Question about Compaq Computers & Internet
My monitor does not show anything cuts on then goes to standby
  • 300 Answers
If you are sure its connected correctly and tightly it sounds like a bad video card to me.
Thanks
Posted on Jul 25, 2008
How do I turn off the Samsung sync-master p2050 monitor?
If it doesn't turn off by holding the power button down for 10 seconds, then it cannot be turned off by the power button alone, like most modern lcd monitors. Most modern monitors goes into standby mode. To completely cut power, you must unplug the power cable.
I've enclosed a link to the install manual for reference.
Samsung SyncMaster P2050 User Manual Page 7
Nov 24, 2014 | Samsung Computers & Internet
After post screen monitor goes into standby and cannot boot from dvd
Not picking up video card, or rather losing communications. Use VGA port if available on you card, and make sure monitor is set to same connection port.
Nov 11, 2012 | Computers & Internet
Monitor keeps showing "Check signal cable"
Well, at least you got it sorted out and everything is working fine now.
Apr 21, 2012 | Samsung SyncMaster 2493HM Monitor
My 43inch nec plasma, will not pick up an incoming signal. it switches on (blank screen), but after around 20 seconds, it goes to standby.
It's going into standby because it's not receiving anything on another end for a set period of time. Be sure to check certain aspects of the monitor if you are connecting it to a PC.
Check if the PC is on first. Obvious, but youd be surprised. Make sure both cables are connected firmly and securely. Also make sure you're using the right cables. If the monitor has multiple inputs, try toggling through them If it still doesn't work, check if the computer is outputting signal on another monitor.
Hope some of these tips help
Mar 06, 2011 | NEC PlasmaSync 42PD3 42" Monitor
I put my acer aspire one laptop into standby by putting down the monitor which automatically lock the laptop but then when i use it again the monitor is dark and i cant see anything. the power is on and i...
ok, press the Power button on the Laptop once, and if nothing happens, press the power button again but this time hold it down until it goes off... then remove the battery for 2 minutes, after that put the battery back and press the power button, it should power on and the monitor will show. (Do not plug into power source during all the above process).
Bams Tech.
Dec 02, 2010 | Acer Aspire One Netbook 8.9" Notebook
When I turn on my monitor, its goes straight to a
  • when you turn on computer. after sometime your monitor goes to standby mode and monitor light colour will be orange it means problem with your computer not monitor.
  • After this You Check your VGA Card.
  • When you turn on computer is there any beep.
  • After this also check your RAM.
  • May be problem with your RAM.
Try this Technique .
Mar 13, 2010 | HP w1907 LCD Monitor
My monitor cuts out after about four seconds
ludwighro805, If Lucky Goldstar warranty not valid option, or LG cash+ old unit refurbished swapout then you will need to repair unit or contract out the work to technician that fully understands failure mode of unit W1934S. Get into my FIXYA profile and READ, READ, READ. Your unit good candidate for repair. Your unit CLASSED as "BLACK" or "BLACK and BLANK" screen failure due to possible POOR factory reflow soldering process. If you do the research you may even want to try a DIY fix. If this info helpful, please rate this response on FIXYA. Good luck with repair. Explore your options before doing anything. Do an additional comment if you still require assistance. 12fixlouie on fixya
Jan 05, 2010 | LG W1934S-SN 19-inch Widescreen LCD...
My monitor shows "auto detection mode
make sure the video card is securly placed in the pci-e slot
Aug 19, 2009 | Dell E228WFP LCD Monitor
Monitor wont stay on when you start computor,its goes green for 5 seconds then straight back to standby,monitor works fine on my other computor.
Its totally ur internal CPU problem.
checkout ur motherboard, microprocessor & fan also from wellknown person.
Dont do anything at home.
Aug 06, 2009 | MSI K8MM-V Motherboard
IBM intellistation M Pro
Test the monitor on another computer , if it shows any display of windows then you have bad vidoe card , but if monitor does not show anything on another computer then the monitor has died .
Jul 27, 2008 | IBM (33P0825) Motherboard
Computers & Internet Logo
15 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
