My amp as 60v dc current coming out of the speaker output on one side of the amp only.
    Brigadier General:
  • 6,966 Answers
Hi again,
Any developments?
Posted on Jul 25, 2008
What is rating of Spin 50 Power Module. Lost mine
Should it be a power supply that outputs AC and converts to DC inside the speaker case, or is it a wall adapter the outputs DC straight to the built in amplifier?
Some speakers have the voltage and polarity for the plug on the back of the speaker where the power lead plugs in. As they are only small speakers of probably a couple of watts it may only need about 2 Amps or less. Higher current is fine as the amp will only use what it needs to work correctly but I would'nt go below 2 Amps.
May 06, 2012 | Labtec Spin 50 Computer Speakers
Im having the problem with my mtx tc6001 amp smoking my speakers I hook up everything and when I turn on radilo speakers jump pop and smoke.
MAKE SURE THE SPEAKERS ARE CONNECTED TO THE AUDIO OUTPUT OF THE AMP AND NOT TO SOME WIRES SENDING DC POWER ........ IF THE AMPLIFIER HAS AN INTERNAL PROBLEM AND IS SENDING DC CURRENT TO THE SPEAKERS THIS WILL MAKE THEM SMOKE ALSO ...... HAVE THE AMP TESTED ON A BENCH IN A SHOP ...
MY GUESS IS IF THE SPEAKERS SMOKED THEY ARE DESTROYED AND CANNOT BE FIXED....... COIL ON THE BACK OF SPEAKERS NOW OPEN ---- SORRY TO TELL YOU THIS...
Jun 29, 2011 | Car Audio & Video
Hi ther the fuse has blown on the speaker out circet on my new amp any ideas why this would happen?
The fuse blew because of excess current. The cause of the excess current is either excess volume, a short in the speaker, OR the amp has failed and is shorted to one of the power rails internally and is driving DC current out.
Replace the fuse and use a meter to check the output voltage with NO speaker connected. It should be under 1/2 volt period. If it is, then check the resistance of the speaker. The DC resistance should be a little less than the rated impedance. Otherwise if the amp is kicking out a higher voltage or blows the fuse again, have the amp repaired.
Mar 28, 2011 | Ashdown Klystron 500w Bass Amp Head
My car subwoofers go IN and OUT frequently as of recently. wires APPEAR to be connected. Are they blown?
The cables from the amp to the speakers could be shorting out, the speaker(s) could be shorting or going bad. The impedance of the speakers could be to low for the amplifier. The amp could be overheating because of any of the above. Turn the power off and try disconnecting one speaker, make sure no bare wires are touching. Reapply the power and observe. If it still does it , reconnect the speaker and preform same test to the other channel. The previous test can determine the side that has the problem. If the problem is still present the speakers and cables need to be checked with an ohm meter. If the cables and speakers check out then the amp speaker outputs need to be checked to see if there is any DC voltage present. If DC voltage is present on the outputs then the amp output section needs to be repaired.
Jun 21, 2010 | Diesel Audio NSX-1422 Car Amp
Had the amp 4 months and getting no sound apart from loud clicking noises when the speakon leads to the speakers are plugged in,ive gone as far as knowing its amp and not speakers/leads etc.its not had...
If the click is a one shot deal when you connect the speakers, I'd suspect that there is DC current on the outputs. Check using a DC voltmeter. You should read less than 0.5VDC. If you read more, there is a problem with the output section. Since this unit is new, it should still be under warranty. DO NOT open it up. If you read DC, return the unit for warranty service.
Please keep us posted,
Dan
Oct 27, 2009 | Vestax VDA1000 2-Channel Amplifier
Noisy left hand power output stage. Noisy transistor? No circuit diagram.
If the speaker is not blown, there must be an output capacitor. If no output capacitor, and you have a blown transistor the speaker will blow from DC current. You can further check the transistors with a multimeter. A transistor looks like 2 diodes and you should be abobe to test with a mulimenter like a diode test.
May 12, 2009 | Audio Players & Recorders
What kind of external power supply does the media speaker needs?
Juster-Avia 3D-107 Media speakers.
I wanted to know what kind of external power supply it needed. I open the case and saw 4 diodes which tells me is a bridge rectifier circuit. I also looked at the filter cap and saw ????uF at 28 volts. Therefor, I did the Scientific Wild *** Guess( A.K.A. SWAG METHOD)
12 volts AC out at 1.6 amps or higher.
Apr 28, 2009 | Juster 3D-102 Computer Speakers
Sony STR-DB940 Receiver Speaker Impedance Question
Whats the rating on the Plasma? How many watts at 4 ohms? If the plasma is rated 100 w at 8 ohm... hanging a 3.4 ohm load would put a lot of strain on the plasma's output amp. At 3.4 ohm the amp would be trying to delive close to 200 watts at full power. But it depends on how hot you normally run the volumn. Remember an amplifier output is AC volts. 1 ohm of resistance is close to a dead short. The amplifier would have to work its *** off to supply that type of power and would probably burn the output op-amps. If the outputs burn & it pumps any DC current through the speaker wire..the speakers would be toast...if not catch on fire. Try to keep the speaker load at or very cloe to the plasma's output load rating. Also if the plasma doesn't state it will handle loads down to 2 ohms...It probably won't.
Gene
Mar 02, 2009 | Sony STR-DB940 Receiver
Amp no longer turning on
Do the speakers push out or pull in when power is applied?
If not, how did you determine that is has DC on the speaker outputs?
Oct 04, 2008 | Legacy Audio LA1030 Car Audio Amplifier
My amp quit working
ok I thought I anwered this one but first thing to try is disconnect all your speakers and see if the light goes out if it doesnt then your gonna need a schematic and a working know how on solid state amplifiers. first check al the outputs for the speakers for dc If theres dc on an output then that output device is shorted or leaky. Ive have open drivers as well as current control transistors leaky or shorted to that made the protection come on.. Good Luck
Apr 07, 2006 | AudioBahn A6004T Car Audio Amplifier
 Grubhead
Grubhead
