Question about Dryers
Dryer leaves burn marks on clothes and it always has since it was new, how do you solve this?
  • 1 more comment
  • snakyjake Jul 27, 2008
    I have the same problem of the dryer leaving burn marks on clothes. I think the burn marks are coming from the edge of the tumbler near the door. Anyone know what is causing this and how to fix?
  • banangel Nov 08, 2008
    I have the same problem but my dryer is only about 8 yrs old. Small clothing tags, dress shirt collars and even in the middle of a garment gets brown marks. I have a Kenmore Heavy duty, gas, stainless steel model. I use the dryer balls (2) to help lift the clothing during the drying process but something gets marked anyway. I use Zout spot cleaner to remove the stain and wash with another load at a later time.
  • ozzietheboy Jan 07, 2009
    I started buying non iron shirts for a few more dollars to save money from sending to the cleaners but now the corners of collars sometimes have this brown mark which doesnt come out! Why is this happening and how do I solve the problem?
Usually caused by the drum felts going bad, hard part to find for older dryers as I am finding out
Posted on Aug 10, 2008
docjohn174
  • 943 Answers
SOURCE: Dryer Leaving Burn Marks On Clothes
HI thanks for your question. the problem with your dryer, is that the front felt bearing is worn. and dropped the drum a bit and clothes getting caught. replace the front bearing and the back bearing. not too expensive. thanks the appliance doc. please rate my question. thanks.
Posted on Oct 09, 2008
  • 686 Answers
SOURCE: Dryer is leaving burn marks on clothes on any temperature.
change your cycling thermostat. It is not telling your heat element to shut off at the rated emp
Posted on Mar 12, 2009
  • 10865 Answers
SOURCE: My dryer leaves burn marks on the clothes. What
Hi. Thanks for using fixya. I can help you. When clothes get marked or torn in your dryer, check these: Rollers Your dryer may use rollers, or wheels, to support the rear of the clothes drum. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the rear of the dryer interior. When the rollers wear out, you need to replace the whole set. Rear seal Your dryer may have a felt-like seal at the rear of the drum. If this seal is worn, torn, or missing, clothes can get caught and torn in the space between the clothes drum and the rear of the dryer interior. When the rear seal wears out, you need to replace it. Front glides Your dryer probably uses nylon or plastic glides at the front of the clothes drum for support. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the front of the dryer interior. When the glides wear out, you need to replace them as a set. Front seal Many dryers have a felt-like seal at the front of the drum. If this seal is worn, torn, or missing, the clothes in the dryer may get caught and torn in the space between the clothes drum and the front of the dryer interior. When the seal wears out, you need to replace it. small_8_13.jpg
Posted on Nov 09, 2009
marka19
  • 1430 Answers
SOURCE: Dryer leaves black marks on clothes
Front bearing assembly or just the slides. Easy check is open the door reach in and push up in the front if the drum has play replace bearing assembly or maybe just get away with the slides if it hasn't eaten in to far. To replace watch the video at www.appliancehelponline.com/servicemanual.html
Posted on Feb 26, 2010
Zeevert
  • 373 Answers
SOURCE: The dryer is leaving what looks like brown burn marks on clothes
The marks are coming from your dryer seal. I had the brown mark problem on my Whirlpool LER4634EQ1 Dryer. It turns out that the inner drum seal wore the paint off the pilot diameter on the inner wall. The pilot diameter rusted and the rust transfered onto the seal. The marks on the clothes are rust marks. I replaced the seal on my dryer, but don't know how long it will last. You may need to try and paint the pilot diameter. The seal with glue was $34 delivered from pcappliancerepair.com. Here's pictures of the rust: http://s2.photobucket.com/albums/y48/ZeeVert/Whirlpool%20Dryer/
Posted on Jun 11, 2010
Kenmore stack dryer burns clothes
HI CAROMIA.unusual but check basics first1-dont overfill 2-no sintetics and nylons.if still burns its obviously overheating.3-check vents.hope this helps.ali
Jun 20, 2012 | Kenmore Dryers
MY FRIGIDAIRE ELECTRIC DRYER IS LEAVING BURN MARKS ON CLOTHES,WHAT IS CAUSING PROBLEM
Assuming that you have the correct temperature selected for your clothes, there are two likely causes:
If the clothes are showing randomly shaped burn marks, the dryer is overheating. This would be accompanied by a burnt smell on the clothes. The high limit thermostat is the culprit.
If the burn marks are dark streaks, the clothes are getting pinched between the drum and the inside of the dryer that does not move. This is caused by worn bearings, slides or rollers. Should you choose to repair this yourself, there is a great deal on a kit with all of the parts you need plus a new belt for only $32 here:
http://www.repairclinic.com/PartDetail/Drum-Bearing-Felt-Seals-Pulley-Belt/5304461262/1261075
Good luck from Detroit, Mi.
Jul 20, 2011 | Frigidaire GLER341A Electric Dryer
Leaving burm marks on clothes
its getting to hot,,,check its air intakes to see if there blocked up and also the hot air outlets (hose pipe) if thats blocked up change it
Jul 10, 2010 | Hotpoint NBXR333EGWW Dryer
I have a 2006 Whirlpool Duet Electric Dryer that leaves brown marks on my cloths. I have cleaned the inside of the dryer per the manual's diretions, but it still leaves the marks. They almost look like...
Usually, if you are getting brown streaks or marks on clothing, one or both of the drum seals are going bad. Clothing will drag between the bulkhead and the drum, leaving brown marks. If you want to do the repair yourself, I can provide instructions, otherwise call for service.
Dec 30, 2009 | Whirlpool GEW9250 Electric Dryer
you might need to replace the felt on the inside front that the tub rides on
Apr 23, 2009 | Dryers
Jan 21, 2009 | Whirlpool GEW9250 Electric Dryer
Oct 09, 2008 | Dryers
Kenmore dryer leaving brown burned lines on clothing
the rear drum seal was bad and as things rub against it they will get black marks on them.
Larry
Aug 02, 2008 | Whirlpool GEW9250P Electric Dryer
Dryers Logo
606 people viewed this question
Top Dryers Experts
