Question about Memorex MMP8565 MP3 Player
I cant sync songs
Every time i try to sync it and delete my old songs, it says it cant change the sync settings. if you can help it would be greatly appreciated
On mine, I cant delete just one mp3, I have to completely trash my whole library
Posted on Aug 18, 2008
I can't delete songs off my iTouch without restoring.
ok what u have to do is this,
find the songs u dont want anymore and uncheck them in itunes and find the songs u want to add and check them, now go to itunes settings and change the syncing options to sync only checked items and then sync the ipod and the stuff u want gone will be gone a the stuff u want there will be there. :)
Mar 01, 2009 | Apple iPod touch
Current files on gogear mp3 cant be replaced.
The HDD6330 doesn't respond well to Windows Media Player 11 - I know it's a pain, but you may have to rollback to Windows Media Player 10 to get it to display correctly (don't worry - you will not lose your existing files by doing so).
-Tha Mp3 Doctor
Feb 04, 2009 | Philips GoGear HDD6330 MP3 Player
I cant delete songs off of my mp3 player
I can't delete my songs. I have tried 4 different media player to delete and they all give me an error message. Failure to delete, not responding can't delete etc... What should I do? I have the pink ilo 1GB mp3 player
Aug 20, 2008 | iLO MP3 Player
My Olympus m:robe MR-500i MP3... Problem:
try:
click Start>Run then copy and paste the following:
C:\Documents and Settings\Username\Application Data\
replace 'Username" with the name of your user account and press enter
In the new window, find olympus and make sure there are no important data in it and delete the folder
then do the same in
C:\Documents and Settings\Username\Local Settings\Application Data
You will need to re-syn your m:robe and re add songs.
Or you can try sync on a different computer and resync on your own computer
Aug 12, 2008 | Olympus m:robe MR-500i MP3 Player
How do I delete songs from my player ?
Did you try changing the usb mode?
settings/usb mode (down at the bottom)
Try changing this to MSC mode.
I hope that helps.
Aug 02, 2008 | SanDisk Sansa e260 MP3 Player
I can't load no more than 60 songs
You have auto-sync enabled - disable it
Disable auto-sync in Windows Media Player - Microsoft's website explains it far better than I can
Open Windows Media Player WITH the mp3 player connected
Highlight Sync, click on the arrow to bring down drop-dow menu
Select Set Up Sync
Uncheck box that says "automatically sync files to device"
Jun 20, 2008 | SanDisk Sansa E280 MP3 Player
I cant delete files from my Sandisk M250 mp3 player
Just called Scan Disk if the device got a setting wrong:
Turn the Scan Disk on:
Go to Setting;
Select USB
Change the selection to Autodetect
Go back to Windows Media player the songs should show up..Worked for me.
May 18, 2008 | SanDisk Sansa m250 MP3 Player
Auto deleting songs we wanted there argghhhhh!
If you are using Windows Media Player to synchronise the MP3 player, you need to change the Sync settings, from auto to manual.
If the Sync option is set to Automatic, then Windows Media Player will synchronise your PC and your player, so they have the same tracks. Unfortunately, if a track is deleted from the PC or the MP3 player, then Media Player will delete it from the other.
However, Media Player may have only deleted the tracks from its library, and not from the PC. If you go to My Documents ----> My Music, you can see if the files are still there.
The Manual sync setting allows you to drag and drop files from the Media Player library on to your player as you wish.
Assuming you are using Media Player, connect the MP3 player to the PC.
Open Windows Media Player.
Right-click the Sync tab and select Tools -----> Options.
Click on the Devices tab and select your player from the list then click properties.
In the window that pops up, click on settings, then click the button next to manual to change from auto.
Click on Finish, then close the other windows by clicking on Apply or Ok, until you are back to the main Media Player screen.
You should now be able to transfer your tracks manually.
If this doesn't work, give more details, including make and model of player, and the software you are using for transfer, and I'll try to help further.
May 14, 2008 | Audio Players & Recorders
Deleting
Plug in your sandisk into the usb driver, click on my computer you should see SANSA M230 (F:) right click on it, you should see format, click on format. And finally click on quick format, then start. That should do the trick. Note it erases all songs. Your welcome! :)
Jun 12, 2006 | SanDisk Sansa m230 MP3 Player
Memorex MMP8565 MP3 Player Logo
51 people viewed this question
Top Memorex Audio Players & Recorders Experts
Henry  Thomas
Henry Thomas
Are you a Memorex Audio Player and Recorder Expert? Answer questions, earn points and help others
