I have problem with tuner the our Tivi Toshiba Regza 32c3500e. When tivi is ON the picture is terible for temporary ( snowy and colours are not good ) and then automatically the picture good without any to do something and vice verca to many time.
I wont to help our tivi problems. Thangking you
Said Joenaidi - Jakarta - Indonesia
Hello press and hold the POWER button • You must configure the ANT/CABLE input source before programming channels (-left-hand column). • If the ANT/CABLE input signal type is set to Cable, the automatic channel programming process erases channels that were previously programmed into the TV's memory. • If the ANT/CABLE input signal type is set to Antenna, the automatic channel programming process adds newly found channels to the existing set of programmed channels (and does NOT erase channels that were previously programmed into the TV's memory.) To remove an Antenna source channel from the memory, you must manually delete it. • To tune the TV to a channel not programmed in the channel memory, you must use the Channel Number buttons on the remote control. • Programming channels when the ANT/CABLE input is configured for Cable will take substantially longer than when the antenna input is configured for Antenna. This is normal; however, once channel programming is finished, you should not have to repeat the programming process again unless
First of all reset the TV. for that
on the TV control panel for 5 or more seconds to reset the TV.
Then connect the TV tt any source like outdoor areiel or cable box etc, select the appropriate input, and retune the TV. First of all, connect it to an external antenna, and set it to autotune.
your Cable TV service lineup changes significantly.
Find out the received channels are clear or not. If they are clear, your TV is perfect, and the input device you connects ot the TV is faulty. OK.
