Question about Epson Stylus Pro 4800 InkJet Printer
Switching from sublimation ink to ultrachrome ink
I am no longer in the sublimation business. Is it possible to switch over from sub ink in my 4800 to epson Ultrachrome ink? Are the Lyson cleaning cartridges an easy fix -- or am I better off selling the printer as is to another sublimation company? Thanks for your advice. Karen
email: karen@estreet.com
  • 33 Answers
You can keep the machine, just flush the system fully before loading the new inks.
Posted on Nov 19, 2008
Heat transfer mug without coating
Hi!
Sublimation Printing is the most common printing method on mugs. By theory, sublimation is offset printing from a transfer paper to your substrate (which is your mug). Mug Coating is important since the coat is composed of Polyurethane paint which is where the Sub-Inks adhere into. Without a Polyurethane coat, the Sub-Inks will not stick to the surface of the mugs. What you can do in order to print on non-coated mugs is to coat those mugs yourself using Polyurethane paints that you can buy at hardware stores. These are usually used in automotive painting and may cause you a bit for each can.
You have to remember though that Polyurethane paints dries longer than enamels and prolonged exposure to these types of paints is hazardous to your health.
It would still be best for you to look for pre-coated mugs to save on production time and, well, efforts.
And yes, I have tried the above tricks personally as I am also engaged in crafts business...
Mar 25, 2014 | Canon Selphy Cp-800 Dye Sublimation...
I have an epson r 230 printer i have a problem that i cannot get its inks i have a ccs system fitted i am using a fine tone sublimation inks
HI, you can use any sublimation ink suitable for epson desktop printers. The sublimation ink is not specifid for model, it's work on every epson destok printers
Mar 08, 2011 | Epson STYLUS R230 InkJet Photo Printer
I just purchased the Ricoh GX7000 for sublimation. Unfortunately, my son set up the printer and did not realize the inks that come with it are not to be installed. He did. I have not printed anything, but...
I would call your vendor. Or if you bought the sawgrass technologies ink, give tech support a call and have them help you download the necessary ICC profile for your printer. Often they can walk you through setup. You will need to delete the current one you son installed.
Narri
Nov 04, 2010 | Ricoh A3 Gel GX7000 InkJet Printer
Add sublimation ink to cartridge for epson c88
The CISS are auto resetebale? If not, you must get a CISS with an autoreset button to get the printer work with the CISS
Oct 06, 2009 | Epson Stylus C88 InkJet Photo Printer
What do I have to do if I want to use sublimation ink on Epson stylus photo 1290?Thanks
what you want is not possible. the Epson Stylus Photo 1290 does not use sublimation ink. it is strongly advised to only use genuine Epson ink to keep the print quality of your print head as high as possible.
Jun 22, 2009 | Epson Stylus Photo 1290 InkJet Printer
Font not Printing.
Try reinstalling the print drivers.
May 29, 2008 | Epson Stylus Pro 4800 InkJet Printer
Not Printing some font
Sometimes, if you have a long USB cable, the information becomes corrupted. Try using a USB booster or a shorter cable.
Epson Stylus Pro 4800 InkJet (Color printing problems)
If you do a nozzle check...do a cleaning...then do another nozzle check, you can "read" the patterns to see exactly what the problem may be. If the first nozzle check is missing half, then you do the cleaning, and the second is missing half also, check the pattern of the box to see if the missing nozzles are jumping around. If the pattern is exactly the same, you have clogs. If the pattern jumps around, you are having ink starvation issues, and may need dampers.
May 19, 2008 | Epson Stylus Pro 4800 InkJet Printer
Epson Stylus Photo R265 icc problems
Do you mean you are using OEM lookalike cartriges or are bulk refilling cartridges with non-Epson ink?
Thats your answer!!!
Feb 12, 2008 | Epson Stylus R265 InkJet Photo Printer
Epson Stylus Pro 4800 InkJet Printer Logo
182 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
