Question about Mintek Televison & Video
Disk will notspin and load - Mintek Televison & Video
    Genius:
  • Mintek Master
  • 1,550 Answers
Clean the laser lens
Posted on Jul 25, 2008
My machine is not spinning
Most common problem affecting spin: Door Lock.
Jul 26, 2016 | Washing Machines
Eratic, sometimes door lock doesnt activate, when it does wahser starts but stop mid cycle and wont continue. Replaced door switch and pump
Repair needed on Maytag Neptune washer - Home Improvement ...
www.dslreports.com > ... > Home Improvement
DSLReports
Aug 5, 2007 - 19 posts - ‎8 authors
Forum discussion: We have a Maytag Neptune front-loader washing machine that ...the drain/spin cycle after a wash even though the timer continues to ... related circuit board failure" their Neptune washer will lock the door, turn on the ... then will either not start tumbling or will stop operation mid-spin cycle.
How To Fix A Washing Machine That Is Not Spinning or ...
removeandreplace.com/.../washing-machine-or-washer-dryer-is-not-spin...
May 13, 2013 - The absolute first thing to do to your washing machine that will notspin or drain (whether it. ... I was so fed up with the machine sometimes refusing to spin or drain the .... I just did a load and it stopped midcycle with e and f error codes.... I tried different cycles but all that happens is the door lock engages ...
Maytag Washer Troubleshooting - YouTube
Dec 02, 2015 | Maytag Washing Machines
WILL FILL UP BUT DOES NOTSPIN OR WASH.
Usually lid switch is the causes
Jun 28, 2015 | Washing Machines
Hello; My washer will not agitate or spin. It does **** out the water. My guess is the "agitate" belt is broken (I can hear the motor running, but there is no agitation or spinning). Appreciate...
you have a broken motor coupling.remove the two screws that hold the top console down,flip up the console,remove the two metal clips and unplug the harness closest to the right clip.open the lid,grab the frame tilt it up and back and the whole frame can be removed.look at the bottom,remove the two clips and slide the pump off,do the same to the motor and on the back you'll find the motor coupling.most likely it will be broke.remove the other half off of the tranny.install the new coupling and you should be fine.if you need anymore help let me know
Jan 23, 2011 | Kenmore 3.2 cu. ft. Plus Top Load Washer
2009 suburban six disk cd
you should just have to press load button and when the green light comes on load 1st disk, after it loads then press load again to load 2nd disk. etc.. continue for all 6 disks
Sep 14, 2009 | Cars & Trucks
Cut thread in the middle of sewing.
The tension of the upper therad is too tight. loosen it by following the instr in the manual
or the upper thread is notspinning off the feel freely while sewing. Make sure the upper thread is not getting cought while sewing,
Ot the upper thread is incorrectly threaded, remove the thread and rethread the machine.
Good Luck.
Aug 16, 2009 | Singer 7422
Not cooling properly
is ther e frost on the evaporator directly below the fan??? if so the fan should be spinning. try taking off te power leads to the fan and check for 110v. ifyou have 110v between the 2 fan leads and its notspinning you have a bad fan
Mar 13, 2008 | Refrigerators
I'm having a problem with my CDJ 800. Loading ejecting
Basic DVD, CDrom Troubleshooting
wrong disk ,disk error,
First Clean the lens:
http://www.ehow.com/how_2036275_clean-lens-dvd.html
wont open, wont close, makes clicking/grinding noises etc.
http://www.llamma.com/xbox/Repairs/thompson_dvd_tray.htm
Jan 28, 2008 | Pioneer CDJ-800 Turntable
Televison & Video Logo
22 people viewed this question
Top Mintek Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Mintek Televison and Video Expert? Answer questions, earn points and help others
