Well, if you have a pc suite provided by the HTC then install it and try to connect through it. If not then connect Bluetooth to your PC and install the Bluetooth drivers which are provided with the dongle then connect your device via bluetooth. This will install your modem drivers as well and now search for your devices in my bleutooth places in your pc and go step by step. Select the connect to internet option in it. Who-la you will be now connected to internet. If you have a Bluetooth and need drivers then search for bluesoleil software.
Two methods are there to use your phone as modem
1)you can use your PC suit to use your phone as modem
You need PC suit software provide by SAMSUNG
To use your phone as modem
*install the pc suit software
*Open PC suit and select "Connect too internet"
*if its failed you can use manual setting by selecting "Connect to internet">Select access point>select the name of network operator from the access point list(if you did't get your network operators name in the list you need to contact your network operators customer care they provide the access point name you need enter this access point in the manual updation list and try to connect now.....
2)you can use Bluetooth technology to connect to internet
For this you need
*Bluetooth on your PC and phone
To connect(in windows OS)
*Click on Bluetooth symbol on task bar
*Select add device select from device which can be connected to your pc list(set your bluetooth device to visible mode)
*Add your device to your pc
Add completion of the above...
*Again click on bluetooth symbol on task bar
*Select "show all devices"
*now select your device(one click) at this time 4 options appears on top your devices list
*select connect using>access point
and 2nd method is *Again click on bluetooth symbol on task bar
*double click on your device
*select connect to internet from the dialog box which appears after selecting the
your device
Thank you
many mobile phone companies dont provide drivers for linux.
But there is a software i would personaly recommend to you. Actually its not a software, its a shell script. Name of software is "Sakis3g". It can connect to mobile phones and other mobile devices which can be detected by linux kernel. You can use IR, Bluetooth, even USB cable to connect to your device.
You can use this software for the following
connect to mobile devices by IR, bluetooth, USB Cable
Send and receive files between computer and device
Access Internet from Device by Dial Up Networking
Browse files on Mobile device
Mount the mobile device on a user specified mount point or communication port. usually it mounts connected mobile device to /dev/rfcomm0. Through this port, you can communicate with the device .
Connect to USB Modem (Like Reliance DataConnect, TATA Photon, IDEA Netsetter etc.)
ability to connect to any locked/unlocked USB internet Modems (Zero Devices)
fully automated connection setup. No manual input is needed except to specify connection name.
You can find more details and download Sakis3g from this address http://www.linuxconfig.org/mobile-broadband-connection-and-sakis3g
S u can use ur samsung mob phone as a modem and connect internet in ur pc. use usb bluetooth dongle or usb data cable to connect ur phone to pc. either use pc suite or bluetooth software(Bluesolil) for connecting internet. Samsung e1410, samsung e250 etc are the models compatible
For you to be able to connect to the internet using your nokia 7210 supernova as a modem, you must do the following;
1. First download the nokia PC Suite from Nokia site http://www.nokiausa.com/get-support-and-software/product-support, select your device, leave the accessory and move on to select the service & software"
2. You then move ahead to download and install the Nokia PC suite on your computer. After successful installation, please run it.
3. Double click on the icon for the nokia pc suite on your desktop, once it is running look for the button that has "connect to the internet", it is the green globe with 2 arrows on it.
4. Once you get that double clicked, it takes you to a pop up that would now enable ypu connect to the internet via your service provider. Click on configure on the lower end of that window.
5. Click on the modem that you'll be using for the connection (bluetooth, USB cable) and click next.
6. After that process you would then be prompted to select your network operator from the list, once you do that you can then click finish and allow it connect.
After some couple of minutes yu'll be connected to the internet using your phone as a modem.
It depends upon the connection you have on your phone. To acess internet from your mobile go to the homepage of the company's connection and follow the instructions one by one.
