Question about HP Pavilion ZV5000, ZV6000, ZX5000 Series 12 Cell Li-Ion Battery - DP390A (DP390A1) CD-ROM Drive
Will not power on
Ac plug lights up power indecator, press power button on and everything goes off.
    Genius:
  • 1,142 Answers
Reseating the RAM may resolve this issue.
Step 1 - Remove the battery
  1. Slide and hold the battery release latch to the unlock position.
  2. Use your finger to lift the battery up and out.
Step 2 - Remove the memory module
  1. Locate the memory module cover on the bottom of the notebook.
  2. Remove the screw that covers the memory module.
  3. Use your finger or a flat head screw driver to lift the inside edge of the memory module and remove it.
  4. Push both tabs outward simultaneously to release the memory module.
  5. Grasp the memory module by the edges and pull gently to remove it.
  6. After removing one module, replace the memory expansion cover and then replace the screw.
Step 3 - Replace the battery
  1. Insert the battery into the notebook.
  2. Push the battery into the base enclosure until you hear a click.
  3. Connect the AC adapter and turn on the notebook.
NOTE: If the PC will not start up and you experience another failure not covered in this article, see Related links . After the memory is reseated, connect the AC adapter and turn on the notebook.
Posted on Aug 12, 2008
  • Maanita Chadha
    Maanita Chadha Aug 12, 2008
    if you face an issue of system shutdown due to heatup, then the fan needs a repair and can be done by a repair technician
How to fix power button
Pam,
The problem is probably not the power button. If you have the AC adapter plugged in but you do not see any lights indicating that there is power reaching the laptop (such as the light that indicates that the battery is charging), chances are that you have a bad motherboard. The other possibility is that you have a broken DC power jack (where the AC adapter plugs into the laptop). Neither the motherboard nor the power jack are user-repairable issues. My advice would be to take this unit to a local professional computer repair center and have it evaluated.
Oct 22, 2014 | Acer Aspire AX1700-U3793A PC Desktop
I have a compaq presario cq50-107nr and i plug my charger in the front light is on but when i press the power button to start up the light goes off and nothing happens help? It happen several times and i...
Please 1. unplug the ac adapter, detach the main battery, press the power button for 15 seconds, plug in the ac adapter, and restart your laptop. If the problem persist: 2.unplug the ac adapter, detach the main battery, press the power button for 15 seconds, take out the hard drive, plug in the ac adapter, and restart your laptop. If the problem persist, then it means that the laptop motherboard is dying. Please read your laptop's service manual before you open the laptop's case/body.
Mar 01, 2014 | Computers & Internet
New motherboard still no power
Remove the main battery and try again, next sub out the ram one at a time and test, I would sub out the power supply to be sure it is basically the only thing left.
May 07, 2012 | Dell XPS M1330 Notebook
Hello my fujitsu e2010 jusr stop working it will
Hi. Try to remove the battery, unplug the ac adapter and press/hold the power button for 10 seconds then plug the ac adapter in. do not put thebattery back in yet. turn the computer on and see what will happen.
If nothing happens, your motherboard needs to be replaced.
Good Luck!
Jun 06, 2010 | Fujitsu Siemens LifeBook E2010 Notebook
Not powering up. The LED power light is just flashing when the battery is in.when the battery is taken out it remains lighted up but goes out when the power switch is pressed.
Try draining the static of the computer.
Turn off the system
remove the AC Adapter and all 3rd party devices if there is?
Remove the battery
press and hold the power button for 1 minute
then,
plugged back in the AC Adapter and battery
turned on the computer
May 19, 2010 | HP Mini 1140NR Netbook
Travelmate only powers up with battery inserted. But AC still charges battery. Orange light goes on and of
Sorry to tell you this but you may have a problem with the charging system. That will require you to return it to Acer or an Acer service center. You can also try this. I got this from Acers' travelmate support website:
If the notebook does not power on:
Make sure the ac adapter is correctly plugged into the notebook and into the power cord.
If everything is plugged in correctly and it still will not power on, follow these steps to complete a ‘power reset' of the notebook.
  1. Unplug the ac adapter. Keep ac adapter unplugged.
  2. Remove the battery and keep the battery unplugged.
  3. Hold the power button down for 15-20 seconds. (Nothing will appear on the display and none of the lights will light up.)
  4. Release the power button and plug in the ac adapter ONLY. (Please note that a power indicator light should be lit on the ac adapter when it is plugged in).
  5. Normally power on the notebook.
  6. If the unit does not power on, remove the ac adapter and insert the battery into the system.
  7. Plug the ac adapter back into the system, the battery charging indicator light will light up.
    If the battery charging indicator light does not light up, the ac adapter may not be providing proper power to the unit, and may need to be replaced.
You can aslo google your specific model of Travelmate to see if others are having this issue.
Les
Jun 27, 2009 | Acer Computers & Internet
My problem is with the AC on my 91 Civic Wagon. It suddenly became inop after an engine change. Wiring seems to be good along with relays. My problem is there is no ground on the clutch relay to actuate...
changing or swapping engine should have no effect on ac unit if you have everything plug back in correctly. I replace my engine also and plug everything back in with no problems. when you press the ac button does it light up? if not than you have no power to the switch and to clutch/compressor. take a meter tester to see if any power going to the compressor when the ac button is on position and also to the ac button. if not check your relay see if its good and test the plug where the relay plug in to see if any current flow though it. I suggest to pick up Chilton manual repair book from auto zone or pep boys for schematic.
Jun 10, 2009 | 1991 Honda Civic
Travelmate 2300 won't power on
The problem could be your bezel.  Remove the 3 screws from the hinges from the rear and you will be able to remove the black strip above the keyboard (after removing the screws, make sure laptop is layed wide open)  once removed, press the button on the motherboard under where the power button is.  If the unit still does not power up, then your motherboard is bad and needs to be replaced.  If it does power up, you need to replace the bezel.
Oct 18, 2007 | Acer TravelMate 2300 Notebook
No Power
You know I had a problem like that at sometime back and I found that the CPU unit had come loose I dont how but it did so I pust it back in solid and away everything went. Cost nothing to try just you ego......goodluck
Sep 02, 2007 | Gateway MX6448 Notebook
HP Pavilion ZV5000, ZV6000, ZX5000 Series 12 Cell Li-Ion Battery - DP390A (DP390A1) CD-ROM Drive Logo
87 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
