No Picture on AV
My Magnavox Smart Series 13" suddenly lost picture in AV. This happened a while ago and after leaving if off for about a week it suddenly was back. It happened again after the Dish Technician came to install a new hd receiver in my living room where I get the signal for the small tv in my loft above the living room. I use a Leap frog set from Radio shack to watch the same programing up stairs as down. The new receiver doesn't have enough red, yellow and white plugins for the leap frog sender unit so I found the output on the back of my hd tv, but no picture now. Suggestions?
I tried everything in the menu, but no go.
Thanks for any help you can give me,
Paula in Montana
It was not a problem with the TV. I needed to purchase Y cables so I could run my audio to both the HDTV and the Leap Frog unit for Magnavox. Then just plug the yellow cable directly into the back of the reciever. Viola!
Thanks for your interest,
Paula in Montana
Posted on Jul 26, 2008
Samsung LED UA40F6400 suddenly lost picture.
The tcon board or the LCD panel is faulty. You have to replace the TCON board to confim the fault.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Aug 06, 2016 | Samsung 40 Inch UA40F6400 Full HD 3D Smart...
No picture showing after power on.
If this does not happen with other devices then I would say try a new video cable. HDMI cables can get very picky. If this happens at anytime then the inverter in TV is going out.
Sep 19, 2015 | Panasonic Viera Tc-p65vt30 3d 65 1080p...
Av channel
unplug it for 5 or 10 minutes then plug it back in turn it back on run it thru the setup program
Sep 27, 2009 | Philips Magnavox 13MT143S 13" TV
JVC D-Series TV top of picture shrinking
There are probably two capacitors that are bad in the vertical circuit. Not too hard to replace if you have any experience at all. Find the vertical output IC ( usually IC451 or similar ) and simply change the closest electrolytic capacitors. A professional can do this easily. Could cost up to $150.
May 13, 2009 | JVC AV-27D302 27" TV
Televion was purchased in 2002 picture was sharp
Need more information.
Are you connected to an antenna?
Did the stations in your area go digital? (DTV converter required)
Mar 02, 2009 | JVC AV-27530 27" TV
Everything works except picture
Most probable cause is the vertical output IC. You can get a replacenment at the following link.
http://servicemanuals.vstore.ca/
Feb 02, 2009 | Philips Magnavox 51MP392H Rear Projection...
Old Sylvania model #6420FB lost remote how to switch to av mode
Unless the TV has a front-panel menu button and allows you to switch modes from there, you are out of luck. There are two possibilities. One is to try another replacement remote. If you get a universal remote made by the TV manufacturer (Magnavox), it may have buttons that will work. The other option is to purchase an RF converter, which will cost around $15. This will take the video/audio signals from the game and convert it to a channel 3 or 4 signal you can then tune in on the TV. The picture won't be quite as bright and clear as with direct AV input, but it will do the trick.
Jan 11, 2009 | Durabrand BH1304D 13" TV
Sound but no picture
GE TV CTC 203 the oicture is very cloudy
Dec 14, 2008 | Televison & Video
27 in Magnavox Smart TV
problem in vertical circuit 100uf 35 volt cap also could have poor solder connections on vertical ic
May 02, 2008 | Philips Magnavox 20MS233S 20" TV
Magnavox Mod. # HD 2715 C 202
Your set in in closed caption mode text 1....Go into your menu and un-do the closed caption mode.
Feb 18, 2008 | Philips Magnavox 27MS343S 27" TV
Televison & Video Logo
109 people viewed this question
Top Televison & Video Experts
