Question about JVC AV-56WP74 56" Rear Projection HDTV-Ready Television
Red color trouble
My projection tv has a red stripe on the middle of screen
    Novelist:
  • 132 Answers
A picture or blank raster viewed from the front will have red marks if a portion of the image path from the green CRT to the front screen is blocked by debris or if the Green CRT is damaged from burn-in or other situations. If green is missing, red dominates virtually any image.
Severe CRT burn-in can occur when there is no sweep signal to a yoke. I have seen technicians removing yoke connectors on RPTVs in attempts to find shorted or suspect components.
Occasionally a damaged TV is sent back to customers as repaired and a service order for a new "fault or complaint" is initiated when the customer complains of the red or green marks or lines.
easyab
Posted on Aug 24, 2008
Red stripe across the screen of sony tv
your tv has a defect in the screen. maybe its only a capacitor or the board have a defect. but you need a qualified technician to fix your problem.just consult that problem to the sony service technician.
Jul 13, 2010 | Sony KDF46E2000 46" Projection HDTV
I have a red line going accross my tv screen. Its
Do you have speakers next to your tv sometimes the line on your tv will be from your sound to close to your tv also the red line could mean your tv tube is going out there about 300 to replace but i ould check frist on your sound are something close to you tv that is maken the red line in the middle of your tv
Dec 09, 2009 | Sony KP-51WS510 51" Rear Projection...
I have a red stripe across the top off my tv
This issue is because of a defect in the light engine. The only way to solve is to replace the whole light engine. They usually run anywhere from $500-$2500 depending on the model. Sony extended the warranties for the light engine on certain models that have this problem because of the defect, contact Sony to see if a certain TV had the warranty extended.
Oct 05, 2009 | Sony Televison & Video
Yellow stripe across middle of the picture
yes rteh color of the wires(ends)red,blue,green,sounds like they may ahve gone bad or are interchanged, what does it do with a dvd picture
May 23, 2009 | Hitachi 42V710 42" Rear Projection HDTV
Red Stripe
the cost of the repair is fair. The color wheel is about 175.00 some other areas in the tv with the kind of problem you are relating can cost the board just above 200.00 until 350.00 then only the color wheel can practically cover the cost you are about to do. Plus labor. make sure they give you the 3 months warranty.
Feb 24, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Pioneer SD-641HD5 red convergence - not chip problem!
Replace Both of your STKs if they are STK392-110s do not go back with them use STK392-180s better ICs, The 110s fall apart and do not hold up.
Nov 12, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
No color and green and or purple color stripe
Yes, sounds like the convergance IC's. They will need to be replaced.
Apr 13, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
Big vertical tinted stripe on screen
Need more information:
Can you isolate which color is causing the banding?
Is there something ON the lense itself?
Is the projection mirror broken or bent?
S
Dec 12, 2007 | Sony Grand WEGA KDP-57XBR2 57" Rear...
Mitsubishi Projection TV problem
Hello Adam...
Most likely a bad formatter board, which plugs in vertically on the signal board.
Nov 25, 2007 | Mitsubishi WS-65809 65" Rear Projection...
Vertical Stripes on My Mitsubishi WS-65809 Projection TV
ADAM,
YOU NEED TO ADJUST THE SCREEN VOLTAGES TO BALANCE IT OUT. YOU CAN DO IT YOUSELF. HERE IS A WEBSITE. PLEASE READ THROUGH IT ALL. ITS FOR RED TINT OR LINES, BUT ITS USE IS FOR THE SAME PROBLEM AND COLORS. HOPFULLY, ON A LITTLE ADJUSTMENT IS ALL IT NEEDS.
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
PRIDAH
Nov 22, 2007 | Sony KP-57WS500 57" Rear Projection...
JVC AV-56WP74 56" Rear Projection HDTV-Ready Television Logo
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
