Home
My Products
Sign In
Back to:
All Products
Fax Machines
Troubleshooting
Tags
Find a Manual
paper feed
how to adjust
fax machine
fax sending
Generic problem for all Brother Fax Machines
I have a FAX -
posted by
pmiles111
on Jul 25, 2008
Report abuse
I have a FAX - 775. Relatively new.
It is the paper feed when the machine starts sending. The paper doesn't stay straight and bunches up and gets stuck.
I cannot find anything in the manual that helps.
Solve This!
I have the same problem.
X
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
OK
Solution #1
posted on Jul 25, 2008
jon_than21
Rank:
Wiz
Rating:
85%, 15 votes
try adjusting the paper guide on both side.
Was this solution helpful? Show your Appreciation by rating it:
Inappropriate
Thanks for Trying
Helpful
FixYa!
Thank You!
Was the solution helpful?
Show your appreciation by commenting on I have a FAX -:
I don't want to Accept this solution
Done
Suggest a new solution for this problem
This Problem Also Relates To:
Brother IntelliFax-2820 Plain Paper Laser Fax
Brother IntelliFAX 1840C Plain Paper Inkjet Fax
Brother IntelliFAX 770 Plain Paper Thermal Fax
Brother IntelliFAX 1270E Plain Paper Fax
Brother Personal FAX-170
Brother MFC-3320CN Plain Paper Inkjet Fax
Brother MFC-730 Inkjet Fax
Can you Help with these Fax Machines problems?
Brother IntelliFAX 4100 Plain Paper Laser...
Black Line on Side of Paper
There is a line on the side of the paper that makes it...
Answer This...
Fax Machines
I was sent a form
I was sent a form with directions to open with Adobe. I...
Answer This...
Fax Machines
need to replace a broken
need to replace a broken gear in paper shredder motor
Answer This...
Panasonic KX-FHD331 Plain Paper Thermal...
Need to get a report
Need to get a report of sent faxes for the month of June...
Answer This...
Fax Machines
the ratio is stuck on
the ratio is stuck on 145%. The only way I can get it off...
Answer This...
Let Our Experts
Solve
Your Problems
Ask!
Loading problems.
Makik
Wiz
Let FixYa Experts
Solve Your Problem
Ask!
Repair Service
Find Fax Machine Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
No
Yes
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
