SOURCE: instructions for setting amriton
From http://www.armitron.com/WatchInstructions.html
If you cannot locate your type of watch listed here, please refer to the back of the watch
case for our Armitron style number and contact us at 718.784.0700 for further help
SOURCE: lost manual to Coleman nightsight
you might try this link http://www.ologi.com/instructions/
SOURCE: coleman watch Model No. 40-328 How To change from 24 to 12 hour
I couldn't find the instructions for your watch but as watches tend to have similar operating characteristics, try this:-
Press the mode button until you come to a message that says something like "12hr" or "24hr" or something that indicates display change.
Then press one of the two buttons on the right to change to the display you require.
Some experimenting may be required!
SOURCE: how do I set time etc on a coleman sports watch,
The watch has four buttons. The lower left button is labeled MODE on the face of the watch. There are four modes and pressing the MODE button will step through each mode until you return to the mode at the start of the process. Start at the "Normal" timekeeping mode and press the "MODE" button three times until the digital display rightmost two figures for seconds flash.
Press the lower right button labeled RESET until the item you want to change is flashing. Pressing RESET cycles through seconds, minutes, hours, day, month, day of the week in the top sub-dial and then back to seconds again.
When the item you want to change is flashing press the top right button labeled START to step the displayed item to the value you want. When you are satisfied all the settings are correct, press the lower left button marked MODE to return to normal operation.
Coleman 40-408 User's Guide
SOURCE: instruction manual for coleman 40-976 watch
Hello destewart,
I have a copy of the manual for you. If you email me, I'll send it to you in an Adobe PDF file.
[email protected]
I hope this helps.
Sandy
