Question about Intertherm Heating & Cooling
I need a replacement thermostat for an Intertherm T841A1480...but i can't find the info anywhere
2 Suggested Answers
The HVAC Guy
  • 30 Answers
SOURCE: Intertherm Thermostat
the wire that is on the x- terminal  on the old tstat will be c-terminal on the new tstat.
Posted on Oct 30, 2008
Need a wiring diagram for a EEH-012H intertherm
Request the wiring diagram from Hunter and, if need be, Intertherm.
Feb 12, 2018 | Hunter Heating & Cooling
How can I connect an Intertherm furnace with a heat pump to a new Honeywell thermostat?
Ensure that that thermostat is for a heat pump and has connections for the emergency heat strips.
Feb 02, 2016 | Heating & Cooling
My intertherm furnace blower stops coming on. If I turn the thermostat up and down several times it will work properly for about a day. then will start doing it again. I have replaced the thermostat and...
Turn the power off to the unit and use a different color thermostat wire in place of the green wire. If this works, there is a short in the wire. If not it's likely either a relay or a bad motor.
Nov 05, 2013 | Intertherm P3RA-048K Air Conditioner
Intertherm baseboard heater model 1580. Need thermostat
Home Depot carries I believe 2 different T-stats , wall mount, and unit mount. Try there. Or you will need to get it touch with the manufacturer. Also have info, 120 or 240 volt.
Mar 06, 2011 | QMark Portable Hydronic Electric Baseboard...
I have a Intertherm outside AC & it was put in when the mobile home was built(1982) and I do not know what it is, I only can find the name of the manufacture, where would I find the model, & other...
mobile homes have split units, I would check the unit inside to see if it has any information. I would check all breakers inside and out, and thermostat. Hopefully it will be something simple. Good Luck Tim
Aug 09, 2010 | Intertherm P3RA-036K Air Conditioner
Oct 26, 2008 | Heating & Cooling
Intertherm
Is the contactor engaging? Make sure it is getting 24v. If not, check the low pressure safety, outside thermostat (if you have one) and the defrost board. Follow the low voltage from the thermostat to all these controls, up to the contactor. Check the thermostat too. If you need a walk through I can help, if you have a volt/ohm meter.
Mar 02, 2008 | Heating & Cooling
Furnace fan running off and on blowing cold air
Need a little more info. Does the fan never stop? Is this a gas furnace? Is your thermostat in the fan auto not fan on position?
Dec 08, 2007 | Heating & Cooling
Intertherm to Honeywell thermostat
Typically if you have a yellow wire in the "y" terminal blue is used as common or "c". As far as your jumper from rc to rh, that will depend upon what type of heat you have. If all of your heat and cooling come from your packaged unit outside, yes you will need the jumper. If this does not work maybe you have a bad breaker or transfomer.
Oct 12, 2007 | Intertherm P3RA-048K Air Conditioner
Heating & Cooling Logo
64 people viewed this question
Top Intertherm Heating & Cooling Experts
Dennis Boxerman
Dan Webster
Dan Webster
Bill Long
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
