Question about RCA Televison & Video
My tv wont turn on it is a rca d40w20 when i hit the on button it just blinks 4 or 5 times and still wont come on
  • 927 Answers
Good Day, citiofdreemz;
This TV has so many concerns that I would recommend that you call an authorized factory service center, it will in the long run save you $ and time.
For real, big IRISH.
Posted on Jul 25, 2008
When i turn on my tv it lights up the on and off button but nothing else happens, no picture, the it turns off and back on again.
At the back... small door.. remove old bulb and replace it with new. It could be blown and it is protecting the rest of the TV
On google put: RCA D40W20 parts.
Near the top will be a site to go to and they will ship to you and it is easier than changing a home lightbulb
Aug 09, 2010 | RCA Scenium D40W20 40" Rear Projection...
Tv doesnt turn on at all
It seems that your unit has some sort of PSU fault, or a problem that is shutting down the Power Supply Unit, PSU. The noise is what gives it away. This happens so that no further damage, and possible fire will occur.
You need to take the unit to a reputable service centre/man and ask for a firm "Quote" for the work to be done. It is that sound that gives it away, this is a typical switchmode Power Supply problem.
Jan 23, 2010 | RCA Scenium D40W20 40" Rear Projection...
Tv just cuts off and the power button blinks 5 times and stops
According to the service manual the lamp needs to be replaced.
Hope this helps,
Skyassoc
Jul 18, 2009 | RCA Scenium D40W20 40" Rear Projection...
RCA HDTV DLP Rear Projection TV wont turn on
RCA Projection tvs are trash,should be off the market.
Mar 29, 2009 | RCA Scenium D40W20 40" Rear Projection...
Tv won,t come on now
i have a kp51ws520 that i just fixed. it blinked 9 times. found out it was the g board. got it done pretty cheap . let me know if you need more info.
Feb 05, 2009 | RCA Scenium D40W20 40" Rear Projection...
Rca d40w20 tv convergence and power on problems
The problem is most likely due to a defective convergence IC.
There are two convergence STK ICs located on the convergence board.
You need first to test the ICS, by checking for continuity the pico fuses at the base of the ICs, then replace the faulty STK.
You should trying doing it yourself only if you are a proven electronic repairer.
Nov 07, 2008 | RCA Scenium D40W20 40" Rear Projection...
Problem with TV
One of the boards may have failed, have you looked inside the tv?
Sep 08, 2008 | RCA Scenium D40W20 40" Rear Projection...
RCA 42in Projection
There is a short, the tv is trying to come on but the fault is keeping it from coming on. Try to find a bad board inside the tv, check all fuses or continuity. Thatll give you a place to start from.
Aug 26, 2008 | RCA Scenium D40W20 40" Rear Projection...
RCA universal remote
I programmed an rca universal remote by:
TURN ONTHE TV
HOLDING DOWN THE TV ANDTHEON/OFF BUTTON ATTHE SAME TIME.UNTILTHEON/OFF BUTTON STAYED ILLUMINATED.
PRESS THE PLAYBUTTON IT WILL BLINK,IF TV DOES NOT GO OFF PRESS PLAY EVERY 5 SECONDS UNTIL TV GOES OFF.
ONCE TV TURNS OFF HIT THE REVERSE BUTTON THE TV WILL COME BACK ON.
HIT THE STOP BUTTON TO SAVE THE CODE.
REPEAT THIS BUT HOLD THE OTHER DESIRED DEVICE INSTEAD OF THE TV.
HOPE IT WORKS
Igotthisinfo from google....then typed in rca universal remote...there was a sight for programming remote.
Jul 26, 2008 | Sanyo DS24425 24" TV
Televison & Video Logo
60 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
