Question about HP 1040 Plain Paper Inkjet Fax
How do you get it to fax only?
How do you get the machine to fax only status?
    Genius:
  • 2,120 Answers
Need more info.
Scroll thru the menus, set the machine to manual mode; it will only receive the fax if you push start.
Posted on Sep 01, 2008
How to clear the job status memory on the Toshiba eSTUDIO 305 Machine
if there is a username and passowrd you log in. then at the bottom right of the screen you will see a job status button. if you press it it usally opens up to the jobs list .. if not after you press it look on the top of the display and select job status or print status. the select the job you want to delete and press delete.
NOTE: if your machine has a fax you cannot delete fax jobs without doing an all reset!
Sep 07, 2011 | Toshiba estudio 305 Copier
Fax out Memory Status 1. Fax out fail ( do i have to Re-fax again by myself Or the machine will Fax out by Memory and 2. HOw If I need to use the Same Memory Number to RE-FAX again ( which Key...
The machine will automatically re-fax documents to a pre set ammount, then give you the fail message. In that case you will have to re-fax yourself. It is possible to change the default number of times that the machine will try for you, but you will have to look in the manual for that.
Oct 06, 2010 | Office Equipment & Supplies
How do I print the fax numbers I have saved in my M24
  1. Press the [Machine Status] button on the Control Panel. The Machine Status button is the bottom of the three buttons between the numeric keypad and the Touch Screen. The Machine Status screen will be displayed.
  2. Select the [Billing Meter / Print Report] tab on the Touch Screen.
  3. Select [Print Report / List]. The Print Report / List screen will be displayed.
  4. Select [Fax Mode Settings].
  5. Select [Address Book].
  6. Press the [Start] button on the Control Panel. The report will print.
Aug 10, 2010 | Xerox Workcentre M24 Color Copier
My phone doesn't receive signal .on display it shows test mode.what is the problem?
is your phone line working perfectly?
You may also need to check if there is an option for changing the status of the machine from test to working status.
Mar 31, 2010 | Philips Magic5 Voice DECT Duo - Fax /...
How do you program the machine to recognize the incoming fax ring tone
if it is a sharp fax machine it has a reception button which you could change the status of unit from telephone to fax or answering machine. usually the indicator of these button is located on the rightmost portion of the lcd screen. once you press the reception button while the unit is on standby, the indicator will point on which of the three settings will you want to activate.
May 12, 2009 | Office Equipment & Supplies
Status NG BO
POWER OFF THE MACHINE PRESS 1 3 *(star) together. switch on machine while holding this three sw.
machine will rest.
May 05, 2009 | Toshiba e-Studio DP170F Plain Paper Laser...
Unable to fax or receive faxes
Make sure the phone cord is hooked to the LINE OR FAX port.
Feb 16, 2009 | HP LaserJet 3055 All-In-One Printer
Incoming fax freezes system
Try installing the fax controller again, make sure to turn off fax machine, reboot computer and then after trying turning on your fax and send another document.
Nov 18, 2008 | Symantec WinFax Pro for PC
GETTING COM AS 634 INSTEAD OF OK STATUS WHAT IS THE REASON
This is what the code means:
Redial was not successful due to no response from the called station or wrong number dialed.
Note
: If busy tone was not detected, the machine will only redial once.
So the your fax machine is getting no response from the fax you're calling.
Hope that helps...
Jun 13, 2008 | Panasonic Panafax UF-585 Plain Paper Laser...
Fax Mode "Status:Standby"
go to the fax option from the menu and check the status option .
The setting had been changed to standby ib your fax machine
Apr 29, 2008 | Canon PIXMA MP830 All-In-One InkJet...
HP 1040 Plain Paper Inkjet Fax Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
