UP" arrow button
c. after, press and release "SHUFFLE" button
d. then press and release "STOP" (black square symbol) button
e. lastly, press and release "MUTE" button and system should go on mute (indicated in the LCD display
After this, you now can change the region code by doing the following button press on your remote control:
1. While the DVD tray is out still and the DVD disc is in the tray, press and release "STOP" button (black square mark)
2. Press and release "SHUFFLE" button
3. Press and release number "0" button on numeric keypad
4. Lastly, press and release "ENTER" button on your remote control and the DVD tray should go back inside the DVD. The disc then should start loading and playing resumes.
5. Allow the DVD disc to run for a few minutes (if you want enjoy a full movie) to keep the region change resident before switching off again.
Now enjoy your Bose Lfiestyle DVD System REGION FREE!!!
Do note, this does not apply to Bose DVD system that are locked to region-1
Glad to be of service always!
Mar 03, 2009 | Bose Lifestyle 18 System
Want to test to see if bose lifestyle 18 works.
Hi sorry but what do you mean that you have lifestyle 18 system? The lifestyle 18 system consist of the media center/DVD player, the bass module, the satellite speakers and the RF remote control (aside from tons of cables)
If you have the media center/DVD only, then you require the power adaptor. you can test if the media center is functioning if the LCD display is working. you can also connect an external powered speaker or an amplifier fro mteh AUX out behind the media center.
Do note that doing so will only give you limited control of the system since you require the whole lot to make everything work properly.
Glad to be of service.
Jan 27, 2009 | Bose Lifestyle 18 System
Connect my remote of my bose lifestyle 18 to my samsung 46a 650
Hi, have you tried going to the system settings menu adn program your 3rd party products htrough there? You may try varied IR code settings for your electronics from there and one of those codes should work atleast for your system. There may be some codes you will get to use but does not have all the funcitons so you need to be patient to try them all.
As per the Blue-Ray DVD, the remote code might still not be embedded on the IR controller chip that is installed in your Lifesytle (after you have tried all the codes and still none works). Bose does release regular firmware updates via their user mailer (if you have registered your product online) or you may passby any of the Bose service center and request them to provide you with the update disc specific to your system version (look underneath the DVD player and the bass module they should indicate AV-- and PS-- models).
Glad to be of service...
Jan 14, 2009 | Bose Lifestyle 18 System
Televison & Video Logo
1,472 people viewed this question
Top Televison & Video Experts
