Question about Hitachi 53UWX10B 53" Rear Projection Television
Hitachi TV green CRT tube
Green CRT tube is not working
  • 927 Answers
Good Day, optih;
Why do you think the TV's green CRT is not working? If that is the case I would think of buying a new TV, or spend about
$550.00 to repair the TV.
Good Luck, big IRISH. PS Only use a Factory Authorized Service Center.
Posted on Aug 21, 2008
Color has changed to green tint
    According to the system the problem in your projection is convergence and the solution is to replace the IC STK's.The part Number is CZ01341. Change the IC STK both and your TV work fine again.And for parts please see the link below.
http://jr.partsearch.com/Model/Hitachi+Ltd/Hitachi/43FDX01B.aspx?SearchTerm=True
   Thanks.
Jan 09, 2010 | Hitachi 43FDX01B TV
53 inch projection tv...seems like the color red and color blue have shifted giving me a picture with red and blue shadows
For CRT projection TV's, this indicates that the Green picture tube is burned (warn out). The less green that strikes the screen, the more redish the image will look. You will need to find an old school TV repair shop that knows how to replace picture tubes.
In the case of a DLP style TV, the color wheel needs replacing.
Dec 29, 2009 | Hitachi Televison & Video
No green color----all other colors seem fine and pic is clear and sharp.
The most likely cause is a bad (shorted or open) CRT driver transistor on the green CRT board. Also check the solder connections on the connector sockets for wires that get plugged into on the CRT boards (and check all the CRT boards; not just the green CRT Board).
The next most-likely cause is a bad green CRT. Try tapping (gently!) on the neck of the green CRT and see if you get any green flashing on the screen. If so, then you've got a bad green picture tube.
Note: I am assuming you are an electronic technician with at least basic knowledge of electronics, and that you know how to solder and test components like resistors, capacitors, diodes, and transistors. If not, you better defer this repair to someone more experienced.
Oct 15, 2009 | Hitachi 43FWX20B 43" Rear Projection...
D52W20BYX1 Green problem
I would go back to green tube disconnect ,unplug CRT board to green tube if set stays up playing its the tube.
Sep 19, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Only has red and green
The Blue CRT Driver Board gould be the problem.
Jul 06, 2009 | Hitachi 50GX49B 50" Rear Projection...
Hitachi S57500 projection tv turns itself off
Hi, I`m afraid it`s not good news, you have a bad green picture tube, video-tek
Feb 10, 2009 | Hitachi 57S500 57" Rear Projection...
TV Has no pitcher
you could have a shorted tube Green disconnect CRT board from green tube if set stays on tube is shorted also check video ic on crt board.
Dec 07, 2008 | JVC AV-56WP74 56" Rear Projection...
Images on tv are green sony 60 in projection sxrd-
If it's bright green with light lines from side to side the green gun is shorting out. You would need to take the front off and look at the neck of the tubes. See if all three filiments are working. It will be a dim glowing in the neck of each tube. If you have filiment voltage but no red gun you may have bad solder connections on the CRT modules but being it's a Sony it could be a bad green Tube. If the green gun is shorting out call around to TV shops in your area and ask them if they have a Beltron or BNK Picture Tube Rejuvenator. Sometimes the short can be cleared using the right test equipment. Ask them how much they would charge you to shoot the tube if that's your problem. If it's no Red it may be bad solder connections on the CRT modules. I hope this helps.
Oct 16, 2008 | Televison & Video
I have a hitachi ultravision tv m#53sbx10b s#v1g000279 and everything works but there is a blue and somtimes yellow swoosh thing in the top left corner. it like fades throughout the colors? i was hoping...
Your Green CRTs coolant may be congealed giving the green tube a yellowish look it should be a vibrant green. Try changing the coolant in the CRT
May 06, 2008 | Televison & Video
Green Screen
Sounds like the green tube is shorted.
Oct 06, 2007 | Hitachi 50VS810 50" Rear Projection HDTV
Open Questions:
See all Hitachi 53UWX10B 53" Rear Projection Television Questions
Hitachi 53UWX10B 53" Rear Projection Television Logo
317 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
