Question about Sony Playstation 3 (PS3) Console
Wireless connection ip????
I checked the status and it is 'enabled'. but when i do a connection test it still does the same thing.
  • 2,071 Answers
Enabled means your connection is OK it's running,then click support to appear your IP address;
Don't forget to rate;
Posted on Jul 27, 2008
How do I find the Printer IP address
Test the wireless connection
Print the wireless test report for information about the printer wireless connection. The wireless test report provides information about the printer status, hardware (MAC) address, and IP address. If the printer is connected to a network, the test report displays details about the network settings.
To print the wireless test report
1. From the printer control panel, touch (Wireless), and then touch Settings.
2. Touch Print Reports
3. Touch Print Wireless Test Report.
Apr 09, 2016 | HP Officejet Pro 8610 Wireless All-in-One...
I cannot get my laptop to connect to the internet either wirelessly or hard-wired. I have two other laptops, connected wirelessly, and a desktop connected via hardwire. It recognizes the router but says...
if you are trying through wireless, first unplug the wire from the laptop,
make sure that the wireless switch on your laptop is turned on.
click on start, control panel, network connections/network & internet/ Network and sharing center..
right click on wireless network connection Icon, if it says disable, it means it is enabled already.
then click on status..
from here the steps would differ from OS to OS
then click on Support tab (for XP)
check the address type, it should be "Assigned by DHCP"
and if you see the IP Address starts with 169., it is a bad IP and needs to disable the connection and enable it.
if the connection type is "Assigned Manually, right click on wireless network connection icon and click on properties and click Internet Protocol(TCP/IP) and click on properties, in this window, check the option "Obtain IP Address Automatically from DHCP"
click ok and OK ..
again right click on the wireless network connection icon and click on view available networks... click on your router name and click on connect..
now check the functionality.
if you are using windows 7 or vista,
click on status, click on details for the IP Address..
We see DHCP Enabled as YES or NO instead of "Adress type"in XP
if it says no, it means it is assigned manually. to change to DHCP , right click on Wireless Icon, select properties, click on IPV4 IP address and click properties, then select obtain automatic..
then try again..
hope this works,
Narendra Tirunahari
Feb 18, 2010 | Gateway 7330GZ Notebook
When I try to log into internet it says windows cannot figure this wireless connection. it was working before. i am afraid i have disabled something by accident.I am technically challenged.
The best thing you should do is remove the softwere of the wireless router then install it again using the CD provided with the wireless Router.
Feb 13, 2010 | Dell Latitude D600 Notebook
I am trying to setup up my wireless router so it will connect with a laptop i already have two desktops connecting to the internet but the laptop will not connect
things to check:
1. is your wireless network adapter on your laptop enabled? check under network connections and check the status of the wireless adapter, enable if required. (it could be disabled or the switch (if the adapter is built in) may be off.
2. once enabled configure your network adater to receive network configuration automatically, go into the network adapter properties, go down to protocol tcp/ip, select it and then click the properties button, select the "obtain and Ip address automatically" and select " obtain DNS server ip address automatically" hit ok, and ok again,
3. does the router have any key configured. if your router was set up by someone and this person configured some basic security on your touer he/she should've given you a network key and router name, that's how you can connect wirelessly to your router. find that info and attempt to connect the router by going into your wireless networks. if the name of your router is not visible, it may still be there, so you may have to type it in.
I don't know how computer savy you are,... if you need further explanation on any of the points above.. feel free to ask... and we'll guide you further or you find out what version your router is (ex, v1, v2, v3..v9) and check the documentation for your specific router's set up and user guide from this link
good luck!
good luck!
Nov 16, 2009 | NetGear WGR614 Wireless Router
Wireless connection
Start->Settings->Control Panel. Double click in Internet Options.
On the Connections tab, click on Never Dial a Connection. While you're there, click on LAN settings. Automatically detect settings should be checked, but normally nothing else should be checked.
If this doesn't help, you may need to rebuild the stack:
Start, Run, CMD to open a command prompt.
Reset WINSOCK entries to installation defaults: netsh winsock reset catalog
Reset TCP/IP stack to installation defaults. netsh int ip reset reset.log
Reboot the machine
Apr 16, 2009 | Computers & Internet
Wireless connection to internet wont work
What Operating System - is it Windows?
Assuming it is, go to the Start menu, and go to Network Connections. Click on the Wireless Network Connection on the right hand side - and view the Status. Is it disabled - then simply right click and enable it. Is it "Not Connected" - then you must attempt to connect to your wireless router. If that's the case, then right click on it and select View Available Wireless Networks, and then once you have that window open - choose Connect.
Apr 02, 2009 | NetGear Super G Wireless Router
Limited or no Wireless connection
It appears that the TCP/IP got disabled or removed.
Check the TCP/IP settinge of the wireless adapter, it should be the same as the network adapter.
Feb 09, 2009 | IBM ThinkPad T41 Notebook
I cant get virgin netgear router to connect to my medion laptop, i get to the last part of the installation process when it says attempting to connect to newtork and it comes up move your connections...
Have you accessed and setup your wireless part of the modem?
To access the router settings menu, you will first need to log into the Wireless router following the steps below:
Open Internet Explorer
In the address bar type the following address:
You will be prompted to enter a Username and Password to access the interface, please use the following default details:
Username: This can be found on the bottom of the router
Password: This can be found on the bottom of the router
From the list on the left hand side, click on ‘Router Status’.
Within the Router Status section there are two areas you will be able to access:
Show Statistics
Connection Status
The Router Status page gives you a detailed status overview of the connection configured on the Wireless router.
Click ‘Connection Status’ to see more information on the broadband connection.
If you have already configured your broadband, you are able to establish/terminate the connection by clicking Connect/Disconnect.
You can also click ‘Show Statistics’ to show you current connection speed and more information on your Broadband connection.
Clicking on Basic Settings enables you to check all the Internet settings of your Broadband connection. Including the Login name (username) and password, IP address and type of connection.
Clicking on ‘Test’ will perform a standard check of your Internet connection and settings.
The ‘ADSL Settings’ section provides you with some more information about your Internet connection. These are:
Multiplexing Method
This section gives you full information regarding the Wireless connection. From here, you can change security settings, the SSID (Name) of the router and the access control list. Options list from:
Name(SSID) virgin broadband (default)
Region Europe(default)
Channel 11(default)
Mode g&b(default)
Enable Wireless Access point
Allow broadcast name
Security options (None, WEP and WPA)
- hope this helps
Jul 03, 2008 | Computers & Internet
Connection to ps3 drops in and out
GO to network settings...Check out Settings and Connection status list...make sure everything is enabled, wireless, and Automatic....reset your connection..and ur router....turn off the WEP disable....
internet connection : Enabled
connection method : wireless
signal strenght: 100%
SSID : (name of your wireless router)
Security: i set one really cares to hack ur PS3 ppl turn this off
Address settings : AUTOMATIC
Feb 11, 2008 | NetGear DG834G Router
Sony Playstation 3 (PS3) Console Logo
13 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
