Question about RIM BlackBerry Curve 8310 Smartphone
I can't be heard on my phone. I can hear the other party. Mute appears to be off.
I can hear just fine. The other party can not hear me. Mute doesn't appear to be the problem
  • akin_ode Aug 24, 2008
    The same
  • annaatlaw Sep 14, 2008
    I have the same problem. I changed my sim card but the problem has persisted! I have spent countless hours with rogers technical support and each time, it looks like we've fixed the problem. But afterwards, I'll receive a call and within 3 minutes of being on the phone, the caller can no longer hear me even though I can hear them. Afterwards, I hang up and try to call the caller back but it keeps saying that the call has failed to go through.
You need to click on voice, it will bleep, close it and do it again then it will say, "say a command" close it, you will now be able to hear on your blackberry. They told me when you receive a text message with sound, it throws out your sound for the phone.
Posted on Sep 13, 2008
I had the exact sane problem! Im with rogers so I brought it to the rogers booth the said it could be the blackberry itsself but I had just gotten it a week ago so it couldnt be it then they figured out I didnt put in my sim card properly so maybe it could be that
Posted on Sep 08, 2008
Is there a mute button I can use while on the phone
yes when you make a call hit the menu button and select mute and visa versa and when the call is taking place you can hit the left soft key button to mute hope this was helpful:)
Sep 15, 2009 | Samsung BlackJack II Smartphone
T-Mobile Wing rings normally when calls are received and calls can be dialed OK. HOWEVER, when connected on an incoming or outgoing call, I cannot hear the other party and they cannot hear me. I tried the...
I hate to say it but you might need to hard-reset the phone. If you choose to do so BACK UP YOUR DATA first. You can get a free program called "PIM Backup." This will let you back up all of your contacts, emails, etc. (all personal information). To hard reset, hold down both of the soft keys at the same time, then simultaneously use your stylus to hit the reset button. You should get a black screen with some text on it asking if you want to hard reset. Press the "send" key to confirm. If you don't get the screen right away keep trying as it doesn't work perfectly every time.
Sep 01, 2009 | T-Mobile Wing™ Smartphone
Can't hear or be heard during phone calls
This is a known promblem with the treo phones.
If you had a wired headset plugged in to your phone then removed it. The phone thinks the headset is still plugged in. Try putting headset back in phone and removing it. You may need to do this a couple of times. If it still doesn't solve the problem make sure your bluetooth on the phone is turned off. If problem still exists you may have to contact your carrier for replacement.
Good Luck,
trweekes
Aug 24, 2008 | Palm Treo 755p Smartphone
T-Mobile MDA
If you are sure you can't be heard while NOT on speakerphone, it's probably a software problem, if you can be heard but can't hear while NOT on speakerphone, then it might be a bad Mic. If you really can't be heard while NOT on speakerphone and you are out of other options, perform a HARD RESET to restore the phone to factory (or current ROM) settings. Check to make sure the mute function isn't being initiated when you take the phone off speakerphone or start a call.
READ AND FOLLOW THIS GUIDE TO PERFORM A HARD RESET.
Aug 18, 2008 | T-Mobile MDA
Is there a mute button on this phone?
Try using a headset temporarily.
If the headset works - then its a speaker problem that needs to be fixed.
You could get by with the headset while the service center gets you a replacement.
Jul 10, 2008 | Palm Treo 755p Smartphone
Blackberry 8300 Curve
Try using the voice dialing feature. I had the same problem until I used the voice dialing. It worked fine after that.
Jun 07, 2008 | AT&T Blackberry Curve 8300 Smartphone
Hi
The first 2 answers sound relay dumb but always start at the beginning when diagnosing a problem. 1: make sure you're not placing your thumb over the Mic (located at the bottom, front of the device). 2: make sure Mute is not turned on, if it is tap it to turn it off. 3: if your using handsfree mode try picking the phone up and using it normally. There's no Mic volume control in the standard Matchbox based GUI but some 3rd party software does include volume adjustments so take a look at your settings in any control apps you have installed. lastly see if you get the same problem using a headset, you have not said if you are using the phone normally, with a headset/BlueTooth headset or in handsfree mode. Post back if non of this helps.
Aug 23, 2007 | Motorola Mobility A1200
Callers can't hear me speak
Corded Mic works great. I am going to try and buy a $20 Mic piece and replace that to see if it works, as it does not seem to be a major problem.
Aug 17, 2006 | Siemens SX66
RIM BlackBerry Curve 8310 Smartphone Logo
161 people viewed this question
Top RIM Computers & Internet Experts
Trisha
Trisha
Nataly Roberts
Nataly Roberts
SANTHOSH
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
