Question about LG French Door Cabinet Depth Refrigerator 21 Cu. Ft. - LRFC21755
LG bottom freezer refrigerator
My 2.5 year old LG bottom drawer freezer is sputtering and not keeping its temperature. There is water collecting on the bottom and a sputtering sound. We have an ice maker in the freezer, but it was never hooked up and it is not turned on.
  • 210 Answers
SOURCE: LG SXS Refrigerator LSC26905 ice maker
LG has a new ice cube tray to solve this problem.
Part number is 3390JA1150A
Sgt 48
Posted on Jun 03, 2008
SOURCE: lg refrigerator LFX25960SW
the answer to the problem from a LG training class is... if the bottom left side of the refer is freezing food the liner has split no fix at this time. some people have beEn able to turn off the ice maker and the food will stop freezing. the ice maker has a fan in the freezer that blows all the cold air up the ice making Cobby.
DO THIS ONLY IF OUTA WARNTEE
for most of you with bad ice makers you could drill a hole in the very bottom of the ice maker towards the front right under the little metal arm in the wight plastic AND DONT DRILL DEEP just enough to put a hole in the outer case then hit it with a blow-dryer for a little bit to remove ice that's blocking the gear on that arm this works 5 outs 10 times
Posted on Oct 29, 2008
david04928
  • 102 Answers
SOURCE: Build up of ice on bottom of LG fridge freezer
Is it supposed to be self defrost? If so then either underneath the freezer needs to be cleaned. coils if dirty will cause freezer not to work well. I that doesn't help you might have a freon leak which would make it under charged and would ice up like that.
Posted on Mar 15, 2009
SOURCE: LG refrigerator model lfx25950tt ice maker not working
I had the same problem and replacing the filter solved the problem for me.
Posted on Mar 22, 2009
  • 161 Answers
SOURCE: LG LRFD25850 French Door, Fix or Repair Daily
You are expereincing poor service. The techs that are working on your unit do not know what they are doing. There is no problem that can't be resolved on appliances. My suggestion to you is to find a really good LG tech in your area to repair this problem. There are only so many things that can cause these problems.
Posted on Jan 22, 2010
Model LFX28968ST. Why is water dripping onto lower freezer drawer?
Richard, sounds like the drain plug/ hole is plugged.
Check the attached links,
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
LG Freezer repair French Door bottom Freezer model
Appliance Repair Forums
LG 819 739 refrigerator not cooling or water leakage how to fix repair by...
How to Unclog Refrigerator Drain Line
Mar 12, 2016 | LG Refrigerators
Water collecting inside fridge, under meat drawer
Yes most responses are the freezer drain even if it is in the bottom freezer. If the drain is blocked water will build up anywhere inside your refrigerator only because it has no place to go during the defrost. Defective door seals can also can make the problem much worse. See Leaking Refrigerators I am here should you need me, Thanks John Tripp Appliance 911
Apr 21, 2014 | GE Profile 22.2 Cu. Ft. Side-by-Side...
I have a 6-7 year old Magic chef top freezer, refrig which is collecting water each day at the inside bottom of the box, refrigerator section. I notice that a slight drip of water comes thru the middle...
The defrost drain is located just under the cooling coils in the back of the freezer. You will need to unload the food and remove the shelves from the freezer. Take the back panel off from inside the freezer and you will see a hole just below the coils. Flush it with hot water using a turkey baster or small hose. See the link below for more details.
Defrost Drain
Jul 21, 2010 | Magic Chef CTB1821AR Top Freezer...
Cold water collects in the bottom space below the drawers
this is just condensation as the fridge is not frost free.try placing a sheet of tissue in the bottom of the salad drawer and one under it, take out about once a week to keep dry
Mar 08, 2010 | Frigidaire FRT21H8 Top Freezer...
Water Leaking From Under LG LRFD21855 Refrigerator
yep, it looks like a frozen drain pipe. to solve it , defrost your frig for 24 hours. if that doesn't help, see the following page for details how to fix it. http://www.schneordesign.com/Avi/LG/LG819_fix.htm good luck Avi
Sep 16, 2009 | LG LRBC22544 Bottom Freezer Refrigerator
Jenn-air fridge
is the defrost drain blocked(ice on freezer floor)
Jun 11, 2009 | Jenn-Air JCD2389G Side by Side...
Water collecting under crisper drawers.
When the refrigerator goes into defrost mode there is a drain tube that allows water melted off the evaporator coil to go into the drain pan that you found empty. That drain tube is clogged.
May 02, 2017 | Whirlpool ET1MHKXM Top Freezer...
Food is freezing in the bottom drawer of my Maytag side by side
check to make sure the slide controls for teh bottom drawer is set to vegtables also it is not uncommon for the temps in the bottom drawer of your refrig to drop down to freezing if you have infrequent door openings. you may also try setting the refrig temperature to a warmer setting as well. thx Peyton
Jan 29, 2009 | Hotpoint HTS20GCNWW / HTS20GCNCC Top...
Roper Refrigerator
open the freezer compartment loo for ice build up on floor of frezer especally towards rear behind back panel. sounds like you have a clogged/frozen defrost drain tube. removing back panel of freezer will give you acess to drain trough, melt away the ice with a hair dryer, youll find a drain hole under there somwhere,pouring boiling water down the drain will clear it pretty quickly( i use a steam machine purchased from the infomercials)
Mar 05, 2008 | Roper RT21AKXKQ Top Freezer Refrigerator
LG French Door Cabinet Depth Refrigerator 21 Cu. Ft. - LRFC21755 Logo
51 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
