Question about Frigidaire FRS26R4A Side by Side Refrigerator
Water from the water dispenser
Should it be cold? Mine is not. I just bought a used 2 yr old FRS26R4A side by side. Everything works great except I dont know if the water suppose to be cold. If it suppose to be cold why isnt it and where is the water holding tank located? Is it located in the refrigerator section? Can you get to it. My temps are good in the freezer and frige side.
  • 725 Answers
The first glass will not be cold. the water line runs thru the bottom and up the door. the compressor and condencer are under there and alway put out heat...the 2nd or 3nd glass will be chilled but not ice cold,,
sorry but I think the designer must like lic in there water...
by the way the tank that is a coil of tubes is in the back/bottom of the refrigerator.
hope it help let me know
Posted on Jul 25, 2008
Ice maker quit making ice how to find problem
Good Morning Friend,
I understand that your Frigidaire refrigerator, model# FRS26R4A, stopped making ice. Here are a couple of suggestions you may try, to get your ice maker to produce ice.
    1)Make sure that the wire signal arm, inside the bucket area, is in the down or ON position.
    2)Make sure your household water line valve is open and on.
    3)Make sure your freezer is cold enough.
    4)Make sure the water dispenser is dispensing water. If not, the ice & water filter cartridge is clogged or restricted by foreign material, and must be replaced.
    I hope this is helpful.
    -Best Regards-
May 22, 2014 | Frigidaire FRS26R4A Side by Side...
Water underneath the freezer section
Please check for the water passage beneath the freezer. There will be a small pipe and there is a possibility that that pipe path is blocked with ice or dirt.
Mar 19, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Plastic Water Line Coiled Inside the Refrigerator
The coiled line is used for chilling the cold water dispenser. Most of the time they are hidden from view,
Mar 16, 2017 | Frigidaire FRS26R4A Side by Side...
The water from my water dispenser isn't cold.
Hi, Only thing you can do is check the temperature in the fresh food section and it should read 34-27 degrees. The temperature controls should both be set at half of the #'s on the dial.
I hope this helps you. Please let me know if I can assist you further.
Jun 05, 2009 | Whirlpool GD2SHGX Refrigerator
No water coming out of dispenser
sound like a crud in the line somewhere. Shut the water off, remove the filter element, and blow air in the water dispenser. If that doesn't do it, remove the line after the shut off, and blow air in before the filter.
Thanks for using Fixya
Have a nice day!
Mar 13, 2009 | Frigidaire FRS26R4A Side by Side...
Water dispenser dripping
The seat in the door valve has probably failed or has some trash in it.
Jan 20, 2009 | Frigidaire FRS26R4A Side by Side...
Water to ice maker isn't filling tray.
what is the inside temperature in the freezer? it has to be below 17 degrees before the ice maker even try's to work
Dec 11, 2008 | Frigidaire FRS26R4A Side by Side...
10 yr old Frigidaire ice maker stopped making ice
try forcing the cycle by manually triggering the cycle a few times. Sometimes you can detach the trip arm or turn the tray by hand by disconnecting it from the gear. There may have been a switch bumped to turn it off or the switch somehow jammed. Maybe check for freeze-up. If there is water in it, it's going somewhere.
Sep 27, 2008 | Frigidaire FRS26R4A Side by Side...
GE ESS25XGMC WW Side by Side
its possible that your water tank has frozen up, try turning the refrig off and leave the doors open for about 10-15 mins and try it again. if that works just reset temp controls a little lower..
Dec 15, 2007 | GE GSH25JFR Side by Side Refrigerator
Frigidaire FRS26R4A Side by Side Refrigerator Logo
142 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
