Question about HP PSC 750 All-In-One InkJet Printer
Ink jet print head
My printer ink jet ports are clogged and I don't know how to remove them from the unit to unclog the jets.
    Novelist:
  • 183 Answers
Unseating and reseating the cartridge
Turn the unit on and open the lid or top cover.
Remove the cartridges.
Re-insert the cartridges.
Close the unit’s lid or top cover.
Cycle the power to the device by turning the printer off for a few seconds.
Turn the printer back on.
Print a test page. If this does not solve the problem, proceed to the next section.
Wiping the cartridge contacts
Using a clean, dry lint-free cloth (a coffee filter works well), wipe the cartridge contacts, from the top to the bottom (see Figure 1). The contact area of the cartridge should be rubbed briskly to remove the waxy lubricant material from the gold contacts.
Figure 1: Cleaning the cartridge contacts
The contacts inside the printer may also require cleaning. Using a clean, dry, lint-free cloth, gently wipe the contacts, from the top to the bottom (see Figure 2).
Figure 2: Cleaning contacts inside the printer
Re-insert the cartridges and close the printer’s top cover.
Print a test page. If the problem persists, perform a hard reset as described in the next section.
Performing a hard reset on the unit
When the printing unit detects an issue with the cartridge, a software flag is set inside the device. This flag may not reset until performing a hard reset on the device.
HP Deskjet and Photosmart printers
Verify that the unit is switched on.
Open printer and remove both cartridges.
Unplug the power cord from the printer.
Wait 30 seconds.
Plug the power cord back into the printer.
Open the top cover and reinsert both cartridges.
Turn the unit on.
Print a test page. If the problem persists, the cartridge should be replaced.
HP Officejet and PSC all-in-one
Remove the power cable from the back of the machine.
Wait 30 seconds.
Press and hold the POWER button on the front panel.
Reinsert the power cable in the backside of the unit.
Posted on Jul 25, 2008
  • HP Master
  • 6,487 Answers
Cleaning the Service Station.
1. Remove the service station motor by removing one screw.
2. Scrap as much congealed ink as possible from the service station.
3. Soak the service station in hot water to dissolve the remaining ink. This will take a while but after a few rinsings nearly all of the ink will be removed.
Hope that helps..........
  • HP Master
  • 1,879 Answers
Try the Printer Driver Utility first.
Printer acts like it is printing and there is ink in the printer but pages are coming out blank
The ink-jets that SHOULD be spraying the ink onto the paper are clogged.
Run a few "print-head-cleaning" cycles, to try to unclog the ink-jets.
Jul 25, 2011 | Office Equipment & Supplies
My printer ink is full and it just printing in black and yellow
The ink leaves the ink-cartridge, and should flow through the ink-jets to be sprayed onto the paper.
If some of the ink-jets are clogged (blue, red) and some of the ink-jets are fine (black, yellow),
then you need to run a few "print-head-cleaning" cycles, to try to unclog those ink-jets.
Jul 19, 2011 | Office Equipment & Supplies
Almost every 4 lines the ink is very faint
The print-head is like a paint-brush -- it paints many "rows" in one swipe across the page.
So, some of the ink-jets in the print-head are clogged.
Run a few print-head-cleaning cycles to try to unclog all the ink-jets.
Jul 19, 2011 | Canon PIXMA MP190 All-In-One InkJet...
Why is there a clear horizontal line within the printed line?
The print-head is like a paint-brush, in that it prints a "band" as it goes across the page.
In your case, some of the ink-jets are CLOGGED, and thus are not shooting ink as the print-head moves HORIZONTALLY across the page.
Run a few "print-head-cleaning-cycles", to try to unclog those ink-jets.
May 14, 2011 | Canon BJ 200EX InkJet Printer
My printer is printing photos and they are blue. Am I almost out of ink?
You either are out-of-ink, or the ink-jets are clogged. Run a "print-head-cleaning" cycle to unclog any jets.
Feb 21, 2011 | Dell Office Equipment & Supplies
Color ink cartridge show a full ink supply, but it won't print color.
It's possible that the ink-jets that spray the colour ink onto the paper have become clogged. Run the printer software, and select a "print-head-cleaning-cycle", to try to unclog those jets.
Oct 17, 2010 | Dell Inkjet 720 Printer
Won't print...says it is printing but doesn't
If you have lots of flashing error lights or electrical problems then it is likely to be electrical.
However, if like most... and your
printer has just been left unused for some time? You probably just have an ink clog.
Provided it worked OK before a period of non-use? Then you just need to use a PRINT HEAD CLEANING KIT to unclog the tiny jets.
Magic Inkjet Flush usually works a treat on those!
Magic is ideal for unclogging the tiny jets on any Canon,Epson HP and removing those horrible white lines which usually appear in prints whendried ink clogs several jets...
So if yours appears to be a clog? all you should need to do is to use the MagicInkjet Flush kit to soak the print head and you should be printing again like new.
You can read more here:
How to Clean, Fix, Repair, Unclog, Dry, Clogged Print Heads on CANON, EPSON, HP, Lexmark, Dell, Olivetti etc…
Good Luck!
John P Bradley
Tinteiros (Ebay)
Nov 23, 2009 | HP Deskjet F4180 All-in-One InkJet Printer
How can you clean the printer but clicking on
Hi
If yourPSC 1210v printer has been left unused for some time? You probably have an ink clog and the standard cleaning is not enough to clear the clogged ink.
Assuming your HP 56 57 still has ink? Empty they are about 30g Each 1g over that is 1ml of unused ink.
Magic is ideal for unclogging the tiny jets on any Canon,Epson HP and removing those horrible white lines which usually appear in prints when dried ink clogs several jets...
So if yours appears to be a clog? all you should need to do is to use a littleMagic Inkjet Flush to soak the print head and you should be printing again like new.
Good Luck!
John P Bradley
Tinteiros (Ebay)
Nov 02, 2009 | HP PSC 1210v All-In-One InkJet Printer
CARTRIDGE PROBLEM TRI COLOR WONT PRINT
HTML clipboardHi
If your printer has been left unused for some time? You probably have an ink clog and the standard cleaning is not enough to clear the clogged ink.
Assuming your tri colour still has ink? (Empty they are about 30g Each 1g over that is 1ml of unused ink.)
Magic is ideal for unclogging the tiny jets on any Canon, Epson HP and removing those horrible white lines which usually appear in prints when dried ink clogs several jets...
So if yours appears to be a clog? all you should need to do is to use a little Magic Inkjet Flush to soak the print head and you should be printing again like new.
HTML clipboard HTML clipboard HTML clipboardYou can read more here: How to Clean, Fix, Repair, Unclog, Dry, Clogged Print Heads on CANON, EPSON, HP, Lexmark, Dell, Olivetti etc…
Good Luck!
HTML clipboard
John P Bradley
Tinteiros (Ebay)
Tinteiros (Ebay)
Nov 02, 2009 | HP OfficeJet J4580 All-In-One Laser...
I put a new color cart in and now my pictures have a green hue to them
Hi
Sounds like too much cyan.
Remove ink and place onto a paper towel.
If it appears too much cyan *blue then let it stand for 2 mins. You can do the same if mixed.
Once normal colours appear try again.
However, if like most... and your printer has just been left unused for some time? You probably have an ink clog on the cyan and magenta.
Magic is ideal for unclogging the tiny jets on any Canon, Epson HP andremoving those horrible white lines which usually appear in prints whendried ink clogs several jets...
So if yours appears to be a clog? all you should need to do is to usethe Magic Inkjet Flush kit to soak the print head and you should beprinting again like new.
Good Luck!
Tinteiros (Ebay)
Oct 31, 2009 | Lexmark P4350 All-In-One InkJet Printer
HP PSC 750 All-In-One InkJet Printer Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
