Question about RCA F19625 19" TV
No sound on older samsung tv
Watching tv,yesterday; there was a slight sound and then NO sound. After some time, the sound came back on. Today, when I turned on the tv there was no sound -- after about 20 minutes, the sound came on perfectly -- it lasted about 25 minutes and then a noise and no sound. This has happened twice today, but mostly excellent picture and NO sound.
Is it possible to hook up external speackers or do we throw away the tv?
Gary
  • 3 Answers
Techs call this a cold or a bad solder connection on the output transistor most likely, tap on it here and there when it happens on the bottom and side of tv, if sound comes in then stops again then it would be a loose connection due to heat over time, if your inclined u can be fixed it, if bad chip it would play first then shut off, or if u have a cable box or rca outputs on tv use them on an amp to get sound, that would bypass amp output and u will use the preamp section which is a different circuit, debgh@comcast.net
Posted on Jul 25, 2008
Sound okay on tv but no sound on bluray player
Make sure the audio inputs are on the same input as the video cable.
Dec 29, 2014 | Audio Players & Recorders
My Samsung TV model LE46C580J1K started with problems yesterday when for no reason in the middle of watching a programme the picture went red and looked like a colour negative photograph. I couldn't change...
Sounds like main board fault. Contact any service technician, or the authorized service center to confirm. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy Pull up older posts. Surf the site with patience.
Apr 24, 2014 | Samsung Televison & Video
The screen on my tv has two slightly discoloured vertical bars
Sounds like image retention. Is it an older Plasma TV?
Image retention is when an image left is left on for a while actually "burns" into the image. It would be especially noticeable in BluRay because it is a bright image. The burn in was probably cause by watching Cable in 4:3. Try to find a static white image to display over night that should remove the burn in.
Nov 25, 2009 | Samsung Televison & Video
Picture remains for few seconds then screen goes blank, sound remains on
I had this problem on my 42" Philips LCD. Just got it yesterday and worked fine on the tv stand. As soon as I mounted the TV to the wall via wall mount system, I had the exact same issue you did. Figured it out today.
The wall mount was putting pressure against the center of the back of the tv (tv set had a slightly rounded back plate, and the mount was a flat plate). As soon as I put spacers (part of the wall mount hardware set) between the wall mount braket and the tv so there was no contact except at the mounting holes, the tv worked fine.
My theory is the pressure pushed the tv back plate against some board components which caused them to overheat (no air flow); or put pressure on internal connectors. I dont know.
Hope this helps, may not apply to your situation.
Sep 01, 2009 | Samsung SM932MW 19 in. LCD TV
Samsung lcd model LN-T4661F,no picture, no sound, when I turn it off, slight screen flicker and tone, one and half yrs. old . Yesterday I turned it on and off about 10 times and it finnally came on, Today...
I have had this problem twice. about 9 months apart. each time i vacumed out the back the tv through the vents. the first time i did this the tv worked right away. the second time the screen went it took a little more. i had to reverse the vacum to blow the air out i blew the air throught the vents and vacumed it. one think i realized was the hole where the stand went made it very easy to accomplish this. the first time it last for a while we will see how it works this time. my unprofiessional opinion is the the dust build up blocks something. if this works for anyone please let me know.
good luck.
May 03, 2009 | Televison & Video
Whilst watching tv after 10 to 15 min screen goes blank but sound ok ,when u turn tv off then back on u get pitcure for about 10 minthen goes off again
I had this problem on my 42" Philips. Just got it yesterday and worked fine on the tv stand. As soon as I mounted the TV to the wall via wall mount system, I had the exact same issue you did. Figured it out today.
Feb 28, 2009 | Samsung LE40R74BDX 40 in. LCD Television
Samsung ht-z310 sound problem.
First check the mute button. hope this help
Dec 16, 2008 | Samsung Audio Players & Recorders
No sound when watching freeview on Samsung 32" LCD TV
I`ve got the same problem, sound with analog but not digital?
Dec 12, 2007 | Televison & Video
TV does not turn on
Most likely a bad flyback transformer....circuit board pull +
xformer R & R not for novice.....Part # 1-453-285-21.........T.
Apr 25, 2007 | Sony KP-57WS510 57" Rear Projection HDTV
RCA F19625 19" TV Logo
94 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
