MGE UPS Pulsar EXtreme 1500 C UPS System Logo
Posted on Feb 16, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Please can you tel me whitch Kind of battery, and how many battery there is in this model : MGE PULSAR EXTREME 1500C RACK and MGE PULSAR EXTREME EXB 1500C RACK
Raj Patel
Level 3:
Genius:
  • Master 1,042 Answers
  • Posted on Feb 16, 2011
Raj Patel
Master
Level 3:
Genius:
Answers
1042
Questions
Helped
270306
Points
3723
Specifications for MGE Pulsar Extreme 1500 C 2U Rack Battery kit
Voltage 12V (Per Cell) Capacity 6Ah (24W) Weight 8Kg Dimensions 151mm x 94mm x 51mm (Per Cell) Lifespan 3 - 5 years Type Sealed Lead acid battery rechargeable highly efficient, leak proof and maintenance free
I think there are four batteries in the pack.
Pulsar UPS DC bus too high
where did you find this old UPS> ? I'd bet cash it did not just fail 14 years online TODAY.!?
Redux1 this is way too long but there are many sub models of PULSAR and non told yet. by you.
nor if TOWER OR RACK MODEL is your? wow. that. ? not the same batteries at all in both ever.
did not read your manual first.
14 YEARS old it is, and now owned by APC.com (a 2007 event)wiki it.
The HIGH DC means the Charger output is too high
or the 36v 3 battery loop is broken (no load equals charge voltage is too high DC bus)
if you have rack UPS and use 12vdc batteries, in it (not 6vdc as it must) the DC bus will be too high.
UPS is complex and more so not telling full model numbers of it and photo of if.
the LIST OF what can be wrong, (besides bad PCB inside)
wrong batteries, used, or connected wrong.
battery terms rusty. or just loose.
EXB option was enabled before (14 years ago?) and not reconfigured now that it is gone. now.
battery breaker rear tripped. in inside batteries and if EXB option the outside battery breaker tripped. on it.
wire backwards is prevented with connector keys, but if hacked , any thing is possible wrong,.
no photos of yours, the DC bus is 36vdc on the tower. 3x12=36v
AC LINE IN CAN BE SET 100VAC TO 480VAC, (TO COVER WORLD POWER USED)
if not configured day1, correctly there is no hope, only smoke.
what AC voltage is your country, (at home are you) and freqency, 50 or 60HZ, (most are auto set for Hz)
MGE is nOT MEG. at all. sorry but typos like that make help super hard.
just one of many 1500, I can not guess what your REALLY is, Pulsar has many sub models.
https://www.manualslib.com/manual/821986/Mge-Ups-Systems-Pulsar-Extreme-1500.html?page=1#manual
MGE is now owned by APC for 14 years today, UPS company (a top maker)
and this model is not supported now it is too old,,, found in garage sail for $1 USD, I'd pass on that.
and APC does not support this very very old UPS now. they chose not to support it, but gee call them and ask.
Apc.com, click support , and contact them.
next time post photos of front and rear.
and full model number not just "Pulsar 1500," shortened like that. and MGE not MEG.
and what country you live and if at home or using commercial power , 100v or 480vac or what. LINE POWER.?
last , is , if you buy a used UPS outside of your country it will be wrong AC input line voltage. and must be cured first. by strapping or configuration settings,
I have never seen any UPS made that works in all countries, and the few that do many, must be strapped first.
how that is done is covered in every UPS MANUAL made, in the world.
if done wrong this test step, you will get smoke or worse fire. (only fuse can save you from that done wrong)
never bypass fuses OK
and if doing other hacks say so, tell the hacks , like using the wrong batteries.
1helpful
1helpful
I have MGE pulsar extreme 3200c and I wanted to know that what is the Max battery size (Ah) I can use with it to get Maximum backup time for several hours. Thank you Azam Latif
Hi, I have this ups as well, My personal adjustment with this ups, is I have installed 6 external Ags Number 120, 15 plates per battery, in pairs. And its working fine on my end , and yes ups is able to charge them all without over charging or any other problems. My ups Already has 6 internal batteries bank installed, attaching these external batteries has increased the backup time.
Thank You.
1helpful
What software do I need to connect to my MGE UPS Pulsar EXtreme 1500C?
The Personal Power Pack (UPS_psp_2_60_02.exe)is the best for MGE UPS,but it has been discontinued for a long time and it runs only on XP and older windows os.
For adjusting the advanced parameters of the UPS,u can use the upsdrv15.exe. This software works only with serial connection.
The only solution for Windows 7 is Eaton's Lan Safe software (since Eaton bought a part of MGE,the UPS is recognised by their software).
These software are not very easy to find,but they're there.
1helpful
PULSAR 220F MINIMUM MILEAGE HOW PLZ TELL
If you are talking about a used UPS, i would not bother with a used unit.
I find if they are used 24hrs a day, when the electricity is tripped and the ups kicks in, they only last a couple of minutes.
I would plug just the pc and monitor into the UPS sockets, and plug everything else into the ordinary sockets. You will get alot longer out of the battery
I have an UPS MGE Pulsar EX30. One batterie was with zero volts. The others are with 13 Volts. I changed the bad batterie, but when I connect the batteries, I get a spark like as in short circuit. I don't...
make sure the UPS is off when you connect the battery and make sure the polarity is correct. Look for the signs on the casing. Check the other batteries to see if they are connected in serial or parallel. Should be in series if it is a mains voltage UPS from 12v batteries so the negative of one goes to the positive of another and they daisy-chain together
4helpful
2answers
Mge pulsar 3000 does not power up
MGE Pulsar 3000 is an online UPS. try to check the battery first if its ok. coz for an online UPS it will need to have a good working UPS battery to trigger the switching relays to on the online UPS unlike backups UPS that can be turn on without any batteries
Need replacement battery for a Pulsar EX15
I reccomend LED bateries as they last longer and are very sufficient
Top MGE Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a MGE Computer and Internet Expert? Answer questions, earn points and help others
