Question about Breville ESP8XL Espresso Machine
Steam wand, little water coming out, but no steam?
How is the best way to clean the wand/pipe?
  • 515 Answers
If you look at the end on the steam pipe you will see a nipple, loosen this and make sure it is clean.
Posted on Jul 25, 2008
Steam wand not working
The steam wand ejects steam in order to froth the milk. The steam wand should be cleaned after it is inserted into milk and at the end of each day. Do not allow the steam wands to soak in water overnight since some of the dirty water can be sucked into the boiling tank inside the machine this may cause the steam not to come out
Unplug the machine, take the case off, disconnect the switch wires and test it with a continuity meter. If you don't get any continuity, or if it is constantly closed and never open, the switch is bad.
this could have been prevented by regular maintenance and proper use. The usual suspect is a gummed up wand or brew line or user error. Here’s what to look for and how to avoid it.
First, notice what kind of wand you have. Most semi-automatic and porta-filter espresso units will have wands that resemble those on bottom or right, although the tips may be different. Some tips do not slide up and down to alter the aeration, as the one on the bottom does. If your wand is from an older (1990s) unit, it could have a more bulbous tip and a smaller hole in the tip. wandte1.jpg wandte2.jpgSome of the new wands give you a manual/automatic control.
wandte3.jpg Many of the new super automatics come with an automatic frothing unit, like this one from Jura-Capresso. The nice thing about the frothing wands on Jura-Capresso's new units is that they allow for even more control.
The "Dual Frother Plus" (top) works like the traditional frothing wand. The metal sleeve goes up for steam, down for foam.
The "Froth Xpress Plus" is a very handy device which can be used with the included sleek milk container or a distinct milk container, like a 1/2 gallon jug. The Froth Xpress has a tube (hard for using the included container, flexible for using a different container) that fits into the frothing tube behind the dial shown in the picture above. After selecting froth or steam, the milk is siphoned into a cup below the steam wand. We recommend steaming the milk first, then adding the espresso.
Whatever sort of wand you have, it is essential to keep it clear of solidified milk which can gum up the tip and even the wand shaft. Here are some symptoms of a clogged wand:
  • Little or no steam comes out of the wand
  • Hot water drips from the tip of the wand
  • A squeal or whistle comes out of the wand when the steam function is selected
  • A deep humming is heard when the steam function is selected*
*This is also a symptom of another more serious problem, particularly if you have a pump espresso machine; so if unclogging the wand does not solve it, you should contact a technician.
A good preventative measure against the clogging of a steam wand is regular rinsing in warm, soapy water of the tip and any other removable frothing part. This should be done after each steam wand use. If your machine has a Froth Xpress, it is important to clean all of the hoses, valve, and connectors (be very careful with the plug, however, because it is delicate). All wands should also have steam jetted through them after a frothing cycle is run.
Another preventative measure is to run a steam cycle for about twenty seconds before each new use. This will eject stray particles before they can build up and cause serious damage. There is also a cappuccino cleaner available which can be used in the automatic frothing devices. The solution is placed in a reservoir, and a full cycle is run until the reservoir is emptied. This can be done every few weeks or every few months, depending upon use.
Aside from prevention, there are treatments for a clogged wand. First, remove the tip, if the tip is removable. Usually they are, as in the case of the plastic tips above. The holes are usually big enough to run a pin or even a small paperclip through (emphasize small) to remove the gunk. If these items are too large, do not attempt to use them; instead try using a thin gauge wire from an electrical wire strand. Next, the metal wand itself can have a pipe cleaner run up into it. Start out by putting just about a half inch of the pipe cleaner up the wand, rubbing it around, then pulling it out. Gradually work more of the pipe cleaner up the wand, but never let the length of pipe cleaner in the wand exceed the wand length. We recommend the pipe cleaners with the stiff barbs attached, as opposed to the mostly soft ones. Do the same for all of the hard hoses and connectors. With respect to rubber or soft plastic parts, rinse them in soapy hot water. If flexible hoses form holes, replacements are available (give us a call) or we've even had some luck at aquarium supply stores.
PLEASE NOTE: if you own the Jura X7 or the Froth Xpress Plus, the diameter of the tiny holes is very important. We recommend trying not to put pins into these holes. However, if they must be cleaned and soaking won't work, a smaller gauge wire, a single strand, should do the trick. Always use a strand that is smaller than the diameter of the hole.
Frothing wand technology is advancing at a breakneck speed, but along with these advances come serious precautionary measures for dealing with these very delicate mechanisms. Follow the steps above, and your machine should be producing full-fledged froth for its entire life.
May 26, 2008 | DeLonghi Esclusivo Magnifica ESAM3300...
Water smell
You may have some residue inside the steam pipe from previous uses (e.g. milk). If you know how to remove the steam pipe, this will be easy to clean. Otherwise, you could try a pipe cleaner (depending on the type of steam wand).
You can also try running the steam pipe into some water, but be careful not to overheat the boiler (consult your manual... it may say you can't steam continuously for more than a minute, or even less).
Sep 24, 2013 | Nuova Simonelli Microbar Espresso Machine
We have a 4 month old gaggia titanium. Today, the steam wand stopped working. (It makes coffee just fine.) I've cleaned the steam wand. When I turn the steam dial, very little steam comes out and I hear a...
Sounds like the steam wand is getting blocked some where either at the metal end or in the parnello wand if you machine has one at the end of the steam wand, if both of those are clean then try this push in on the steam knob if that works then tap rod assemble or steam valve needs to be replaced, make sure to ask about the stainless steel valve instead of the plastic one.
Oct 06, 2010 | Gaggia Titanium Espresso Machine
If pump does not work then what should i priory
Need more information to solve your problem.
Does the pump come on (do you hear it?) but no water comes out when you make coffee?
When you select Hot Water and open the steam valve, does the pump run and does water come out the steam valve?
If you hear the pump running but no water is coming out - then it could either be that the pump needs to be primed. In that case you would select Hot Water and open the steam valve all the way and let water run out the wand for a minute or two.
If the steam wand delivers water but you don't get any water when you brew coffee, then either the coffee is ground so fine that the water cannot go through the coffee grinds OR the filter disc may be plugged up. Try grinding coarser and try removing the filter disc and cleaning it with a toothbrush - hold the disc to the light and verify that you can see through all the tiny holes.
If it pumps water for coffee but you don't get water out the steam pipe, then the steam wand may be plugged with hardened milk - in that case remove the plastic frother and soak it and clean it. Also use a bent paperclip to clean the hole in the end of the chrome steam pipe.
If the pump doesn't run at all and you don't hear any pump noises ever - then either the pump has failed or has a loose wire.
No Cappuccinatore or Steam and Loud Bang!
The steam is ariving to the steam wand with a thin teflon pipe which is conected to a easy clip on union. So probably by the presure of the steam in the pipe since the capucinatote was gogled the pipe have been came out from the union so the steam is leaking in the machine. Be carefull not work the steam since the water in the machine can make an electrical short and damage the machine completly. Now in order to fix the problem first you must remove the top and side panel in order to connect back the steam pipe to the wand union and second to clean the capucinatore by complitly desasemble it put it in special detergent and leave it fro some our so any dirt will be removed more easily and by a good visual inspection you can see that all holes are cleaned from any dry milk.
Jun 05, 2010 | Saeco Royal Professional Espresso Machine
No steam pressure with little to no water/steam
Remove the steam wand and inside you will find a small teflon like tube at the top, throw that away and run water through the wand to make sure it is clear then re-assemble in machine and test.
Jul 26, 2009 | Gaggia Syncrony Logic 74884 Espresso...
The coffee brews fine but the steam wand is not working.
Pressure build ok.
Dec 09, 2007 | FrancisFrancis! X1 Espresso Machine
No steam, just hot water.
The steam wand has to be removed to be cleaned properly. Unfortunately, this procedure is not outlined in the manual. Just cleaning the wand on the outside or using a clip to clean the tip is not enough.
The other end of steam wand where it connects to the pressuring cabin actually swivels around a fitting. It is this fitting that you need to thoroughly clean. Years of using the machine can cause calcification around this fitting.
If you look under this end of hte steam wand, you should see a philllip-headed screw. Before you loosen this screw, you have to remove the grey trim so that the entire wand can be remove.
Once the entire wand is removed, what I just described will be much clearer.
Nov 10, 2007 | Breville ESP8XL Espresso Machine
Problem with steam wand on my espresso machine
Did you try to prime the wand by running water through it for 4 seconds? After you do that it should work fine.
Aug 28, 2007 | Saeco Classico Espresso Machine
Breville ESP8XL Espresso Machine Logo
190 people viewed this question
Top Breville Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Steve
Colin Stickland
Colin Stickland
Are you a Breville Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
