Question about DCS WO-130 Stainless Steel Electric Single Oven
DCS over F7 error beeping
First the keypad number 0 stopped working ,. then the beeping error F7 started. Had to turn of circuit to stop the beeping. Sometimes it will work for a day then it starts again. What do I do?
KEYPAD BUTTONS ARE REMAINING CLOSED FOR MORE THAN 32 SECONDS. REPLACE KEY PAD,DUE TO STERCHED PANEL MEMBRANE
Posted on Feb 17, 2010
Oven beeps and display shows F7
Error F7 means that the keypad is shorted or stuck and to resolve this issue you'll have to replace the Electronic Range control (ERC).
The code can be caused by a faulty keypad or a stuck keypad which may mean relay is turned on. Determine if problem is with the Key Panel or Control by:
a.- Pushing CLEAR/OFF pad.
b.- Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if code come on again, the problem is in the Control. Replace control to solve it. If code does not come on, problem is with the Key Panel
Hope helps.
Jul 07, 2011 | DCS WO-130 Stainless Steel Electric Single...
I am getting an F7 error message more and more frequently. When the F7 message is on the display, my kepad does not work and I get an annoying beep. When I press "Clear" the F7 and beep will stop until the...
Hi
You don't say what type of GE oven this is so I will advise the following;
On a GE range oven F7 indicates either a function pad button is stuck or the clock on the oven is malfunctioning
On the 99 Range oven F7 indicates a shorted Clear/Off Key due to membrane switch or a shorted control or connector
On the GE XL44 Self Clean Oven F7 is Stuck keypad or control relay malfunction
Hope this helps. Please remember to rate my answer. Thank you.
Jul 07, 2009 | GE Ovens
Oven emitted black smoke and F7 beeping on display
F7 stuck keypad
Stuck keypad may mean relay is turned on.
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
Mar 30, 2009 | GE Profile JK915 Electric Single Oven
F7 code keeps flashing on upper oven, nothing on keypad works
A function pad is probably stuck.
Push all buttons several times each. Often this will clear a stuck pad.
If that does not work replace the clock.
Mar 04, 2009 | GE Profile JT910SASS Electric Single Oven
F7 code keeps flashing, nothing on keypad works. I can use second oven with the dial and also my counter range top but the F7 won't go away, nor the beeping. I can push the start button or stop and F7 will...
After much searching, I have found that you have a faulty keypad.
The recommended solution is to unplug the oven, or shut it down at the fuse box, and then remove the faceplate where you can then remove the keypad, and clean the connectors with an eraser, as well as the ribbon that connectes the keypad with the oven.
I hope this helps out.
F7 error steady beeping
short inthe key pad, thinks a button is being preesed for an extended period of time youll need to replace the keypad/ electronic control
Nov 17, 2008 | GE JKP45 Electric Double Oven
My oven wont quit beeping!
It depends on the actual model number (that you didn't supply), but most Kenmore F7 errors indicate a bad keypad or bad control panel. If you unplug the ribbon cable from the keypad to the panel then plug the oven back in and it starts beeping again, it's a bad control panel, if it doesn't beep anymore, it's a bad keypad.
Please unplug the oven power with working on it.
Geno
Aug 02, 2008 | Ovens
DCS wall oven F7 ERROR
I TRIED SOLUTION FROM SYMAR DATED MAR 14, 08 IT WORKED FOR NOW. I HOPE IT WILL CONTINUE WORK UNTIL SERVICING...COME MORNING.
Feb 09, 2008 | DCS WO-130 Stainless Steel Electric Single...
DCS WO-130 Stainless Steel Electric Single Oven Logo
352 people viewed this question
Top DCS Ovens Experts
ray gallant
Appliance Repair by...
Are you a DCS Oven Expert? Answer questions, earn points and help others
