Question about Mitsubishi WT-46805 46" Rear Projection Television
Mitsubishi WT-4605 - picture going dark, comes back
The picture on our set fades out and finally goes black.  Comes back again good as new and goes thru the process again.  Ideas?
  • 927 Answers
Good Day, rflinker;
Please check for fluid on the TV's PCB's, look toward the front of those boards, ensure all cables are properly seated into their sockets.
Good Luck, big IRISH.
Posted on Jul 25, 2008
Image goes black and then returns shortly after
Many sets that use lamps do this right before the lamp fails--average life is 2000 hours or 2 years of normal use--if no blinking lights suspect the lamp first.
May 29, 2012 | Televison & Video
Troublshoot Mitsubishi wt 46809
Fuse will not be bad if green power light comes on and stays on--if it came on and went off there is a self check.
Likely issues: if no sound also-----problem is in either power supply or set is in shutdown---has a latch circuit.
I have another suggestion based on having worked on hundreds of these sets-----Look first directly under the picture tubes and above the main boards---is there a gray or black plastic tray running under them?
Let me know what you have tried etc by pressing the "make a comment button" here-----
Mar 26, 2012 | Mitsubishi WT-46809 46" Rear Projection...
ACER EXTENSA 4620-4605 model screen problem
If you wiggle the screen and it comes back, then it is not your Video card. Probably just a loose connection with your LCD cable to the LCD screen. Although you may also need a new screen/cable.
The weird thing is that it "fades" out... which would indicate a bad screen to me.. but securing the cable is alot cheaper to try first.
Completely rule out your graphics card by connecting your laptop to an external monitor... if it works fine for a long period of time then your card is fine.
Good Luck.
Sep 06, 2009 | Acer Extensa 4620 Notebook
R52wh74 fades to one color then dark, then black
awewryte,
I have the same TV and now have the identical problem that you described. Did you ever get it fixed or find out what the problem was? If so, will you please pass the information on?
Thanks.
Aug 08, 2009 | RCA Televison & Video
Mits 46805 - Replaced IC's now picture is dim!
Good Day, Nickb2b;
The IC's you installed will not cause a dark/dim picture......but I would like you to check two things:
1. Make sure you put all cables that you may have unplugged into their proper positions, the cables are marked with numbers, ensure all cables are properly seated,
2. Look for fluid on the PCB's.
Jun 21, 2008 | Mitsubishi WT-46805 46" Rear Projection...
Monitor problem
This monitor is bad replacement is the only option as the CRT monitors are obselete you could get a good deal on one if you are not shopping for a flat panel!
Oct 24, 2007 | Samsung 793S 17" CRT Monitor
Picture goes dark
1 your problem is in video section 2 if it is ok then check power supply for any components defective.
Sep 15, 2007 | Sony FD Trinitron WEGA KV-32HS500 32" TV
Mitsubishi WT 46805 ~ Picture gone..... :0(
Good Day, Corri;
It sounds like the TV has a Circuit problem in the convergence circuit. If it comes and goes then the concern can be corrected by re-soldering the 'conv' output IC"s. A semi-minor repair and cost.
Aug 18, 2006 | Mitsubishi WT-46805 46" Rear Projection...
Mitsubishi WT-46805 46" Rear Projection Television Logo
95 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
